My synaptics touchpad began malfunctioning while using LibreOfficeWriter- and after closing the pointer would only go across top of screen in a jerky pattern. After rebooting the touchpad no longer works.
My keyboard after reeboot is not like it was- (stutters, skips, double types, puts in extra spaces) since the update.
I had before this a sound issue that seemed to resolve.
//**NEW EDIT. after posting the touchpad regained function for no apparent reason. Later same day, using LibreOffice Writer again after about 1/2 hour, the touchpad became unresponsive, again. By the time I used journalctl command in a terminal, the touchpad came back. My backup mouse was still plugged in. It was not during the first event. Journalctrl returned info (error?) Synaptic that I’ve pasted in a separate post below //
Linux nobody-IC3LAF 5.16.5-1-MANJARO #1 SMP PREEMPT Tue Feb 1 16:57:14 UTC 2022 x86_64 GNU/Linux
Host: nobody-IC3LAF Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel
wm: xfwm 4.16.1 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion g7 Notebook PC
v: 058F100014204610000620100 serial: CNF112C9VW Chassis: type: 10
serial: N/A
Mobo: Hewlett-Packard model: 166A v: 08.38 serial: PBVEE111Z07RM7
BIOS: Insyde v: F.63 date: 03/22/2012
Info: dual core model: Intel Core i3 M 380 bits: 64 type: MT MCP
smt: enabled arch: Westmere rev: 5 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1333 high: 2533 min/max: 933/2533 volts: 0.0 V
ext-clock: 1066 MHz cores: 1: 2533 2: 933 3: 933 4: 933 bogomips: 20231
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Core Processor Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Chicony HP Webcam-101 type: USB driver: uvcvideo bus-ID: 2-1.5:4
chip-ID: 04f2:b293 class-ID: 0e02 serial: SN0001
Display: server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa resolution: 1600x900~60Hz
s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.3.5
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter vendor: Hewlett-Packard
driver: rtl8192ce v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8176
class-ID: 0280
IF: wlo1 state: up mac: 20:10:7a:09:ea:2c
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:8136 class-ID: 0200
IF: eno1 state: down mac: 98:4b:e1:c5:c7:42
Local Storage: total: 465.76 GiB used: 14.85 GiB (3.2%)
ID-1: /dev/sda vendor: Western Digital model: WD5000BPKX-22HPJT0
size: 465.76 GiB speed: 3.0 Gb/s type: HDD rpm: 7200 serial: WD-WXM1E14SJMD8
rev: 1A01 scheme: MBR
ID-1: / size: 449.5 GiB used: 14.85 GiB (3.3%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8 GiB used: 524 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 196 Uptime: 1h 40m wakeups: 1 Memory: 3.63 GiB
used: 2.58 GiB (71.0%) Init: systemd v: 250 Compilers: gcc: 11.1.0
clang: 13.0.0 Packages: pacman: 1291 Shell: Bash (sudo) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.12
