Oracle VB was working until Nov 2021 in Xfce. I have not used VB again until I tried yesterday. It would not launch.
I update Manjaro regularly before launching the program. The current updated kernel version is 4.19.252-3.
I wonder if this is the reason VB has stopped working? This version I think is not supported now.
And why this old kernel when I do an update now?
Thanks!
that number does not look like a kernel version - more like the version of the virtualbox modules
not sure - did not investigate
perhaps consciously, intentionally, install a more recent kernel
and make sure to also install the virtualbox kernel modules for that kernel version
Kernels will get updated within a particular version
but never will they be replaced by more recent ones
without your interaction
JoHubb:
We’re going to need more details than that.
Please see [HowTo] Make support easier
JoHubb:
this old kernel
4.19 is an LTS (Long Term Support) kernel and you have the latest version available from the Manjaro stable branch.
Have you tried any other kernels like 5.4, 5.10, 5.15 or 5.18?
No, it didn’t. I’ve decrypted it for you and edited the post.
Thanks for advice.
By ‘not launching’ I mean that when I try to open the application from the menu, nothing happens, nothing at all. It is as though the application was not there.
JoHubb:
Thanks!
Thanks for your help. But I am running into lots of other problems.
The Manjaro Settings Manager does not open. When I try to open it from the menu, nothing happens. It is as though the menu entry is not there. So, I cannot find a source for newer kernels.
Same applies to Qt5 settings - nothing happens which I try to open it. The same may apply to other applications. I did not check them all.
On the VB, I took a screenshot of the entry in the file manager but I cannot find a way of posting it here.
Sorry, if I missed something obvious.
Olli
29 July 2022 09:08
5
Thanks.
[howard@Lyra ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 4.19.252-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=bb8bf78e-d283-448b-b815-c7f00a4edbef rw acpi_osi=Linux
acpi_backlight=vendor quiet
resume=UUID=dac08ddf-cc6d-4827-a355-6d1a84d429ca
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Apple product: MacBookPro6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F22586C8
Mobo: Apple model: Mac-F22586C8 v: MacBookPro6,2
serial: <superuser required> UEFI: Apple v: MBP61.88Z.0057.B17.1702241225
date: 02/24/17
ID-1: BAT0 charge: 56.0 Wh (96.6%) condition: 58.0/69.0 Wh (84.1%)
volts: 12.4 min: 10.9 model: SMPNz451 bq20z451 type: Unknown serial: N/A
status: N/A
Device-1: hid-00:1f:20:e1:a9:cb-battery model: Bluetooth Mouse M557
serial: N/A charge: N/A status: discharging
RAM: total: 7.72 GiB used: 1.32 GiB (17.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Westmere
gen: core 1 built: 2010-11 process: Intel 32nm family: 6 model-id: 0x25 (37)
stepping: 5 microcode: 0x7
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1437 high: 1463 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1463 2: 1423
3: 1437 4: 1428 bogomips: 21278
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdtscp sep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
arch: Gen-5.75 process: Intel 45nm built: 2010 ports: active: none
off: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0046
class-ID: 0300
Device-2: NVIDIA GT216M [GeForce GT 330M] vendor: Apple driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-13 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: LVDS-2 empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:0a29
class-ID: 0300
Device-3: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-1.1:3
chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915,nouveau
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-size: <missing: xdpyinfo>
Monitor-1: LVDS-1 mapped: LVDS-1-1 note: disabled model: Apple Color LCD
built: 2009 res: N/A dpi: 129 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: 1680x1050
Monitor-2: LVDS-2 pos: primary model: Apple Color LCD built: 2009
res: 1680x1050 hz: 60 dpi: 129 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: max: 1680x1050 min: 640x350
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: NVIDIA GT216 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0be2
class-ID: 0403
Sound Server-1: ALSA v: k4.19.252-3-MANJARO running: yes
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: 3.137 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:1684 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:4353 class-ID: 0280
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:9 chip-ID: 05ac:8218 class-ID: fe01
Local Storage: total: 988.84 GiB used: 372.29 GiB (37.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 020 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade
size: 57.33 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-R UJ-898 rev: HC10
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 115.87 GiB
(12.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: bb8bf78e-d283-448b-b815-c7f00a4edbef
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 264 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: E733-32D6
ID-3: /home/<filter>/TresoritDrive raw-size: N/A size: 3.91 TiB used: 256.43
GiB (6.4%) fs: fuse.tresoritfs source: ERR-102
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: dac08ddf-cc6d-4827-a355-6d1a84d429ca
ID-1: /dev/sdb1 maj-min: 8:17 size: 2 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 3.9 MiB fs: vfat label: N/A
uuid: C26E-047E
ID-3: /dev/sdb3 maj-min: 8:19 size: 55.33 GiB fs: ext4 label: writable
uuid: 825d3ca3-48d4-4199-8741-6d39bf95e321
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
Hub-3: 1-1.1:3 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
Device-1: 1-1.1.3:9 info: Apple Bluetooth Host Controller type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8218
class-ID: fe01
Device-2: 1-1.2:4 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0237 class-ID: 0301
Device-3: 1-1.3:6 info: Apple Internal Memory Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05ac:8403 class-ID: 0806
serial: <filter>
Device-4: 1-1.4:8 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: Full speed or root hub ports: 8 rev: 2.0
Hub-5: 2-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 3 rev: 2.0
Device-1: 2-1.1:3 info: Apple Built-in iSight type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05ac:8507
Device-2: 2-1.2:4 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
Device-3: 2-1.3:5 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 65.0 C mobo: N/A gpu: nouveau temp: 61.0 C
Processes: 185 Uptime: 4h 33m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1374 lib: 454 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.20
[howard@Lyra ~]$
Looks like I’m on my own on this one! Thanks anyway.
