Touchpad acting up
I’ve switched to Linux (manjaro, obviously) about a month ago and I love it, except that my touchpad on my HP Laptop 15-db0xxx sometimes acts up. Acts up in the sense that it sometimes becomes unresponsive, very slow, or just does not work.
The first time it began to act up (a few weeks back) I was able to fix it by following the popular solution (reloading i2c_hid_acpi) from the forum post ‘touchpad sometimes not working’ (unfortunately the forum is not allowing me to add the link to the post).
Two days ago my touchpad started acting up again, so I tried reloading i2c_hid_acpi again:
modprobe -r i2c_hid_acpi && modprobe ic2_hid_acpi
But instead of it fixing the issue, I got this message:
modprobe: FATAL: Module ic2_hid_acpi not found in directory /lib/modules/5.15.23-2-MANJARO
I tried to search for a solution for the error message, but couldn’t find one. I am also a complete beginner, so couldn’t make any sense out of the error message. I ended up getting the touchpad working again by rebooting and running my updates a couple of times. But the proplem has come back; my touchpad is currently not working, and my cursor is not visible on the screen.
Here’s some information about my laptop:
  Kernel: 5.15.23-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: HP product: HP Laptop 15-db0xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 84AE v: 86.21 serial: <superuser required> UEFI: Insyde
    v: F.17 date: 01/16/2019
  ID-1: BAT1 charge: 29.2 Wh (100.0%) condition: 29.2/42.1 Wh (69.2%)
    volts: 13.0 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
    serial: <filter> status: Full
  RAM: total: 7.49 GiB used: 3.89 GiB (52.0%)
  RAM Report:
  Info: dual core model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP smt: enabled arch: Zen rev: 0 cache: L1: 192 KiB
    L2: 1024 KiB L3: 4 MiB
  Speed (MHz): avg: 1589 high: 1597 min/max: 1600/2500 boost: disabled
    cores: 1: 1587 2: 1585 3: 1590 4: 1597 bogomips: 19969
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt
    pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit
    smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
    svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xsaves
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
    chip-ID: 1002:15dd class-ID: 0300
  Device-2: Lite-On HP Webcam type: USB driver: uvcvideo bus-ID: 3-2.1:3
    chip-ID: 04ca:707d class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: amdgpu note: n/a (using device driver) - try sudo/root
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
    class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.23-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: yes
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: 2000
    bus-ID: 03:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 3-2.3:4 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 19.12 GiB (2.1%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: RTM2 scheme: GPT
  ID-1: / size: 915.53 GiB used: 19.12 GiB (2.1%) fs: ext4 dev: /dev/sda2
    label: N/A uuid: 35b9e2a6-b943-44ee-a653-98e7e169593e
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/sda1 label: NO_LABEL uuid: FA0D-CF04
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 3-2.1:3 info: Lite-On HP Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04ca:707d
  Device-2: 3-2.3:4 info: Realtek Realtek Bluetooth 4.2 Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
  Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 55.0 C mobo: 20.0 C gpu: amdgpu temp: 55.0 C
  Processes: 264 Uptime: 19h 10m wakeups: 13 Init: systemd v: 250 Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: 1292 pacman: 1282 flatpak: 7 snap: 3
  Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.12
Thanks in advance for any help you guys provide!
