Touchpad not recognized
My touchpad stopped working. I get this message right after listing the devices from libinput:
event9 - PIXA3848:00 093A:3848 Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.28.0/clickpad-with-right-button.html for details
libinput info:
Device: PIXA3848:00 093A:3848 Touchpad
Kernel: /dev/input/event9
Group: 7
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap button map: left/right/middle
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Scroll button: n/a
Scroll button lock: n/a
Click methods: *button-areas clickfinger
Clickfinger button map: left/right/middle
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles: flat *adaptive custom
Rotation: n/a
Area rectangle: n/a
inxi
inxi -F         ✔
  Host: rabii Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.3 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Nitro ANV15-51 v: V1.14
    serial: <superuser required>
  Mobo: RPL model: Sportage_RTH v: V1.14 serial: <superuser required>
    UEFI: INSYDE v: 1.14 date: 06/21/2024
  ID-1: BAT1 charge: 32.8 Wh (65.1%) condition: 50.4/57.5 Wh (87.7%)
  Info: 10-core (6-mt/4-st) model: 13th Gen Intel Core i7-13620H bits: 64
    type: MST AMCP cache: L2: 9.5 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:4900:3600 cores: 1: 400 2: 400
    3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
    13: 400 14: 400 15: 400 16: 400
  Device-1: Intel Raptor Lake-P [UHD Graphics] driver: i915 v: kernel
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] driver: nvidia
    v: 570.133.07
  Device-3: Quanta ACER HD User Facing driver: uvcvideo type: USB
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915 resolution: 1: 1920x1080~144Hz 2: 1920x1080~144Hz
  API: EGL v: 1.5 drivers: iris,nvidia
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 25.0.2-arch1.2
    renderer: Mesa Intel Graphics (RPL-P)
  API: Vulkan v: 1.4.309 drivers: N/A surfaces: xcb,xlib,wayland
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Raptor Lake-P/U/H cAVS driver: sof-audio-pci-intel-tgl
  Device-2: NVIDIA AD107 High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.1 status: active
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF: wlp62s0 state: up mac: c0:35:32:a7:67:2d
    driver: r8168
  IF: enp63s0 state: down mac: 0c:cc:47:ea:db:c3
  Device-1: Lite-On Wireless_Device driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: C0:35:32:A7:67:2E bt-v: 5.2
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd
  Local Storage: total: 1.38 TiB used: 1.18 TiB (85.7%)
  ID-1: /dev/nvme0n1 vendor: Silicon Motion model: SM2P41C8-512GC1
  ID-2: /dev/nvme1n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
  ID-1: / size: 451.49 GiB used: 297.77 GiB (66.0%) fs: ext4 dev: /dev/dm-0
  ID-2: /boot/efi size: 299.4 MiB used: 448 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
    dev: /dev/dm-1
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.33 GiB used: 7.95 GiB (51.8%)
  Processes: 383 Uptime: 13m Shell: Zsh inxi: 3.3.37
I’d suggest trying another kernel, if you haven’t already. I have (had) issues with my Lenovo trackpads with various kernel series/revisions. It seems this also affects other brands.
Ones to try: linux66 (LTS), linux613, linux614 (both HWE) — I recommend keeping at least one other kernel on your system other than the one you are actually using.
There is, of course, also a possibility of a hardware fault.
I was using 6.12 LTS and tried 6.14… none works… :confused:
Do you still have the .ISO you installed from? If so, I guess that’s the next thing to try (as, presumably, it was working OK with that).
There is a command I sometimes need to use following a sleep/wake cycle (only the first one following a fresh boot):
sudo modprobe -r psmouse && sudo modprobe -a psmouse
… which might work with your setup.
In my case, the trackpad is unresponsive on the first “wake” and the machine won’t go back to sleep until I issue the above.
N.B. I also have a habit of keeping a USB mouse or trackpad in my backpack, in case of issues.
