Before the recent update, I was using the touchpad toggler in tray, with the recent update it has disappeared and I cannot even recall if it was added as standard or a 3rd party widget (couldn’t find anything).
i have same problem, after update, touch pad icon in tray gone!
now i use shortcut to toggle on or off touchpad
Seems KDE guys decided on this because certain less capable individuals disabled their touchpads from tray and couldn’t figure out how to restart their machines to re-enable it.
