Hello
Torchlight II doesnt start in Steam.
I found a similar Theme for my Question but there is the Solution to install a Lanuguae pack but i dont think this is my Problem, because the terminal Output says something about EFL Class and i have absolutly no Idea what this is. Thanks for any help
I hope the Following copy paste Terminal stuff is helpful i did this my first time
BuildCompleteAppOverviewChange: 172 apps
RegisterForAppOverview 1: 2ms
RegisterForAppOverview 2: 2ms
Installing breakpad exception handler for appid(steam)/version(1669935987)
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 200710, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 200710, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/samuel/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=200710 -- /home/samuel/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/run/media/samuel/Daten/SteamLibrary/steamapps/common/Torchlight II/ModLauncher.bin.x86_64'\0
Game process added : AppID 200710 "/home/samuel/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=200710 -- /home/samuel/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/run/media/samuel/Daten/SteamLibrary/steamapps/common/Torchlight II/ModLauncher.bin.x86_64'", ProcID 10378, IP 0.0.0.0:0
chdir /run/media/samuel/Daten/SteamLibrary/steamapps/common/Torchlight II
ERROR: ld.so: object '/home/samuel/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/samuel/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
/run/media/samuel/Daten/SteamLibrary/steamapps/common/Torchlight II/ModLauncher.bin.x86_64: symbol lookup error: /usr/lib/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var
GameAction [AppID 200710, ActionID 1] : LaunchApp changed task to Completed with ""
Game process removed: AppID 200710 "/home/samuel/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=200710 -- /home/samuel/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/run/media/samuel/Daten/SteamLibrary/steamapps/common/Torchlight II/ModLauncher.bin.x86_64'", ProcID 10378
ThreadGetProcessExitCode: no such process 10379
Uploaded AppInterfaceStats to Steam
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
