I recently installed Manjaro/xfce. Everything is fine but I noticed that my touchpad pad area does not work with single or double clicks and I have to press physical buttons to select anything.
Scrolling functions fine with touchpad.(DEVICE NAME - MSFT0001:01 04F3:3140 Touchpad)
I have installed manjaro on dual boot with windows 10 and latter has no such problems after installation of manjaro.
I am complete noob with Linux so I don’t know any config settings. Is there any? PLEASE HELP ME OUT…
Sorry for the delay,
Regarding more info, I don’t think I have any on this issue, my problem is just that how a normal touchpad works like you place a cursor on the buttons like ‘x’ , minimize or on icons you single tap on pad for single click or double tap for double click to access folders,files etc. – this way mine is not working.
Buttons at the bottom of touchpad only works - press on bottom left corner for selection and on bottom right corner for additional options.
Scrolling works by sliding using two fingers.
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d5ea4842-047b-4305-9d4a-cc0fec20439f rw quiet apparmor=1
security=apparmor resume=UUID=7f4c6e39-3084-4489-9bef-64f11c9bcb05
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82FG v: IdeaPad 5 15ITL05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ITL05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> UEFI: LENOVO v: FHCN59WW date: 08/26/2021
ID-1: BAT0 charge: 25.1 Wh (50.0%) condition: 50.2/57.0 Wh (88.1%)
volts: 12.2 min: 11.5 model: Celxpert L19C3PF5 type: Li-poly
serial: <filter> status: charging cycles: 370
RAM: total: 7.55 GiB used: 1.66 GiB (22.0%)
RAM Report:
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 810 high: 1148 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 580 2: 906 3: 1101
4: 1148 5: 686 6: 769 7: 736 8: 554 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-5:3 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x08e2 built: 2019 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.14 TiB used: 26.39 GiB (2.3%)
model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: GPT
ID-1: / raw-size: 276.85 GiB size: 271.44 GiB (98.05%)
used: 26.39 GiB (9.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: d5ea4842-047b-4305-9d4a-cc0fec20439f
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: NO_LABEL
uuid: E58C-5E87
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 7f4c6e39-3084-4489-9bef-64f11c9bcb05
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 3230-4120
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 237.23 GiB fs: bitlocker
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: F420313620310162
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 638.53 GiB fs: ntfs
label: MISCELLANEOUS uuid: 4EFA054DFA05332F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 3-5:3 info: IMC Networks Integrated Camera type: Video
Device-3: 3-7:4 info: Shenzhen Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a2 class-ID: ef00
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 245 Uptime: 6m wakeups: 161 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1098 lib: 318
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.14
