Hi everyone,
I noticed that touch input for the Dolphin search bar doesn’t open the on-screen keyboard (OSK) due to a wrong default value of gtk-im-module
You can check the value using this command dconf-editor /org/gnome/desktop/interface/gtk-im-module
If it says gtk-im-context-simple
you are likely also affected. Only wayland
works with touch input.
I originally came from this issue in the Gnome bug tracker: OSK auto-open behaviour is inconsistent for nautilus and firefox (#6278) · Issues · GNOME / gnome-shell · GitLab
One dev recommended me that I should report this issue to the Manjaro team.
I decided to post it on the forums, because I’m not sure if this is really an issue that Manjaro can and wants to solve.
So if anybody can reproduce this, see it as some kind of “unofficial bug report”.
