One day my touchpad stopped working i cant seem to figure out why. I reinstalled manjaro and the issue still persists. If i run sudo modprobe psmouse proto=imps then it works but obviously doesnt have the touchpad features. When running xinput the touchpad can be seen there. However when debugging events with libinput there are no events seen from the touchpad. I tried disabling and renabling it with libinput but to no success.
Touchpad = ETPS/2 Elantech Touchpad
inxi output
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7658c3c0-2857-49ac-ae12-a6f22ed80c39 rw quiet
resume=UUID=e438a4ce-d424-4745-b83c-1888f3304230 udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 86D5 v: 96.31 serial: <filter> UEFI: AMI v: F.05
date: 11/06/2019
ID-1: BAT0 charge: 41.8 Wh (83.8%) condition: 49.9/49.9 Wh (100.0%)
volts: 11.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: Discharging cycles: 449
ID-2: hidpp_battery_0 charge: N/A condition: N/A volts: 3.9 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: Discharging
RAM: total: 13.58 GiB used: 1.6 GiB (11.8%)
Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 33550
Speed: 1223 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1223 2: 1281 3: 1221 4: 1221 5: 1223 6: 1222 7: 1223 8: 1378
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-1:2 chip-ID: 30c9:0013 class-ID: 0e02
serial: <filter>
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0
5.13.15-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 6.4 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: HPS0NEXF temp: 39.9 C scheme: GPT
ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%) used: 6.4 GiB (0.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 7658c3c0-2857-49ac-ae12-a6f22ed80c39
label: NO_LABEL uuid: C06D-8C9F
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e438a4ce-d424-4745-b83c-1888f3304230
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-4:3 info: Realtek 802.11ac WLAN Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: Luxvisions Innotech Limited HP TrueVision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.8 C mobo: 45.0 C
GPU: device: amdgpu temp: 45.0 C device: nouveau temp: N/A
Processes: 240 Uptime: 10m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1043 lib: 294 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
dmesg output:
[ 53.952328] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.952415] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.952411] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.952469] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.952527] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.952585] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.952667] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.952749] pci_pm_runtime_resume+0xaa/0xc0
[ 53.952751] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.952754] __rpm_callback+0x7b/0x130
[ 53.952757] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.952759] rpm_callback+0x1f/0x70
[ 53.952762] rpm_resume+0x55b/0x800
[ 53.952765] __pm_runtime_resume+0x4a/0x80
[ 53.952768] rpm_get_suppliers+0x3c/0xc0
[ 53.952770] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.952773] __rpm_callback+0x10c/0x130
[ 53.952776] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.952778] rpm_callback+0x1f/0x70
[ 53.952780] rpm_resume+0x55b/0x800
[ 53.952784] pm_runtime_work+0x6c/0xa0
[ 53.952786] process_one_work+0x1e3/0x3b0
[ 53.952789] worker_thread+0x50/0x3b0
[ 53.952791] ? process_one_work+0x3b0/0x3b0
[ 53.952794] kthread+0x133/0x160
[ 53.952795] ? set_kthread_struct+0x40/0x40
[ 53.952797] ret_from_fork+0x22/0x30
[ 53.952802] ---[ end trace 0cf98a80fe4cb06e ]---
[ 53.952846] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.952848] ------------[ cut here ]------------
[ 53.952849] nouveau 0000:01:00.0: timeout
[ 53.952859] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.952921] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.952965] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.952980] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.952982] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.952983] Workqueue: pm pm_runtime_work
[ 53.952986] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.953047] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.953049] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.953051] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.953052] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.953054] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.953055] R10: ffffafcd00167890 R11: ffffffff9b0c0e00 R12: 0000000000000246
[ 53.953056] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.953058] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.953059] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.953060] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.953062] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.953063] Call Trace:
[ 53.953065] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.953065] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.953139] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.953212] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.953284] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.953342] ? ktime_get+0x38/0x90
[ 53.953344] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.953428] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.953511] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.953569] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.953627] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.953685] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.953767] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.953849] pci_pm_runtime_resume+0xaa/0xc0
[ 53.953851] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.953854] __rpm_callback+0x7b/0x130
[ 53.953857] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.953859] rpm_callback+0x1f/0x70
[ 53.953862] rpm_resume+0x55b/0x800
[ 53.953865] __pm_runtime_resume+0x4a/0x80
[ 53.953868] rpm_get_suppliers+0x3c/0xc0
[ 53.953870] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.953873] __rpm_callback+0x10c/0x130
[ 53.953876] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.953878] rpm_callback+0x1f/0x70
[ 53.953880] rpm_resume+0x55b/0x800
[ 53.953884] pm_runtime_work+0x6c/0xa0
[ 53.953886] process_one_work+0x1e3/0x3b0
[ 53.953889] worker_thread+0x50/0x3b0
[ 53.953891] ? process_one_work+0x3b0/0x3b0
[ 53.953894] kthread+0x133/0x160
[ 53.953895] ? set_kthread_struct+0x40/0x40
[ 53.953897] ret_from_fork+0x22/0x30
[ 53.953901] ---[ end trace 0cf98a80fe4cb06f ]---
[ 53.953977] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.953978] ------------[ cut here ]------------
[ 53.953979] nouveau 0000:01:00.0: timeout
[ 53.953989] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.954050] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.954095] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.954110] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.954112] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.954113] Workqueue: pm pm_runtime_work
[ 53.954116] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.954177] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.954178] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.954180] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.954182] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.954183] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.954184] R10: ffffafcd00167890 R11: ffffffff9b0c1340 R12: 0000000000000246
[ 53.954185] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.954187] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.954188] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.954189] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.954191] Call Trace:
[ 53.954193] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.954266] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.954339] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.954411] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.954469] ? ktime_get+0x38/0x90
[ 53.954471] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.954555] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.954638] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.954696] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.954754] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.954784] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.954812] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.954894] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.954976] pci_pm_runtime_resume+0xaa/0xc0
[ 53.954978] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.954981] __rpm_callback+0x7b/0x130
[ 53.954984] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.954986] rpm_callback+0x1f/0x70
[ 53.954989] rpm_resume+0x55b/0x800
[ 53.954992] __pm_runtime_resume+0x4a/0x80
[ 53.954995] rpm_get_suppliers+0x3c/0xc0
[ 53.954997] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.955000] __rpm_callback+0x10c/0x130
[ 53.955003] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.955005] rpm_callback+0x1f/0x70
[ 53.955007] rpm_resume+0x55b/0x800
[ 53.955011] pm_runtime_work+0x6c/0xa0
[ 53.955013] process_one_work+0x1e3/0x3b0
[ 53.955016] worker_thread+0x50/0x3b0
[ 53.955018] ? process_one_work+0x3b0/0x3b0
[ 53.955021] kthread+0x133/0x160
[ 53.955022] ? set_kthread_struct+0x40/0x40
[ 53.955025] ret_from_fork+0x22/0x30
[ 53.955029] ---[ end trace 0cf98a80fe4cb070 ]---
[ 53.955073] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.955074] ------------[ cut here ]------------
[ 53.955075] nouveau 0000:01:00.0: timeout
[ 53.955084] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.955146] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.955191] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.955206] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.955208] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.955209] Workqueue: pm pm_runtime_work
[ 53.955215] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.955212] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.955272] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.955274] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.955276] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.955277] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.955278] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.955279] R10: ffffafcd00167890 R11: ffffffff9b0c1868 R12: 0000000000000246
[ 53.955281] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.955282] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.955284] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.955285] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.955286] Call Trace:
[ 53.955288] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.955288] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.955335] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.955362] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.955435] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.955507] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.955565] ? ktime_get+0x38/0x90
[ 53.955567] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.955643] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.955651] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.955734] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.955792] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.955850] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.955908] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.955990] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.956072] pci_pm_runtime_resume+0xaa/0xc0
[ 53.956074] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.956077] __rpm_callback+0x7b/0x130
[ 53.956080] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.956082] rpm_callback+0x1f/0x70
[ 53.956085] rpm_resume+0x55b/0x800
[ 53.956088] __pm_runtime_resume+0x4a/0x80
[ 53.956091] rpm_get_suppliers+0x3c/0xc0
[ 53.956094] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.956096] __rpm_callback+0x10c/0x130
[ 53.956099] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.956101] rpm_callback+0x1f/0x70
[ 53.956104] rpm_resume+0x55b/0x800
[ 53.956107] pm_runtime_work+0x6c/0xa0
[ 53.956110] process_one_work+0x1e3/0x3b0
[ 53.956112] worker_thread+0x50/0x3b0
[ 53.956115] ? process_one_work+0x3b0/0x3b0
[ 53.956117] kthread+0x133/0x160
[ 53.956119] ? set_kthread_struct+0x40/0x40
[ 53.956121] ret_from_fork+0x22/0x30
[ 53.956125] ---[ end trace 0cf98a80fe4cb071 ]---
[ 53.956354] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.956356] ------------[ cut here ]------------
[ 53.956356] nouveau 0000:01:00.0: timeout
[ 53.956367] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.956429] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.956475] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.956490] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.956492] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.956493] Workqueue: pm pm_runtime_work
[ 53.956497] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.956557] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.956559] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.956561] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.956562] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.956563] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.956564] R10: ffffafcd00167890 R11: ffffffff9b0c1dd8 R12: 0000000000000246
[ 53.956566] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.956567] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.956569] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.956570] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.956571] Call Trace:
[ 53.956587] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.956573] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.956640] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.956647] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.956720] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.956792] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.956850] ? ktime_get+0x38/0x90
[ 53.956852] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.956935] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.957019] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.957077] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.957135] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.957193] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.957274] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.957357] pci_pm_runtime_resume+0xaa/0xc0
[ 53.957359] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.957362] __rpm_callback+0x7b/0x130
[ 53.957365] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.957367] rpm_callback+0x1f/0x70
[ 53.957370] rpm_resume+0x55b/0x800
[ 53.957373] __pm_runtime_resume+0x4a/0x80
[ 53.957376] rpm_get_suppliers+0x3c/0xc0
[ 53.957379] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.957381] __rpm_callback+0x10c/0x130
[ 53.957384] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.957386] rpm_callback+0x1f/0x70
[ 53.957389] rpm_resume+0x55b/0x800
[ 53.957392] pm_runtime_work+0x6c/0xa0
[ 53.957395] process_one_work+0x1e3/0x3b0
[ 53.957397] worker_thread+0x50/0x3b0
[ 53.957400] ? process_one_work+0x3b0/0x3b0
[ 53.957402] kthread+0x133/0x160
[ 53.957404] ? set_kthread_struct+0x40/0x40
[ 53.957406] ret_from_fork+0x22/0x30
[ 53.957410] ---[ end trace 0cf98a80fe4cb072 ]---
[ 53.958067] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.958069] ------------[ cut here ]------------
[ 53.958069] nouveau 0000:01:00.0: timeout
[ 53.958081] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.958143] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.958190] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.958206] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.958208] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.958209] Workqueue: pm pm_runtime_work
[ 53.958212] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.958273] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.958274] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.958276] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.958277] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.958278] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.958280] R10: ffffafcd00167890 R11: ffffffff9b0c2318 R12: 0000000000000246
[ 53.958281] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.958282] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.958284] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.958285] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.958286] Call Trace:
[ 53.958289] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.958362] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.958435] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.958508] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.958566] ? ktime_get+0x38/0x90
[ 53.958568] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.958651] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.958735] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.958793] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.958850] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.958908] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.958990] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.959072] pci_pm_runtime_resume+0xaa/0xc0
[ 53.959075] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.959077] __rpm_callback+0x7b/0x130
[ 53.959080] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.959082] rpm_callback+0x1f/0x70
[ 53.959085] rpm_resume+0x55b/0x800
[ 53.959088] __pm_runtime_resume+0x4a/0x80
[ 53.959091] rpm_get_suppliers+0x3c/0xc0
[ 53.959094] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.959096] __rpm_callback+0x10c/0x130
[ 53.959099] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.959101] rpm_callback+0x1f/0x70
[ 53.959104] rpm_resume+0x55b/0x800
[ 53.959107] pm_runtime_work+0x6c/0xa0
[ 53.959110] process_one_work+0x1e3/0x3b0
[ 53.959112] worker_thread+0x50/0x3b0
[ 53.959115] ? process_one_work+0x3b0/0x3b0
[ 53.959117] kthread+0x133/0x160
[ 53.959119] ? set_kthread_struct+0x40/0x40
[ 53.959120] ret_from_fork+0x22/0x30
[ 53.959125] ---[ end trace 0cf98a80fe4cb073 ]---
[ 53.959315] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.959316] ------------[ cut here ]------------
[ 53.959317] nouveau 0000:01:00.0: timeout
[ 53.959327] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.959389] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.959435] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.959450] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.959452] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.959453] Workqueue: pm pm_runtime_work
[ 53.959456] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.959517] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.959518] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.959520] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.959521] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.959523] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.959524] R10: ffffafcd00167890 R11: ffffffff9b0c2828 R12: 0000000000000246
[ 53.959525] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.959526] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.959528] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.959529] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.959531] Call Trace:
[ 53.959533] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.959607] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.959679] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.959752] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.959810] ? ktime_get+0x38/0x90
[ 53.959812] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.959896] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.959979] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.960037] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.960095] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.960153] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.960235] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.960316] pci_pm_runtime_resume+0xaa/0xc0
[ 53.960319] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.960321] __rpm_callback+0x7b/0x130
[ 53.960324] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.960327] rpm_callback+0x1f/0x70
[ 53.960329] rpm_resume+0x55b/0x800
[ 53.960333] __pm_runtime_resume+0x4a/0x80
[ 53.960336] rpm_get_suppliers+0x3c/0xc0
[ 53.960338] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.960341] __rpm_callback+0x10c/0x130
[ 53.960343] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.960346] rpm_callback+0x1f/0x70
[ 53.960348] rpm_resume+0x55b/0x800
[ 53.960352] pm_runtime_work+0x6c/0xa0
[ 53.960354] process_one_work+0x1e3/0x3b0
[ 53.960357] worker_thread+0x50/0x3b0
[ 53.960359] ? process_one_work+0x3b0/0x3b0
[ 53.960362] kthread+0x133/0x160
[ 53.960363] ? set_kthread_struct+0x40/0x40
[ 53.960365] ret_from_fork+0x22/0x30
[ 53.960370] ---[ end trace 0cf98a80fe4cb074 ]---
[ 53.960412] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.960413] ------------[ cut here ]------------
[ 53.960414] nouveau 0000:01:00.0: timeout
[ 53.960423] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.960485] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.960530] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.960545] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.960547] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.960548] Workqueue: pm pm_runtime_work
[ 53.960551] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.960612] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.960613] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.960615] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.960616] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.960618] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.960619] R10: ffffafcd00167890 R11: ffffffff9b0c2d38 R12: 0000000000000246
[ 53.960620] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.960621] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.960623] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.960624] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.960626] Call Trace:
[ 53.960627] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.960701] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.960774] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.960846] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.960904] ? ktime_get+0x38/0x90
[ 53.960906] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.960990] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.961073] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.961131] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.961189] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.961246] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.961328] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.961410] pci_pm_runtime_resume+0xaa/0xc0
[ 53.961413] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.961415] __rpm_callback+0x7b/0x130
[ 53.961418] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.961421] rpm_callback+0x1f/0x70
[ 53.961423] rpm_resume+0x55b/0x800
[ 53.961427] __pm_runtime_resume+0x4a/0x80
[ 53.961429] rpm_get_suppliers+0x3c/0xc0
[ 53.961432] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.961434] __rpm_callback+0x10c/0x130
[ 53.961437] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.961439] rpm_callback+0x1f/0x70
[ 53.961442] rpm_resume+0x55b/0x800
[ 53.961445] pm_runtime_work+0x6c/0xa0
[ 53.961448] process_one_work+0x1e3/0x3b0
[ 53.961451] worker_thread+0x50/0x3b0
[ 53.961453] ? process_one_work+0x3b0/0x3b0
[ 53.961456] kthread+0x133/0x160
[ 53.961457] ? set_kthread_struct+0x40/0x40
[ 53.961459] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.961459] ret_from_fork+0x22/0x30
[ 53.961464] ---[ end trace 0cf98a80fe4cb075 ]---
[ 53.961508] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.961509] ------------[ cut here ]------------
[ 53.961510] nouveau 0000:01:00.0: timeout
[ 53.961519] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.961581] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.961626] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.961641] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.961643] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.961644] Workqueue: pm pm_runtime_work
[ 53.961649] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.961647] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.961707] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.961709] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.961711] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.961712] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.961713] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.961714] R10: ffffafcd00167890 R11: ffffffff9b0c3260 R12: 0000000000000246
[ 53.961716] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.961717] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.961717] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.961720] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.961721] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.961723] Call Trace:
[ 53.961723] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.961725] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.961798] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.961871] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.961943] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.962001] ? ktime_get+0x38/0x90
[ 53.962004] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.962087] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.962170] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.962228] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.962286] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.962344] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.962425] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.962508] pci_pm_runtime_resume+0xaa/0xc0
[ 53.962511] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.962514] __rpm_callback+0x7b/0x130
[ 53.962517] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.962519] rpm_callback+0x1f/0x70
[ 53.962522] rpm_resume+0x55b/0x800
[ 53.962525] __pm_runtime_resume+0x4a/0x80
[ 53.962528] rpm_get_suppliers+0x3c/0xc0
[ 53.962531] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.962533] __rpm_callback+0x10c/0x130
[ 53.962536] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.962538] rpm_callback+0x1f/0x70
[ 53.962541] rpm_resume+0x55b/0x800
[ 53.962544] pm_runtime_work+0x6c/0xa0
[ 53.962547] process_one_work+0x1e3/0x3b0
[ 53.962550] worker_thread+0x50/0x3b0
[ 53.962552] ? process_one_work+0x3b0/0x3b0
[ 53.962554] kthread+0x133/0x160
[ 53.962556] ? set_kthread_struct+0x40/0x40
[ 53.962558] ret_from_fork+0x22/0x30
[ 53.962562] ---[ end trace 0cf98a80fe4cb076 ]---
[ 53.962607] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.962608] ------------[ cut here ]------------
[ 53.962609] nouveau 0000:01:00.0: timeout
[ 53.962618] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.962680] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.962725] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.962740] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.962742] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.962743] Workqueue: pm pm_runtime_work
[ 53.962746] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.962807] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.962808] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.962810] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.962811] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.962812] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.962814] R10: ffffafcd00167890 R11: ffffffff9b0c37b8 R12: 0000000000000246
[ 53.962815] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.962816] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.962818] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.962819] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.962821] Call Trace:
[ 53.962823] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.962823] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.962896] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.962969] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.963042] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.963100] ? ktime_get+0x38/0x90
[ 53.963102] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.963185] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.963269] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.963327] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.963385] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.963442] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.963524] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.963606] pci_pm_runtime_resume+0xaa/0xc0
[ 53.963609] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.963611] __rpm_callback+0x7b/0x130
[ 53.963614] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.963617] rpm_callback+0x1f/0x70
[ 53.963619] rpm_resume+0x55b/0x800
[ 53.963623] __pm_runtime_resume+0x4a/0x80
[ 53.963626] rpm_get_suppliers+0x3c/0xc0
[ 53.963628] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.963630] __rpm_callback+0x10c/0x130
[ 53.963633] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.963635] rpm_callback+0x1f/0x70
[ 53.963638] rpm_resume+0x55b/0x800
[ 53.963641] pm_runtime_work+0x6c/0xa0
[ 53.963644] process_one_work+0x1e3/0x3b0
[ 53.963647] worker_thread+0x50/0x3b0
[ 53.963649] ? process_one_work+0x3b0/0x3b0
[ 53.963652] kthread+0x133/0x160
[ 53.963653] ? set_kthread_struct+0x40/0x40
[ 53.963655] ret_from_fork+0x22/0x30
[ 53.963659] ---[ end trace 0cf98a80fe4cb077 ]---
[ 53.963700] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.963702] ------------[ cut here ]------------
[ 53.963702] nouveau 0000:01:00.0: timeout
[ 53.963711] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.963773] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.963818] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.963833] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.963835] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.963836] Workqueue: pm pm_runtime_work
[ 53.963847] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.963839] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.963900] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.963901] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.963903] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.963904] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.963906] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.963907] R10: ffffafcd00167890 R11: ffffffff9b0c3ce0 R12: 0000000000000246
[ 53.963908] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.963910] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.963911] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.963913] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.963913] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.963914] Call Trace:
[ 53.963916] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.963990] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.964063] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.964135] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.964193] ? ktime_get+0x38/0x90
[ 53.964196] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.964280] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.964363] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.964421] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.964479] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.964537] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.964619] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.964701] pci_pm_runtime_resume+0xaa/0xc0
[ 53.964704] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.964706] __rpm_callback+0x7b/0x130
[ 53.964709] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.964711] rpm_callback+0x1f/0x70
[ 53.964714] rpm_resume+0x55b/0x800
[ 53.964717] __pm_runtime_resume+0x4a/0x80
[ 53.964720] rpm_get_suppliers+0x3c/0xc0
[ 53.964723] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.964725] __rpm_callback+0x10c/0x130
[ 53.964728] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.964730] rpm_callback+0x1f/0x70
[ 53.964733] rpm_resume+0x55b/0x800
[ 53.964736] pm_runtime_work+0x6c/0xa0
[ 53.964739] process_one_work+0x1e3/0x3b0
[ 53.964741] worker_thread+0x50/0x3b0
[ 53.964744] ? process_one_work+0x3b0/0x3b0
[ 53.964746] kthread+0x133/0x160
[ 53.964748] ? set_kthread_struct+0x40/0x40
[ 53.964750] ret_from_fork+0x22/0x30
[ 53.964754] ---[ end trace 0cf98a80fe4cb078 ]---
[ 53.964795] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.964796] ------------[ cut here ]------------
[ 53.964797] nouveau 0000:01:00.0: timeout
[ 53.964806] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.964868] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.964913] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.964928] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.964929] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.964930] Workqueue: pm pm_runtime_work
[ 53.964933] RIP: 0010:g84_bar_flush+0xfa/0x110 [nouveau]
[ 53.964994] Code: 8b 40 10 48 8b 78 10 4c 8b 6f 50 4d 85 ed 75 03 4c 8b 2f e8 58 c4 e9 d8 4c 89 ea 48 c7 c7 cc 11 f9 c0 48 89 c6 e8 fb a0 24 d9 <0f> 0b eb a8 e8 7d c2 29 d9 66 66 2e 0f 1f 84 00 00 00 00 00 66 90
[ 53.964996] RSP: 0018:ffffafcd00167a68 EFLAGS: 00010086
[ 53.964998] RAX: 0000000000000000 RBX: ffff8f14d1a32800 RCX: 0000000000000027
[ 53.964999] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.965000] RBP: ffff8f14d6f52958 R08: 0000000000000000 R09: ffffafcd00167898
[ 53.965001] R10: ffffafcd00167890 R11: ffffffff9b0c4220 R12: 0000000000000246
[ 53.965003] R13: ffff8f14c11270e0 R14: 0000000000000000 R15: 0000000c8874c1c9
[ 53.965004] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.965006] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.965007] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.965009] Call Trace:
[ 53.965009] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.965010] nv50_instobj_release+0x32/0xc0 [nouveau]
[ 53.965084] nvkm_instobj_load+0x4f/0xa0 [nouveau]
[ 53.965157] nvkm_instmem_init+0x62/0x80 [nouveau]
[ 53.965230] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.965288] ? ktime_get+0x38/0x90
[ 53.965290] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.965374] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.965457] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.965515] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.965573] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.965630] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.965712] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.965794] pci_pm_runtime_resume+0xaa/0xc0
[ 53.965797] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.965799] __rpm_callback+0x7b/0x130
[ 53.965802] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.965805] rpm_callback+0x1f/0x70
[ 53.965807] rpm_resume+0x55b/0x800
[ 53.965811] __pm_runtime_resume+0x4a/0x80
[ 53.965814] rpm_get_suppliers+0x3c/0xc0
[ 53.965816] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.965818] __rpm_callback+0x10c/0x130
[ 53.965821] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.965824] rpm_callback+0x1f/0x70
[ 53.965826] rpm_resume+0x55b/0x800
[ 53.965829] pm_runtime_work+0x6c/0xa0
[ 53.965832] process_one_work+0x1e3/0x3b0
[ 53.965835] worker_thread+0x50/0x3b0
[ 53.965837] ? process_one_work+0x3b0/0x3b0
[ 53.965839] kthread+0x133/0x160
[ 53.965841] ? set_kthread_struct+0x40/0x40
[ 53.965843] ret_from_fork+0x22/0x30
[ 53.965847] ---[ end trace 0cf98a80fe4cb079 ]---
[ 53.965954] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.965955] ------------[ cut here ]------------
[ 53.965956] nouveau 0000:01:00.0: timeout
[ 53.965967] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/falcon/v1.c:276 falcon_v1_wait_idle+0xdc/0xf0 [nouveau]
[ 53.966028] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.966075] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.966090] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.966092] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.966093] Workqueue: pm pm_runtime_work
[ 53.966097] RIP: 0010:falcon_v1_wait_idle+0xdc/0xf0 [nouveau]
[ 53.966156] Code: 8b 40 10 48 8b 78 10 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 16 1a ea d8 4c 89 e2 48 c7 c7 aa 0e f9 c0 48 89 c6 e8 b9 f6 24 d9 <0f> 0b eb ad e8 3b 18 2a d9 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f
[ 53.966158] RSP: 0018:ffffafcd00167a58 EFLAGS: 00010282
[ 53.966160] RAX: 0000000000000000 RBX: ffffffffffffff92 RCX: 0000000000000027
[ 53.966161] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.966162] RBP: ffff8f14c5edec98 R08: 0000000000000000 R09: ffffafcd00167888
[ 53.966163] R10: ffffafcd00167880 R11: ffffffff9b0c4748 R12: ffff8f14c11270e0
[ 53.966165] R13: ffff8f14d0288c08 R14: ffff8f14cde94100 R15: ffff8f14cde94000
[ 53.966166] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.966167] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.966169] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.966170] Call Trace:
[ 53.966173] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.966173] nvkm_falcon_disable+0x36/0x50 [nouveau]
[ 53.966232] nvkm_falcon_reset+0xe/0x20 [nouveau]
[ 53.966291] gp102_fb_vpr_scrub+0xb8/0x1a0 [nouveau]
[ 53.966361] nvkm_fb_init+0x109/0x160 [nouveau]
[ 53.966428] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.966486] ? ktime_get+0x38/0x90
[ 53.966488] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.966572] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.966655] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.966713] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.966771] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.966829] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.966911] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.966993] pci_pm_runtime_resume+0xaa/0xc0
[ 53.966995] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.966998] __rpm_callback+0x7b/0x130
[ 53.967001] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.967003] rpm_callback+0x1f/0x70
[ 53.967006] rpm_resume+0x55b/0x800
[ 53.967009] __pm_runtime_resume+0x4a/0x80
[ 53.967012] rpm_get_suppliers+0x3c/0xc0
[ 53.967015] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.967017] __rpm_callback+0x10c/0x130
[ 53.967020] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.967022] rpm_callback+0x1f/0x70
[ 53.967025] rpm_resume+0x55b/0x800
[ 53.967028] pm_runtime_work+0x6c/0xa0
[ 53.967031] process_one_work+0x1e3/0x3b0
[ 53.967034] worker_thread+0x50/0x3b0
[ 53.967036] ? process_one_work+0x3b0/0x3b0
[ 53.967038] kthread+0x133/0x160
[ 53.967040] ? set_kthread_struct+0x40/0x40
[ 53.967042] ret_from_fork+0x22/0x30
[ 53.967046] ---[ end trace 0cf98a80fe4cb07a ]---
[ 53.967087] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.967088] ------------[ cut here ]------------
[ 53.967089] nouveau 0000:01:00.0: timeout
[ 53.967099] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/falcon/v1.c:289 nvkm_falcon_v1_enable+0x11e/0x130 [nouveau]
[ 53.967159] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.967205] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.967221] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.967222] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.967223] Workqueue: pm pm_runtime_work
[ 53.967226] RIP: 0010:nvkm_falcon_v1_enable+0x11e/0x130 [nouveau]
[ 53.967286] Code: 8b 40 10 48 8b 78 10 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 04 17 ea d8 4c 89 e2 48 c7 c7 aa 0e f9 c0 48 89 c6 e8 a7 f3 24 d9 <0f> 0b e9 6a ff ff ff e8 26 15 2a d9 66 0f 1f 44 00 00 0f 1f 44 00
[ 53.967287] RSP: 0018:ffffafcd00167a60 EFLAGS: 00010286
[ 53.967289] RAX: 0000000000000000 RBX: ffffffffffffff92 RCX: 0000000000000027
[ 53.967290] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.967292] RBP: ffff8f14c5edec98 R08: 0000000000000000 R09: ffffafcd00167890
[ 53.967293] R10: ffffafcd00167888 R11: ffffffff9b0c4c88 R12: ffff8f14c11270e0
[ 53.967294] R13: ffff8f14d0288c08 R14: ffff8f14cde94100 R15: ffff8f14cde94000
[ 53.967295] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.967297] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.967299] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.967300] Call Trace:
[ 53.967300] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.967303] nvkm_falcon_enable+0x36/0x70 [nouveau]
[ 53.967362] gp102_fb_vpr_scrub+0xb8/0x1a0 [nouveau]
[ 53.967431] nvkm_fb_init+0x109/0x160 [nouveau]
[ 53.967499] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.967557] ? ktime_get+0x38/0x90
[ 53.967559] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.967643] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.967726] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.967784] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.967842] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.967900] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.967981] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.968064] pci_pm_runtime_resume+0xaa/0xc0
[ 53.968066] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.968069] __rpm_callback+0x7b/0x130
[ 53.968072] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.968074] rpm_callback+0x1f/0x70
[ 53.968077] rpm_resume+0x55b/0x800
[ 53.968080] __pm_runtime_resume+0x4a/0x80
[ 53.968083] rpm_get_suppliers+0x3c/0xc0
[ 53.968086] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.968088] __rpm_callback+0x10c/0x130
[ 53.968091] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.968093] rpm_callback+0x1f/0x70
[ 53.968096] rpm_resume+0x55b/0x800
[ 53.968099] pm_runtime_work+0x6c/0xa0
[ 53.968102] process_one_work+0x1e3/0x3b0
[ 53.968104] worker_thread+0x50/0x3b0
[ 53.968107] ? process_one_work+0x3b0/0x3b0
[ 53.968109] kthread+0x133/0x160
[ 53.968111] ? set_kthread_struct+0x40/0x40
[ 53.968113] ret_from_fork+0x22/0x30
[ 53.968117] ---[ end trace 0cf98a80fe4cb07b ]---
[ 53.968119] nouveau 0000:01:00.0: fb: Falcon mem scrubbing timeout
[ 53.968579] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.968581] ------------[ cut here ]------------
[ 53.968581] nouveau 0000:01:00.0: timeout
[ 53.968592] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/falcon/v1.c:276 falcon_v1_wait_idle+0xdc/0xf0 [nouveau]
[ 53.968652] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.968698] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.968714] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.968716] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.968718] Workqueue: pm pm_runtime_work
[ 53.968721] RIP: 0010:falcon_v1_wait_idle+0xdc/0xf0 [nouveau]
[ 53.968780] Code: 8b 40 10 48 8b 78 10 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 16 1a ea d8 4c 89 e2 48 c7 c7 aa 0e f9 c0 48 89 c6 e8 b9 f6 24 d9 <0f> 0b eb ad e8 3b 18 2a d9 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f
[ 53.968781] RSP: 0018:ffffafcd00167a58 EFLAGS: 00010282
[ 53.968783] RAX: 0000000000000000 RBX: ffffffffffffff92 RCX: 0000000000000027
[ 53.968784] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.968786] RBP: ffff8f14c5edec98 R08: 0000000000000000 R09: ffffafcd00167888
[ 53.968787] R10: ffffafcd00167880 R11: ffffffff9b0c51c8 R12: ffff8f14c11270e0
[ 53.968788] R13: ffff8f14d0288c08 R14: ffff8f14cde94100 R15: ffff8f14cde94000
[ 53.968789] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.968791] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.968792] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.968794] Call Trace:
[ 53.968796] nvkm_falcon_disable+0x36/0x50 [nouveau]
[ 53.968855] nvkm_falcon_reset+0xe/0x20 [nouveau]
[ 53.968914] gp102_fb_vpr_scrub+0x15f/0x1a0 [nouveau]
[ 53.968983] nvkm_fb_init+0x109/0x160 [nouveau]
[ 53.969050] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.969108] ? ktime_get+0x38/0x90
[ 53.969110] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.969194] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.969277] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.969335] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.969393] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.969451] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.969533] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.969615] pci_pm_runtime_resume+0xaa/0xc0
[ 53.969618] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.969620] __rpm_callback+0x7b/0x130
[ 53.969623] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.969626] rpm_callback+0x1f/0x70
[ 53.969628] rpm_resume+0x55b/0x800
[ 53.969632] __pm_runtime_resume+0x4a/0x80
[ 53.969635] rpm_get_suppliers+0x3c/0xc0
[ 53.969637] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.969639] __rpm_callback+0x10c/0x130
[ 53.969642] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.969644] rpm_callback+0x1f/0x70
[ 53.969647] rpm_resume+0x55b/0x800
[ 53.969650] pm_runtime_work+0x6c/0xa0
[ 53.969653] process_one_work+0x1e3/0x3b0
[ 53.969656] worker_thread+0x50/0x3b0
[ 53.969658] ? process_one_work+0x3b0/0x3b0
[ 53.969660] kthread+0x133/0x160
[ 53.969662] ? set_kthread_struct+0x40/0x40
[ 53.969664] ret_from_fork+0x22/0x30
[ 53.969668] ---[ end trace 0cf98a80fe4cb07c ]---
[ 53.969709] nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
[ 53.969710] ------------[ cut here ]------------
[ 53.969711] nouveau 0000:01:00.0: timeout
[ 53.969721] WARNING: CPU: 0 PID: 18 at drivers/gpu/drm/nouveau/nvkm/falcon/v1.c:289 nvkm_falcon_v1_enable+0x11e/0x130 [nouveau]
[ 53.969781] Modules linked in: hid_logitech_hidpp hid_logitech_dj cmac algif_hash algif_skcipher af_alg bnep amdgpu mousedev intel_rapl_msr rtw88_8822ce snd_rn_pci_acp3x intel_rapl_common gpu_sched snd_pci_acp3x rtw88_8822c btusb rtw88_pci btrtl btbcm rtw88_core btintel edac_mce_amd snd_hda_codec_realtek bluetooth uvcvideo ccp snd_hda_codec_generic snd_hda_codec_hdmi ledtrig_audio videobuf2_vmalloc rng_core nouveau usbhid snd_hda_intel ecdh_generic videobuf2_memops hp_wmi ecc kvm videobuf2_v4l2 snd_intel_dspcfg mac80211 snd_intel_sdw_acpi videobuf2_common joydev platform_profile snd_hda_codec sparse_keymap wmi_bmof irqbypass videodev crct10dif_pclmul crc32_pclmul snd_hda_core ghash_clmulni_intel snd_hwdep mxm_wmi i2c_algo_bit mc drm_ttm_helper aesni_intel ttm crypto_simd cryptd rapl cfg80211 snd_pcm drm_kms_helper psmouse pcspkr snd_timer r8169 cec snd realtek vfat syscopyarea sysfillrect mdio_devres rfkill sp5100_tco sysimgblt fat k10temp i2c_piix4 libphy libarc4 soundcore fb_sys_fops
[ 53.969827] wmi hp_accel lis3lv02d pinctrl_amd hp_wireless i2c_hid_acpi video i2c_hid mac_hid acpi_cpufreq acpi_tad drm fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci serio_raw atkbd libps2 i8042 serio
[ 53.969843] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G W 5.13.15-1-MANJARO #1
[ 53.969845] Hardware name: HP HP Pavilion Gaming Laptop 15-ec0xxx/86D5, BIOS F.05 11/06/2019
[ 53.969846] Workqueue: pm pm_runtime_work
[ 53.969849] RIP: 0010:nvkm_falcon_v1_enable+0x11e/0x130 [nouveau]
[ 53.969908] Code: 8b 40 10 48 8b 78 10 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 04 17 ea d8 4c 89 e2 48 c7 c7 aa 0e f9 c0 48 89 c6 e8 a7 f3 24 d9 <0f> 0b e9 6a ff ff ff e8 26 15 2a d9 66 0f 1f 44 00 00 0f 1f 44 00
[ 53.969910] RSP: 0018:ffffafcd00167a60 EFLAGS: 00010286
[ 53.969911] RAX: 0000000000000000 RBX: ffffffffffffff92 RCX: 0000000000000027
[ 53.969913] RDX: ffff8f1770a18728 RSI: 0000000000000001 RDI: ffff8f1770a18720
[ 53.969914] RBP: ffff8f14c5edec98 R08: 0000000000000000 R09: ffffafcd00167890
[ 53.969915] R10: ffffafcd00167888 R11: ffffffff9b0c56f0 R12: ffff8f14c11270e0
[ 53.969916] R13: ffff8f14d0288c08 R14: ffff8f14cde94100 R15: ffff8f14cde94000
[ 53.969918] FS: 0000000000000000(0000) GS:ffff8f1770a00000(0000) knlGS:0000000000000000
[ 53.969919] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 53.969921] CR2: 00007fedfc006e40 CR3: 000000011a616000 CR4: 00000000003506f0
[ 53.969922] Call Trace:
[ 53.969929] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.969924] nvkm_falcon_enable+0x36/0x70 [nouveau]
[ 53.969988] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.969983] gp102_fb_vpr_scrub+0x15f/0x1a0 [nouveau]
[ 53.970040] systemd-journald[245]: /dev/kmsg buffer overrun, some messages lost.
[ 53.970052] nvkm_fb_init+0x109/0x160 [nouveau]
[ 53.970119] nvkm_subdev_init+0x92/0xd0 [nouveau]
[ 53.970177] ? ktime_get+0x38/0x90
[ 53.970180] nvkm_device_init+0x11f/0x1b0 [nouveau]
[ 53.970263] nvkm_udevice_init+0x41/0x60 [nouveau]
[ 53.970347] nvkm_object_init+0x3e/0x110 [nouveau]
[ 53.970405] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.970462] nvkm_object_init+0x73/0x110 [nouveau]
[ 53.970520] nouveau_do_resume+0x2b/0xd0 [nouveau]
[ 53.970602] nouveau_pmops_runtime_resume+0x7a/0x150 [nouveau]
[ 53.970684] pci_pm_runtime_resume+0xaa/0xc0
[ 53.970687] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.970689] __rpm_callback+0x7b/0x130
[ 53.970692] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.970694] rpm_callback+0x1f/0x70
[ 53.970697] rpm_resume+0x55b/0x800
[ 53.970700] __pm_runtime_resume+0x4a/0x80
[ 53.970703] rpm_get_suppliers+0x3c/0xc0
[ 53.970706] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.970708] __rpm_callback+0x10c/0x130
[ 53.970711] ? pci_pm_freeze_noirq+0x100/0x100
[ 53.970713] rpm_callback+0x1f/0x70
[ 53.970716] rpm_resume+0x55b/0x800
[ 53.970719] pm_runtime_work+0x6c/0xa0
[ 53.970722] process_one_work+0x1e3/0x3b0
[ 53.970724] worker_thread+0x50/0x3b0
[ 53.970727] ? process_one_work+0x3b0/0x3b0
[ 53.970729] kthread+0x133/0x160
[ 53.970731] ? set_kthread_struct+0x40/0x40
[ 53.970733] ret_from_fork+0x22/0x30
[ 53.970737] ---[ end trace 0cf98a80fe4cb07d ]---
[ 53.970738] nouveau 0000:01:00.0: fb: Falcon mem scrubbing timeout
[ 53.970742] nouveau 0000:01:00.0: fb: VPR still locked after scrub!
[ 53.970744] nouveau 0000:01:00.0: fb: init failed, -5
[ 53.970844] nouveau 0000:01:00.0: init failed with -5
[ 53.970847] nouveau: Xorg[864]:00000000:00000080: init failed with -5
[ 53.970850] nouveau: DRM-master:00000000:00000000: init failed with -5
[ 53.970852] nouveau: DRM-master:00000000:00000000: init failed with -5
[ 53.970855] nouveau 0000:01:00.0: DRM: Client resume failed with error: -5
[ 53.970857] nouveau 0000:01:00.0: DRM: resume failed with: -5
[ 60.642166] kauditd_printk_skb: 12 callbacks suppressed
