imgur com/a/Sy8etgX
When I start up my pc only my leftmost screen starts up and then is glitchy as shown in the video linked above. So when I start my pc I have to go to the settings and change the display settings to have all three monitors on, and even that doesn’t work flawlessly as shown. To get my third monitor to work I have to Enable it, disable it, and then enable it again for it to work “properly”. After that there is still an pixel thick line bleeding over to the monitor next that I have to fix by moving the screen in the settings menu and then move back.
[krister@krister ~]$ inxi --admin --verbosity=7 --filter --no-host --width
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_ADDRESS = "sv_SE.UTF-8",
LC_NAME = "sv_SE.UTF-8",
LC_MONETARY = "sv_SE.UTF-8",
LC_PAPER = "sv_SE.UTF-8",
LC_IDENTIFICATION = "sv_SE.UTF-8",
LC_TELEPHONE = "sv_SE.UTF-8",
LC_MEASUREMENT = "C",
LC_TIME = "en_SE.UTF-8",
LC_NUMERIC = "sv_SE.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=71b17009-2745-4548-924a-04bd1ffc62f8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <superuser required>
UEFI: American Megatrends v: P3.70 date: 11/14/2019
ID-1: hidpp_battery_0 charge: 12% condition: N/A volts: 3.7 min: N/A
model: Logitech G403 Prodigy Wired/Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
RAM: total: 15.55 GiB used: 8.36 GiB (53.8%)
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2640 high: 3984 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2376 2: 2056
3: 2484 4: 3032 5: 3713 6: 2071 7: 2777 8: 2055 9: 2153 10: 3984 11: 2908
12: 2078 bogomips: 86277
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 7040x1440 s-dpi: 94 s-size: 1903x389mm (74.92x15.31")
s-diag: 1942mm (76.47")
Monitor-1: DP-1 pos: bottom-l res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: DP-2 pos: primary,top-center res: 2560x1440 hz: 144 dpi: 93
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
Monitor-3: DP-4 pos: top-right res: 2560x1440 hz: 60 dpi: 109
size: 596x335mm (23.46x13.19") diag: 684mm (26.92") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-5:4 v: kernel chip-ID: 1038:12ad pcie: gen: 3
class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 678.14 GiB (58.2%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
type: HDD rpm: 7200 serial: <filter> rev: A7L0 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS DVD model: RAM GHB1N rev: AS00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 151.04 GiB (66.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 71b17009-2745-4548-924a-04bd1ffc62f8
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: BAF2-52A0
ID-3: /mnt/sda1 raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 527.1 GiB (56.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 87e90b2f-ae1b-4f4b-a899-098f8546068c
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-2:3 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-5:4 info: SteelSeries ApS Arctis 7 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:12ad class-ID: 0300
Device-3: 1-6:5 info: Microsoft Xbox One Controller type: <vendor specific>
driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:02d1 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: JosefAdamcik Sofle type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: fc32:0287 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 314 Uptime: 1h 13m wakeups: 6 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1646 pm: pacman pkgs: 1612 libs: 461 tools: pamac,yay pm: flatpak
pkgs: 34 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.24
