Touchpad stopped working in xfce
Dear all,
I use Manjaro with xfce for some weeks on my Thinkpad T14 for some months now. The touchpad and the trackpoint worked fine; until today. I already used the famous hint “Have you tried turning it off an on again?”
The trackpoint is working, the touchpad isn’t.
Both input devices are recognised:
xinput -list
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad              	id=10	[slave  pointer  (2)]
⎜   ↳ TPPS/2 Elan TrackPoint                  	id=11	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Video Bus                               	id=6	[slave  keyboard (3)]
    ↳ Power Button                            	id=7	[slave  keyboard (3)]
    ↳ Sleep Button                            	id=8	[slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            	id=9	[slave  keyboard (3)]
    ↳ ThinkPad Extra Buttons                  	id=12	[slave  keyboard (3)]
But libinput –debug-devices shows only output for the trackpoint. (If you want, I can share the output for the trackpoint at a later post.)
Here are some information about the system:
inxi -zv8
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=2f18b3d3-f2cb-4b1c-9f27-a3ee1aad6d7e rw rootflags=subvol=@
    "quiet
    cryptdevice=UUID=d83e8b7c-63d2-4795-a2b5-79f16a21e7a7:luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7
    root=/dev/mapper/luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7 splash
    apparmor=1 security=apparmor
    resume=/dev/mapper/luks-2f5c30c0-b084-4f03-a882-69db91174e81
    udev.log_priority=3"
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver avail: xscreensaver dm:
    1: LightDM v: 1.32.0 2: SDDM note: stopped Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 20UES3YA01 v: ThinkPad T14 Gen 1
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20UES3YA01 v: SDK0J40697 WIN serial: <filter>
    part-nu: LENOVO_MT_20UE_BU_Think_FM_ThinkPad T14 Gen 1
    uuid: a127d9cc-2fdf-11b2-a85c-d61c8d50fe70 UEFI: LENOVO v: R1BET65W(1.34 )
    date: 06/17/2021
  ID-1: BAT0 charge: 41.5 Wh (80.6%) condition: 51.5/50.5 Wh (101.9%)
    power: 9 W volts: 11.73 min: 11.55 model: LGC 5B10W139 type: Li-poly
    serial: <filter> charging: status: discharging control: start: 95%
    end: 100% cycles: 365
  System RAM: total: 32 GiB available: 30.58 GiB used: 2.6 GiB (8.5%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMAB2GS6AMR6N-XN serial: N/A
    part-no: HMA82GS6DJR8N-XN serial: <filter>
  Slot: 1 type: PCIe status: available info: J3600 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 2 type: PCIe status: available info: J3605 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 3 type: PCIe status: available info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:00.0
  Slot: 4 type: PCIe status: available info: J3702, M.2 length: long
  Slot: 5 type: PCIe status: available info: J3703, M.2 length: long
  Slot: 6 type: PCIe status: available info: J4000 length: long volts: 3.3
    bus-ID: 00:00.0
  Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/1700 boost: enabled
    base/boost: 1700/4200 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
    5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 54318
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 38.0 C
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 04f2:b6d0
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: eDP-1 mapped: eDP model: InfoVision Optronics/Kunshan 0x057d
    built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
    chroma: red: x: 0.580 y: 0.333 green: x: 0.329 y: 0.565 blue: x: 0.153
    y: 0.129 white: x: 0.314 y: 0.329 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    renoir ACO DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:1636 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,
    kscreen-doctor, xfce4-display-settings wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
    lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: n/a (root, process) with:
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-4:2 chip-ID: 8087:0029
    class-ID: e001
  Device-1: luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7 maj-min: 254:0
    type: LUKS dm: dm-0 size: 443.01 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 443.01 GiB
  Device-2: luks-2f5c30c0-b084-4f03-a882-69db91174e81 maj-min: 254:1
    type: LUKS dm: dm-1 size: 33.63 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 33.63 GiB
  Local Storage: total: 491.67 GiB used: 215.32 GiB (43.8%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Lexar model: NCard
    size: 14.73 GiB block-size: physical: 512 B logical: 512 B type: Removable
    tech: SSD serial: <filter> scheme: MBR
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41730C20 temp: 41.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 302d 21h cycles: 69,852
    read-units: 31,178,333 [15.9 TB] written-units: 26,481,220 [13.5 TB]
  ID-1: / raw-size: 443.01 GiB size: 443.01 GiB (100.00%)
    used: 215.32 GiB (48.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7
    label: N/A uuid: 2f18b3d3-f2cb-4b1c-9f27-a3ee1aad6d7e
    used: 824 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: E915-CE17
  ID-3: /home raw-size: 443.01 GiB size: 443.01 GiB (100.00%)
  ID-4: /var/cache raw-size: 443.01 GiB size: 443.01 GiB (100.00%)
  ID-5: /var/log raw-size: 443.01 GiB size: 443.01 GiB (100.00%)
  ID-1: swap-1 type: partition size: 33.63 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-2f5c30c0-b084-4f03-a882-69db91174e81 label: swap
    uuid: bc73af35-cb3f-4655-9921-1f073688cc01
  ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 3.76 GiB fs: iso9660
  ID-2: /dev/mmcblk0p2 maj-min: 179:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: CBD3-6116
  Hub-2: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 4-4:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-5: 5-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 6-2:2 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6d0 class-ID: fe01
    serial: <filter>
  Hub-7: 7-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: 1642 pm: pacman pkgs: 1632 libs: 416 tools: pamac pm: flatpak
    pkgs: 10
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 406
  1: cpu: 300% command: ps pid: 3231 mem: 4.10 MiB (0.0%)
  2: cpu: 10.7% command: firefox pid: 1777 mem: 586.1 MiB (1.8%)
  3: cpu: 6.4% command: firefox pid: 2256 mem: 311.2 MiB (0.9%)
  4: cpu: 3.2% command: Xorg pid: 1155 mem: 95.3 MiB (0.3%)
  5: cpu: 1.7% command: firefox pid: 2021 mem: 360.4 MiB (1.1%)
  Memory top: 5 of 406
  1: mem: 586.1 MiB (1.8%) command: firefox pid: 1777 cpu: 10.7%
  2: mem: 360.4 MiB (1.1%) command: firefox pid: 2021 cpu: 1.7%
  3: mem: 352.3 MiB (1.1%) command: firefox pid: 2047 cpu: 0.8%
  4: mem: 311.2 MiB (0.9%) command: firefox pid: 2256 cpu: 6.4%
  5: mem: 260.1 MiB (0.8%) command: firefox pid: 2014 cpu: 1.0%
  Processes: 406 Power: uptime: 22m states: freeze,mem,disk suspend: s2idle
    image: 12.2 GiB services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh (sudo) v: 5.9
    running-in: xfce4-terminal inxi: 3.3.39
mhwd-kernel -li
Currently running: 6.12.48-1-MANJARO (linux612)
   * linux612
   * linux66
mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
From my understanding output of lsusbor lspciwouldn’t be of much help, but if you want, I can happily share this with you. An additional external mouse via USB is working as expected.
Thank you in advance
varomanja
have you by accident used the Fn+F combo disabling the touchpad ?
On a Lenovo Legion it is Fn+F10
I don’t know about Xfce specifically but some environments provide a setting disable while typing - could it be as simple as that ?
Some drivers only work with X11 environment, so X11 or Wayland ?
Hi @varomanja,
Maybe I’m blind, but I am unable to find your input devices in your inxi output. Or the USB: section, for that matter. This leads me to think:
  • The command you used doesn’t supply the required info; and/or
  • the output is incomplete for whichever reason.
Therefore, I’m asking you to please return/provide the complete unfiltered, unchanged output of:
inxi -ev8
I just tested this on my computer and it does, indeed, provide the info.
Also, please do provide the output for:
lsusb
In xorg.0.logI found a “ignoring this device”.
Perhaps the full log is usefull:
    23.438]
X.Org X Server 1.21.1.18
[    23.438] Current Operating System: Linux flitzer 6.12.48-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri, 19 Sep 2025 16:11:04 +0000 x86_64
[    23.438] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=2f18b3d3-f2cb-4b1c-9f27-a3ee1aad6d7e rw rootflags=subvol=@ "quiet cryptdevice=UUID=d83e8b7c-63d2-4795-a2b5-79f16a21e7a7:luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7 root=/dev/mapper/luks-d83e8b7c-63d2-4795-a2b5-79f16a21e7a7 splash apparmor=1 security=apparmor resume=/dev/mapper/luks-2f5c30c0-b084-4f03-a882-69db91174e81 udev.log_priority=3"
[    23.438]
[    23.438] Current version of pixman: 0.46.4
[    23.438] 	Before reporting problems, check http://wiki.x.org
[    23.438] Markers: (--) probed, (**) from config file, (==) default setting,
[    23.438] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 23 12:09:05 2025
[    23.440] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    23.440] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    23.440] (==) No Layout section.  Using the first Screen section.
[    23.441] (==) No screen section available. Using defaults.
[    23.441] (**) |-->Screen "Default Screen Section" (0)
[    23.441] (**) |   |-->Monitor "<default monitor>"
[    23.441] (==) No monitor specified for screen "Default Screen Section".
[    23.441] (**) Allowing byte-swapped clients
[    23.441] (==) Automatically adding devices
[    23.441] (==) Automatically enabling devices
[    23.441] (==) Automatically adding GPU devices
[    23.441] (==) Automatically binding GPU devices
[    23.441] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    23.443] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    23.443] 	Entry deleted from font path.
[    23.443] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    23.443] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    23.443] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    23.443] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    23.443] (==) ModulePath set to "/usr/lib/xorg/modules"
[    23.443] (II) The server relies on udev to provide the list of input devices.
[    23.443] (II) Module ABI versions:
[    23.443] 	X.Org ANSI C Emulation: 0.4
[    23.443] 	X.Org Video Driver: 25.2
[    23.443] 	X.Org XInput driver : 24.4
[    23.443] 	X.Org Server Extension : 10.0
[    23.443] (++) using VT number 7
[    23.443] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    23.445] (II) xfree86: Adding drm device (/dev/dri/card1)
[    23.445] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:07:00.0/drm/card1
[    23.460] (--) PCI:*(7@0:0:0) 1002:1636:17aa:5081 rev 209, Mem @ 0x860000000/268435456, 0x870000000/2097152, 0xfd300000/524288, I/O @ 0x00001000/256
[    23.460] (II) LoadModule: "glx"
[    23.462] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    23.470] (II) Module glx: vendor="X.Org Foundation"
[    23.470] 	compiled for 1.21.1.18, module version = 1.0.0
[    23.470] 	ABI class: X.Org Server Extension, version 10.0
[    23.470] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[    23.470] 	loading driver: amdgpu
[    23.470] (==) Matched amdgpu as autoconfigured driver 0
[    23.470] (==) Matched ati as autoconfigured driver 1
[    23.470] (==) Matched modesetting as autoconfigured driver 2
[    23.470] (==) Matched fbdev as autoconfigured driver 3
[    23.470] (==) Matched vesa as autoconfigured driver 4
[    23.470] (==) Assigned the driver to the xf86ConfigLayout
[    23.470] (II) LoadModule: "amdgpu"
[    23.470] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    23.472] (II) Module amdgpu: vendor="X.Org Foundation"
[    23.472] 	compiled for 1.21.1.18, module version = 25.0.0
[    23.472] 	Module class: X.Org Video Driver
[    23.472] 	ABI class: X.Org Video Driver, version 25.2
[    23.472] (II) LoadModule: "ati"
[    23.473] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    23.473] (II) Module ati: vendor="X.Org Foundation"
[    23.473] 	compiled for 1.21.1.11, module version = 22.0.0
[    23.473] 	Module class: X.Org Video Driver
[    23.473] 	ABI class: X.Org Video Driver, version 25.2
[    23.485] (II) LoadModule: "modesetting"
[    23.485] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    23.487] (II) Module modesetting: vendor="X.Org Foundation"
[    23.487] 	compiled for 1.21.1.18, module version = 1.21.1
[    23.487] 	Module class: X.Org Video Driver
[    23.487] 	ABI class: X.Org Video Driver, version 25.2
[    23.487] (II) LoadModule: "fbdev"
[    23.488] (WW) Warning, couldn't open module fbdev
[    23.488] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    23.488] (II) LoadModule: "vesa"
[    23.488] (WW) Warning, couldn't open module vesa
[    23.488] (EE) Failed to load module "vesa" (module does not exist, 0)
[    23.488] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[    23.488] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    23.509] (WW) Falling back to old probe method for modesetting
[    23.509] (EE) open /dev/dri/card0: No such file or directory
[    23.509] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    23.509] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[    23.509] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    23.509] (==) AMDGPU(0): Default visual is TrueColor
[    23.509] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[    23.509] (==) AMDGPU(0): RGB weight 888
[    23.509] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[    23.509] (--) AMDGPU(0): Chipset: "AMD Radeon Graphics" (ChipID = 0x1636)
[    23.509] (II) Loading sub module "fb"
[    23.509] (II) LoadModule: "fb"
[    23.509] (II) Module "fb" already built-in
[    23.509] (II) Loading sub module "dri2"
[    23.509] (II) LoadModule: "dri2"
[    23.509] (II) Module "dri2" already built-in
[    23.792] (II) Loading sub module "glamoregl"
[    23.792] (II) LoadModule: "glamoregl"
[    23.793] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    23.798] (II) Module glamoregl: vendor="X.Org Foundation"
[    23.798] 	compiled for 1.21.1.18, module version = 1.0.1
[    23.798] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    23.824] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon Graphics (radeonsi, renoir, ACO, DRM 3.61, 6.12.48-1-MANJARO)
[    23.824] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[    23.824] (==) AMDGPU(0): TearFree property default: auto
[    23.824] (==) AMDGPU(0): VariableRefresh: disabled
[    23.824] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[    23.824] (II) AMDGPU(0): KMS Pageflipping: enabled
[    23.826] (II) AMDGPU(0): Output eDP has no monitor section
[    23.826] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[    23.826] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[    23.827] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[    23.855] (II) AMDGPU(0): EDID for output eDP
[    23.855] (II) AMDGPU(0): Manufacturer: IVO  Model: 57d  Serial#: 0
[    23.855] (II) AMDGPU(0): Year: 2020  Week: 0
[    23.855] (II) AMDGPU(0): EDID Version: 1.4
[    23.855] (II) AMDGPU(0): Digital Display Input
[    23.855] (II) AMDGPU(0): 6 bits per channel
[    23.855] (II) AMDGPU(0): Digital interface is DisplayPort
[    23.855] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 31  vert.: 17
[    23.855] (II) AMDGPU(0): Gamma: 2.20
[    23.855] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[    23.855] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[    23.855] (II) AMDGPU(0): First detailed timing is preferred mode
[    23.855] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[    23.855] (II) AMDGPU(0): Display is continuous-frequency
[    23.855] (II) AMDGPU(0): redX: 0.579 redY: 0.335   greenX: 0.329 greenY: 0.564
[    23.855] (II) AMDGPU(0): blueX: 0.154 blueY: 0.130   whiteX: 0.312 whiteY: 0.328
[    23.855] (II) AMDGPU(0): Manufacturer's mask: 0
[    23.855] (II) AMDGPU(0): Supported detailed timing:
[    23.855] (II) AMDGPU(0): clock: 138.8 MHz   Image Size:  309 x 174 mm
[    23.855] (II) AMDGPU(0): h_active: 1920  h_sync: 1944  h_sync_end 1992 h_blank_end 2080 h_border: 0
[    23.855] (II) AMDGPU(0): v_active: 1080  v_sync: 1083  v_sync_end 1095 v_blanking: 1112 v_border: 0
[    23.855] (II) AMDGPU(0): clock: 111.0 MHz   Image Size:  309 x 174 mm
[    23.855] (II) AMDGPU(0):  InfoVision
[    23.855] (II) AMDGPU(0):  R140NWF5 RG
[    23.855] (II) AMDGPU(0): EDID (in hex):
[    23.855] (II) AMDGPU(0): 	00ffffffffffff0026cf7d0500000000
[    23.855] (II) AMDGPU(0): 	001e0104951f1178e376909455549027
[    23.855] (II) AMDGPU(0): 	21505400000001010101010101010101
[    23.855] (II) AMDGPU(0): 	010101010101383680a0703820401830
[    23.855] (II) AMDGPU(0): 	3c0035ae100000195e2b80a070382040
[    23.855] (II) AMDGPU(0): 	18303c0035ae10000019000000fe0049
[    23.855] (II) AMDGPU(0): 	6e666f566973696f6e0a2020000000fe
[    23.855] (II) AMDGPU(0): 	00523134304e574635205247200a00e2
[    23.856] (II) AMDGPU(0): Printing probed modes for output eDP
[    23.856] (II) AMDGPU(0): Modeline "1920x1080"x60.0  138.80  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (66.7 kHz eP)
[    23.856] (II) AMDGPU(0): Modeline "1920x1080"x48.0  111.02  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (53.4 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1680x1050"x60.0  138.80  1680 1944 1992 2080  1050 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1280x1024"x60.0  138.80  1280 1944 1992 2080  1024 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1440x900"x60.0  138.80  1440 1944 1992 2080  900 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1280x800"x60.0  138.80  1280 1944 1992 2080  800 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1280x720"x60.0  138.80  1280 1944 1992 2080  720 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "1024x768"x60.0  138.80  1024 1944 1992 2080  768 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "800x600"x60.0  138.80  800 1944 1992 2080  600 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): Modeline "640x480"x60.0  138.80  640 1944 1992 2080  480 1083 1095 1112 -hsync -vsync (66.7 kHz e)
[    23.856] (II) AMDGPU(0): EDID for output HDMI-A-0
[    23.856] (II) AMDGPU(0): EDID for output DisplayPort-0
[    23.856] (II) AMDGPU(0): EDID for output DisplayPort-1
[    23.856] (II) AMDGPU(0): Output eDP connected
[    23.856] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[    23.856] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[    23.856] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[    23.856] (II) AMDGPU(0): Using exact sizes for initial modes
[    23.856] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[    23.856] (II) AMDGPU(0): mem size init: gart size :3d1b54000 vram size: s:1df68000 visible:1df68000
[    23.856] (==) AMDGPU(0): DPI set to (96, 96)
[    23.856] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[    23.856] (II) Loading sub module "ramdac"
[    23.856] (II) LoadModule: "ramdac"
[    23.856] (II) Module "ramdac" already built-in
[    23.856] (II) UnloadModule: "modesetting"
[    23.856] (II) Unloading modesetting
[    23.856] (II) AMDGPU(0): [DRI2] Setup complete
[    23.856] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[    23.856] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[    23.857] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[    23.857] (II) AMDGPU(0): SYNC extension fences enabled
[    23.857] (II) AMDGPU(0): Present extension enabled
[    23.857] (==) AMDGPU(0): DRI3 enabled
[    23.857] (==) AMDGPU(0): Backing store enabled
[    23.857] (II) AMDGPU(0): Direct rendering enabled
[    23.878] (II) AMDGPU(0): Use GLAMOR acceleration.
[    23.878] (II) AMDGPU(0): Acceleration enabled
[    23.878] (==) AMDGPU(0): DPMS enabled
[    23.878] (==) AMDGPU(0): Silken mouse enabled
[    23.878] (II) AMDGPU(0): Set up textured video (glamor)
[    23.886] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[    23.886] (II) Initializing extension Generic Event Extension
[    23.887] (II) Initializing extension SHAPE
[    23.887] (II) Initializing extension MIT-SHM
[    23.887] (II) Initializing extension XInputExtension
[    23.887] (II) Initializing extension XTEST
[    23.887] (II) Initializing extension BIG-REQUESTS
[    23.887] (II) Initializing extension SYNC
[    23.887] (II) Initializing extension XKEYBOARD
[    23.888] (II) Initializing extension XC-MISC
[    23.888] (II) Initializing extension SECURITY
[    23.888] (II) Initializing extension XFIXES
[    23.888] (II) Initializing extension RENDER
[    23.888] (II) Initializing extension RANDR
[    23.888] (II) Initializing extension COMPOSITE
[    23.888] (II) Initializing extension DAMAGE
[    23.888] (II) Initializing extension MIT-SCREEN-SAVER
[    23.889] (II) Initializing extension DOUBLE-BUFFER
[    23.889] (II) Initializing extension RECORD
[    23.889] (II) Initializing extension DPMS
[    23.889] (II) Initializing extension Present
[    23.889] (II) Initializing extension DRI3
[    23.889] (II) Initializing extension X-Resource
[    23.889] (II) Initializing extension XVideo
[    23.889] (II) Initializing extension XVideo-MotionCompensation
[    23.889] (II) Initializing extension GLX
[    23.902] (II) AIGLX: Loaded and initialized radeonsi
[    23.902] (II) GLX: Initialized DRI2 GL provider for screen 0
[    23.902] (II) Initializing extension XFree86-VidModeExtension
[    23.902] (II) Initializing extension XFree86-DGA
[    23.902] (II) Initializing extension XFree86-DRI
[    23.902] (II) Initializing extension DRI2
[    23.903] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[    24.005] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[    24.005] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    24.005] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    24.005] (**) Video Bus: Applying InputClass "system-keyboard"
[    24.005] (II) LoadModule: "libinput"
[    24.006] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    24.009] (II) Module libinput: vendor="X.Org Foundation"
[    24.009] 	compiled for 1.21.1.13, module version = 1.5.0
[    24.009] 	Module class: X.Org XInput Driver
[    24.009] 	ABI class: X.Org XInput driver, version 24.4
[    24.009] (II) Using input driver 'libinput' for 'Video Bus'
[    24.009] (**) Video Bus: always reports core events
[    24.009] (**) Option "Device" "/dev/input/event3"
[    24.012] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    24.012] (II) event3  - Video Bus: device is a keyboard
[    24.012] (II) event3  - Video Bus: device removed
[    24.077] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/LNXVIDEO:00/input/input3/event3"
[    24.077] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[    24.077] (**) Option "xkb_layout" "de"
[    24.077] (WW) Option "xkb_variant" requires a string value
[    24.116] (II) event3  - Video Bus: is tagged by udev as: Keyboard
[    24.116] (II) event3  - Video Bus: device is a keyboard
[    24.117] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    24.117] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    24.117] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    24.117] (**) Power Button: Applying InputClass "system-keyboard"
[    24.117] (II) Using input driver 'libinput' for 'Power Button'
[    24.117] (**) Power Button: always reports core events
[    24.117] (**) Option "Device" "/dev/input/event0"
[    24.119] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    24.119] (II) event0  - Power Button: device is a keyboard
[    24.119] (II) event0  - Power Button: device removed
[    24.157] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    24.157] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    24.157] (**) Option "xkb_layout" "de"
[    24.157] (WW) Option "xkb_variant" requires a string value
[    24.159] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    24.159] (II) event0  - Power Button: device is a keyboard
[    24.160] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[    24.160] (II) No input driver specified, ignoring this device.
[    24.160] (II) This device may have been added with another device file.
[    24.161] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[    24.161] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    24.161] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    24.161] (**) Sleep Button: Applying InputClass "system-keyboard"
[    24.161] (II) Using input driver 'libinput' for 'Sleep Button'
[    24.161] (**) Sleep Button: always reports core events
[    24.161] (**) Option "Device" "/dev/input/event2"
[    24.163] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[    24.163] (II) event2  - Sleep Button: device is a keyboard
[    24.163] (II) event2  - Sleep Button: device removed
[    24.203] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[    24.203] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[    24.203] (**) Option "xkb_layout" "de"
[    24.204] (WW) Option "xkb_variant" requires a string value
[    24.206] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[    24.206] (II) event2  - Sleep Button: device is a keyboard
[    24.208] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event8)
[    24.208] (II) No input driver specified, ignoring this device.
[    24.208] (II) This device may have been added with another device file.
[    24.209] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event6)
[    24.209] (II) No input driver specified, ignoring this device.
[    24.209] (II) This device may have been added with another device file.
[    24.209] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event7)
[    24.210] (II) No input driver specified, ignoring this device.
[    24.210] (II) This device may have been added with another device file.
[    24.210] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event9)
[    24.211] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event10)
[    24.211] (II) No input driver specified, ignoring this device.
[    24.211] (II) This device may have been added with another device file.
[    24.212] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    24.212] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    24.212] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    24.212] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    24.212] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    24.212] (**) AT Translated Set 2 keyboard: always reports core events
[    24.212] (**) Option "Device" "/dev/input/event4"
[    24.214] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    24.214] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    24.215] (II) event4  - AT Translated Set 2 keyboard: device removed
[    24.233] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    24.234] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
[    24.234] (**) Option "xkb_layout" "de"
[    24.234] (WW) Option "xkb_variant" requires a string value
[    24.236] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    24.236] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    24.238] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event11)
[    24.238] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    24.238] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[    24.238] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[    24.238] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    24.238] (**) Option "Device" "/dev/input/event11"
[    24.240] (II) event11 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    24.243] (II) event11 - SynPS/2 Synaptics TouchPad: device is a touchpad
[    24.244] (II) event11 - SynPS/2 Synaptics TouchPad: device removed
[    24.300] (II) libinput: SynPS/2 Synaptics TouchPad: Step value 0 was provided, libinput Fallback acceleration function is used.
[    24.301] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event11"
[    24.301] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 10)
[    24.304] (**) Option "AccelerationScheme" "none"
[    24.304] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    24.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    24.304] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    24.306] (II) event11 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    24.309] (II) event11 - SynPS/2 Synaptics TouchPad: device is a touchpad
[    24.311] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    24.311] (II) No input driver specified, ignoring this device.
[    24.311] (II) This device may have been added with another device file.
[    24.312] (II) config/udev: Adding input device TPPS/2 Elan TrackPoint (/dev/input/event12)
[    24.312] (**) TPPS/2 Elan TrackPoint: Applying InputClass "evdev pointer catchall"
[    24.312] (**) TPPS/2 Elan TrackPoint: Applying InputClass "libinput pointer catchall"
[    24.312] (II) Using input driver 'libinput' for 'TPPS/2 Elan TrackPoint'
[    24.312] (**) TPPS/2 Elan TrackPoint: always reports core events
[    24.312] (**) Option "Device" "/dev/input/event12"
[    24.314] (II) event12 - TPPS/2 Elan TrackPoint: is tagged by udev as: Mouse Pointingstick
[    24.315] (II) event12 - TPPS/2 Elan TrackPoint: device is a pointer
[    24.316] (II) event12 - TPPS/2 Elan TrackPoint: device removed
[    24.356] (II) libinput: TPPS/2 Elan TrackPoint: Step value 0 was provided, libinput Fallback acceleration function is used.
[    24.357] (II) libinput: TPPS/2 Elan TrackPoint: Step value 0 was provided, libinput Fallback acceleration function is used.
[    24.357] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input13/event12"
[    24.357] (II) XINPUT: Adding extended input device "TPPS/2 Elan TrackPoint" (type: MOUSE, id 11)
[    24.357] (**) Option "AccelerationScheme" "none"
[    24.357] (**) TPPS/2 Elan TrackPoint: (accel) selected scheme none/0
[    24.357] (**) TPPS/2 Elan TrackPoint: (accel) acceleration factor: 2.000
[    24.357] (**) TPPS/2 Elan TrackPoint: (accel) acceleration threshold: 4
[    24.360] (II) event12 - TPPS/2 Elan TrackPoint: is tagged by udev as: Mouse Pointingstick
[    24.360] (II) event12 - TPPS/2 Elan TrackPoint: device is a pointer
[    24.363] (II) config/udev: Adding input device TPPS/2 Elan TrackPoint (/dev/input/mouse1)
[    24.363] (II) No input driver specified, ignoring this device.
[    24.363] (II) This device may have been added with another device file.
[    24.369] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event5)
[    24.369] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[    24.369] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[    24.369] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[    24.369] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[    24.369] (**) ThinkPad Extra Buttons: always reports core events
[    24.369] (**) Option "Device" "/dev/input/event5"
[    24.370] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[    24.370] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[    24.371] (II) event5  - ThinkPad Extra Buttons: device removed
[    24.407] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input5/event5"
[    24.407] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 12)
[    24.407] (**) Option "xkb_layout" "de"
[    24.407] (WW) Option "xkb_variant" requires a string value
[    24.409] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[    24.409] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[    59.237] (II) AMDGPU(0): EDID vendor "IVO", prod id 1405
[    59.237] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    59.238] (II) AMDGPU(0): Modeline "1920x1080"x0.0  138.80  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (66.7 kHz eP)
[    59.238] (II) AMDGPU(0): Modeline "1920x1080"x0.0  111.02  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (53.4 kHz e)
[    59.242] (II) AMDGPU(0): EDID vendor "IVO", prod id 1405
[    59.242] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    59.242] (II) AMDGPU(0): Modeline "1920x1080"x0.0  138.80  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (66.7 kHz eP)
[    59.242] (II) AMDGPU(0): Modeline "1920x1080"x0.0  111.02  1920 1944 1992 2080  1080 1083 1095 1112 -hsync -vsync (53.4 kHz e)
[    59.293] (WW) AMDGPU(0): flip queue failed: Invalid argument
(... more Modelines ...)
If touchpad has been disabled accidentally it can be re-enabled in xfce4-mouse-settings
xfce:xfce4-settings:mouse [Xfce Docs]
Hi @Mirdarthos,
here is lsusb:
lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 002: ID 04f2:b6d0 Chicony Electronics Co., Ltd Integrated Camera
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
And here is inxi -ev8:
  Host: flitzer Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1 clocksource: hpet avail: acpi_pm
    "quiet
    base: Arch Linux
    serial: PF2HGR4F Chassis: type: 10 serial: PF2HGR4F
  Mobo: LENOVO model: 20UES3YA01 v: SDK0J40697 WIN serial: L1HF0CL0173
    date: 06/17/2021
  ID-1: BAT0 charge: 32.1 Wh (62.3%) condition: 51.5/50.5 Wh (101.9%)
    power: 9.3 W volts: 11.35 min: 11.55 model: LGC 5B10W139 type: Li-poly
    serial: 5297 charging: status: discharging control: start: 95% end: 100%
    cycles: 365
  System RAM: total: 32 GiB available: 30.58 GiB used: 2.2 GiB (7.2%)
    part-no: HMA82GS6DJR8N-XN serial: 2280B603
    bus-ID: 00:00.0
    bus-ID: 00:00.0
    bus-ID: 00:00.0
    xsaveopt xtopology
    protection
    class-ID: fe01 serial: 0001
    screens: 1
  IF: enp2s0f0 state: down mac: 8c:8c:aa:58:09:8c
  IF: wlp3s0 state: up mac: e0:d4:64:54:c7:2a
  IP v4: 192.168.178.51/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.178.255
  IP v6: 2a04:4540:802:5c00:4689:19c0:6e51:8439/64
  IP v6: fe80::6bcd:3d0a:a5ab:537/64 type: noprefixroute scope: link
  IF: enp5s0 state: down mac: 8c:8c:aa:58:09:8b
  WAN IP: 46.59.206.60
    class-ID: e001
  Components:
  Components:
    tech: SSD serial: 0x46900f1f scheme: MBR
    lanes: 4 tech: SSD serial: CJA3N82211100441E fw-rev: 41730C20 temp: 41.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 302d 22h cycles: 69,852
    read-units: 31,178,473 [15.9 TB] written-units: 26,482,057 [13.5 TB]
    uuid: CBD3-6116
    serial: 0001
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
    pkgs: 10
Processes:
  CPU top: 5 of 417
  1: cpu: 200% command: ps pid: 4745 mem: 4.09 MiB (0.0%)
  2: cpu: 8.0% command: firefox pid: 1777 mem: 587.2 MiB (1.8%)
  3: cpu: 6.7% command: firefox pid: 2256 mem: 383.2 MiB (1.2%)
  4: cpu: 2.8% command: Xorg pid: 1155 mem: 95.4 MiB (0.3%)
  5: cpu: 1.4% command: firefox pid: 2021 mem: 334.8 MiB (1.0%)
  Memory top: 5 of 417
  1: mem: 587.2 MiB (1.8%) command: firefox pid: 1777 cpu: 8.0%
  2: mem: 383.2 MiB (1.2%) command: firefox pid: 2256 cpu: 6.7%
  3: mem: 334.8 MiB (1.0%) command: firefox pid: 2021 cpu: 1.4%
  4: mem: 249.5 MiB (0.7%) command: firefox pid: 2014 cpu: 0.4%
  5: mem: 246.1 MiB (0.7%) command: firefox pid: 1947 cpu: 0.4%
  Processes: 417 Power: uptime: 1h 19m states: freeze,mem,disk suspend: s2idle
It doesn’t seem listed in either lsusb nor inxi output. Have you tested in a Live environment, perhaps?
X11 or Wayland?
X11 (checked via loginctl).
xfce4-mouse-settingsshow both trackpoint AND touchpad as enabled (via the slider).
A live usb is a very good idea. To be sure it is not a hardware problem.
So what did you do today ?
grep -e '2025-11-23' /var/log/pacman.log
[2025-11-22T21:12:48+0100] [PAMAC] synchronizing package lists
[2025-11-23T11:29:45+0100] [PAMAC] synchronizing package lists
[2025-11-23T11:44:27+0100] [PACMAN] Running 'pacman -Syu'
[2025-11-23T11:44:27+0100] [PACMAN] synchronizing package lists
[2025-11-23T11:44:28+0100] [PACMAN] starting full system upgrade
[2025-11-23T11:50:43+0100] [PAMAC] synchronizing package lists
[2025-11-23T11:50:47+0100] [ALPM] transaction started
[2025-11-23T11:50:47+0100] [ALPM] installed xorg-xinput (1.6.4-2)
[2025-11-23T11:50:47+0100] [ALPM] transaction completed
[2025-11-23T11:50:47+0100] [ALPM] running '30-systemd-update.hook'...
I added yesterday, just to be sure…
I installed xinput to create some insight after the problem arose.
If it didn’t change anything - you should remove it.
As you say it has become an issue overnight - so to speak - I it could be an error in one of the xfce xml configuration files.
I am not super familiar with xfce so I don’t know specifically which configurations apply.
In my experience a normal functional system does not loose trackpad overnight.
Something must have caused it - you just have to retrace your steps - the package pacmanlogviewer is a great tool for filtering the log - much better than my amateurish grep.
Why did you install xorg input?
Your bios:
LENOVO v: R1BET65W (Version 1.34 ) date: 06/17/2021
LVFS result:
Lenovo (ThinkPad) ThinkPad T14/P14s Gen 1 AMD
Lenovo ThinkPad T14/P14s Gen 1 AMD System Firmware R1BET83W, Version 1.52
lenovo support:
T14 Gen 1 (type 20UD, 20UE) Laptop (ThinkPad) - Type 20UE
BIOS Update (Bootable CD) 46.36 MB Version 1.53 06 Nov 2025
More info:
Is fwupd or gnome-firmware installed? - if not, do it. It is in manjaro repos.
info:
Lenovo thinkpads have longtime firmware support. Why don’t you take advantage of it? That’s why people buy thinkpads and pay the extra.
Thank you, @banjo for your recommendation of upgrading the firmware.
Of course, this cannot be the root cause of the problem, but it solved it for me.
Thank you, @linux-aarhus for your recommendation of pacmanlogviewer.
With this tool (of course I could have used the log file itself) I found, that I installed some firmware days ago (to get rid of warnings during boot). Presumably I did not boot right after the install.
So the problem showed up late.
And that is a good root cause for the problem, that was solved by upgrading the firmware.
I installed xorg-input to check, if the touchpad is recognised by X11.
