When running Wayland on KDE, my laptop (Dell G7 7588) doesn’t properly recognize the touchpad. It’s still usable, but most features don’t work (including, but not limited to, tap to click). This error doesn’t happen when running an X11 session. If I go to the Touchpad settings in System Settings, there is a red error message that says “No touchpad found”.
I have tried the solution here found here, but it didn’t resolve the issue.
Adding this edit a year after the fact because the moderator response and self-selected “solution” still doesn’t sit well with me–
The response of “file the bug in the correct place, and if you don’t know how, get bent” is incredibly frustrating. Behavior like this in this forum is a big reason why I no longer recommend Manjaro to people. If you had linked the KDE bug tracker, the condescending tone could’ve been somewhat excusable as I could have gone and filed the bug in the correct place and talked with more professional individuals.
I certainly could’ve just intuited where I needed to go (which I incorrectly, but understandably, assumed would be the KDE GitHub issue board), but that kind of defeats the purpose of asking questions, doesn’t it?
