Touchpad Click Configuration
I can't seem to configure double-finger or triple-finger clicks on the XFCE edition like I could so eaily on the Gnome edition through an easy-to-use GUI. I can use double-finger scroll though. My only option is using bottom left as left click, bottom middle as middle click and bottom right as right click..
I've tried installing xf86-input-synaptics and editing the X11 config file as per synaptics usage page, but that caused my system to hang where I had to TTY2 and delete the file and remove synaptics (then my system was back to normal).
XFCE is great! But I feel they've missed the boat on some user-friendly setting options.
What does cat /etc/X11/xorg.conf.d/* tell you?
Blockquote
Read and parsed by systemd-localed. It's probably wise not to edit this file
manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
Option "XkbModel" "pc105"
EndSection
Generated by mhwd - Manjaro Hardware Detection
Section "Device"
Identifier "Device0"
Driver "intel"
BusID "PCI:0:2:0"
Option "AccelMethod" "sna"
Option "DRI" "true"
EndSection
Section "DRI"
Group "video"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Blockquote
Ok, that is what I expected. Please write a file called 30-touchpad.conf with the following content in /etc/X11/xorg.conf.d/:
    Identifier "touchpad"
    Driver "synaptics"
    MatchIsTouchpad "on"
    Option "TapButton1" "1"
    Option "TapButton2" "3"
    Option "TapButton3" "2"
    Option "VertEdgeScroll" "on"
    Option "VertTwoFingerScroll" "on"
    Option "HorizEdgeScroll" "on"
    Option "HorizTwoFingerScroll" "on"
    Option "CircularScrolling" "on"
    Option "CircScrollTrigger" "2"
    Option "EmulateTwoFingerMinZ" "40"
    Option "EmulateTwoFingerMinW" "8"
    Option "CoastingSpeed" "0"
    Option "FingerLow" "30"
    Option "FingerHigh" "50"
    Option "MaxTapTime" "125"
EndSection
Some of those options you might not want - I just copied a default config from Arch Wiki.
If that doesn't work, replace synaptics with libinput or evdev as the driver and try again. If that still doesn't work go into the file you just pasted above (with cat /etc/X11/xorg.conf.d/* and add the following line under MatchIsKeyboard "on"
MatchDevicePath "/dev/input/event*"
