Manjaro has been installed for about 3 weeks now, without many issues.
A few days ago i noticed that after i login, when i try to launch an application or open the network manager, the entire taskbar freezes for up to 2 minutes. Then, everything pops up at once. The application i opened, the network manager, everything i clicked on. From then on, it generally acts fine until the next time I reboot.
I set the system monitor to open on startup so i could see any resource spikes when this happens, but both RAM and CPU usage remain normal, and well below max.
Also, sometimes when i open an application, It immediately stops responding and i either have to completely kill it or wait 2 minutes just like on startup. I suspect this is related.
EDIT: I’ve noticed that when these hang-ups happen, all resource actually grinds to a halt, instead of increasing like you’d usually expect. Then it spikes once everything starts up again INCLUDING network usage! Last time time my system froze, i was waiting on a search on DuckDuckGo to load, even though this would usually be almost instant. The more i learn about this issue, the less sense it makes.
I have no idea what’s causing this, especially since my RAM and CPU usage don’t spike at all during these incidents, and i haven’t had any issues for the first 2 weeks of usage.
Below is my system info:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8cd23690-313c-45a8-8b09-0485563f506f rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 3003 date: 12/09/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
status: Discharging
RAM: total: 15.55 GiB used: 2.9 GiB (18.7%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 3 MiB bogomips: 86425
Speed: 3600 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3600 2: 2052 3: 2198 4: 2200 5: 2053 6: 2200 7: 2132 8: 2798 9: 3590
10: 2055 11: 2056 12: 2895
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:731f
class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1353x380mm (53.3x15.0")
s-diag: 1405mm (55.3")
Monitor-1: DisplayPort-0 res: 5120x1440 dpi: 109
size: 1190x340mm (46.9x13.4") diag: 1238mm (48.7")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.41.0 5.13.19-2-MANJARO
LLVM 12.0.1)
v: 4.6 Mesa 21.3.0-devel (git-b61e9345c1) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Edimax EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
type: USB driver: rtl8192cu bus-ID: 1-4:2 chip-ID: 7392:7811 class-ID: 0000
serial: <filter>
IF: wlp1s0f0u4 state: down mac: <filter>
IF-ID-1: enp1s0f0u5 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 1-5:6 chip-ID: 04e8:6864
class-ID: 0a00 serial: <filter>
Device-2: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-6:4 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 1.14 TiB used: 268.61 GiB (23.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 126.05 GiB (55.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 8cd23690-313c-45a8-8b09-0485563f506f
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: A3BC-2F9D
ID-3: /mnt raw-size: 839.34 GiB size: 825.09 GiB (98.30%)
used: 142.56 GiB (17.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: 2 - Games uuid: ce65ad4f-499c-4e56-bcba-9f4c6d881884
Device-1: 1-4:2
info: Edimax EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
type: Network driver: rtl8192cu interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 7392:7811 class-ID: 0000 serial: <filter>
Device-2: 1-5:6
info: Samsung GT-I9070 (network tethering USB debugging enabled)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 3 rev: 2.1
speed: 480 Mb/s power: 64mA chip-ID: 04e8:6864 class-ID: 0a00
serial: <filter>
Device-3: 1-6:4 info: ASUSTek Broadcom BCM20702A0 Bluetooth type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 525
Processes: 345 Uptime: 7m wakeups: 4 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1488 pacman: 1473 lib: 406
flatpak: 6 snap: 9 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
