Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ade649ba-48e8-4bd1-9e1c-7878c6f77246 rw quiet mitigations=off
nowatchdog pci=noaer cpufreq.default_governor=performance apparmor=1
security=apparmor udev.log_priority=3 acpi_osi=! acpi_osi=Linux
"acpi_osi=Windows 2009" nogpumanager i915.enable_gvt=1 pcie_port_pm=off
iommu=1 intel_iommu=on kvm.ignore_msrs=1 rd.driver.pre=vfio-pci
default_hugepagesz=1G hugepagesz=1G hugepages=0 transparent_hugepage=never
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GE75 Raider 8SE v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-17E2 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17E2IMS.10E date: 03/28/2019
ID-1: BAT1 charge: 41.7 Wh (95.9%) condition: 43.5/53.4 Wh (81.4%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Unknown
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.2 GiB used: 5.66 GiB (18.1%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 4077 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4077 2: 4094
3: 4101 4: 4048 5: 4100 6: 4050 7: 3990 8: 4057 9: 4100 10: 4101 11: 4090
12: 4099
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: N/A bus-ID: 1-13:5
chip-ID: 5986:211c class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 144 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel port: 6000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus-ID: 05:00.0
chip-ID: 1969:e0b1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
IF-ID-1: nordlynx state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
Local Storage: total: 2.07 TiB used: 1.31 TiB (63.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3256GJ
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: E8FK11.C temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: KingSpec model: ACSC4M1TS25
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4H scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 137.84 GiB (59.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ade649ba-48e8-4bd1-9e1c-7878c6f77246
label: NO_LABEL uuid: B822-64D2
ID-3: /run/media/rabcor/KingSpec raw-size: 953.87 GiB
size: 953.4 GiB (99.95%) used: 582.31 GiB (61.1%) fs: xfs dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: 7081018e-cce8-4d7d-b093-bb681ff46b8e
ID-4: /run/media/rabcor/WD raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 617.38 GiB (66.3%) fs: f2fs dev: /dev/sda1 maj-min: 8:1
label: Western Digital uuid: ae81d12d-6838-4833-b47b-8dd120364382
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-9:4 info: SteelSeries ApS SteelSeries KLC type: HID
power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-4: 1-13:5 info: Acer HD Webcam type: Video driver: N/A interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 368 Uptime: 1d 2h 16m wakeups: 20 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1471
lib: 422 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
I am having an issue where if I use two finger scrolling to scroll, sometimes when I accidentally tap the touchpad with a third finger (this is not consistent, e.g. only happens sometimes, not always) the scrolling jerks/jumps back to where I initially started scrolling.
This is quite infuriating since it makes me lose track of which line I was reading.
I have no idea why it does this, I’m not using any gestures, nor do I even have any package for that installed.
The laptop is identified by xinput as:
SynPS/2 Synaptics TouchPad
However it used to (~2 years ago last I checked) be identified by xinput as:
CUST0001:00 06CB:CDA1 Touchpad
The driver I am using for it is libinput (default). I do not remember if I had this issue or not last time I used linux on this laptop around 2 years ago.
