I have been reading here and still no luck
can anyone please just give me the steps to having a working conky and able to add themes ?
many thanks
many thanks
Hi,
You already asked for this here:
Links which may be useful:
https://wiki.manjaro.org/index.php?title=Basic_Tips_for_conky
https://wiki.archlinux.org/index.php/conky
https://wiki.archlinux.org/index.php/Conky/Tips_and_tricks
The application conky-manager
can help you to deal with config files and installed themes.
I don’t know much about this application as I’am not using it.
I Know but im still stuck all i want is a running conky and added themes
why is it so hard I Only get this and if i close terminal, Conky is also gone
Full description of Configuration Settings and Conky Objects can be found here:
http://conky.sourceforge.net/config_settings.html
http://conky.sourceforge.net/variables.html
You can also call scripts written in bash, python, lua…
If you take time to read this link: https://wiki.archlinux.org/index.php/conky#Autostart
You will learn how to start Conky automatically. Settings may depend on the window manager / desktop environment you are using.
Im Using Gnome
as always many thanks for ue fast help
I just cant get my head around this
As it’s written in the Arch Wiki, you have to create a .desktop
file under:
~/.config/autostart/conky.desktop
As for the content of this file:
[Desktop Entry]
Type=Application
Name=conky
Exec=conky --daemonize --pause=5
StartupNotify=false
Terminal=false
Conky will start automatically when you log in after setting this up.
I messed up my config file
any help and some how i copy past this Lua thing like this
local usage = [[
Usage: convert.lua old_conkyrc [new_conkyrc]
Tries to convert conkyrc from the old v1.x format to the new, lua-based format.
Keep in mind that there is no guarantee that the output will work correctly
with conky, or that it will be able to convert every conkyrc. However, it
should provide a good starting point.
Although you can use this script with only 1 arg and let it overwrite the old
config, it's suggested to use 2 args so that the new config is written in a new
file (so that you have backup if something went wrong).
Optional: Install dos2unix. We will attempt to use this if it is available
because Conky configs downloaded from Internet sometimes are created on DOS/Windows
machines with different line endings than Conky configs created on Unix/Linux.
For more information about the new format, read the wiki page
<https://github.com/brndnmtthws/conky/wiki>
local function quote(s)
if not s:find("[\n'\\]") then
return "'" .. s .. "'";
end;
local q = '';
while s:find(']' .. q .. ']', 1, true) do
q = q .. '=';
end;
return string.format('[%s[\n%s]%s]', q, s, q);
end;
local bool_setting = {
background = true, disable_auto_reload = true, double_buffer = true, draw_borders = true,
draw_graph_borders = true, draw_outline = true, draw_shades = true, extra_newline = true,
format_human_readable = true, no_buffers = true, out_to_console = true,
out_to_ncurses = true, out_to_stderr = true, out_to_x = true, override_utf8_locale = true,
own_window = true, own_window_argb_visual = true, own_window_transparent = true,
short_units = true, show_graph_range = true, show_graph_scale = true,
times_in_seconds = true, top_cpu_separate = true, uppercase = true, use_xft = true,
draw_blended = true, forced_redraw = true
local num_setting = {
border_inner_margin = true, border_outer_margin = true, border_width = true,
cpu_avg_samples = true, diskio_avg_samples = true, gap_x = true, gap_y = true,
imlib_cache_flush_interval = true, imlib_cache_size = true,
max_port_monitor_connections = true, max_text_width = true, max_user_text = true,
maximum_width = true, mpd_port = true, music_player_interval = true, net_avg_samples = true,
own_window_argb_value = true, pad_percents = true, stippled_borders = true,
text_buffer_size = true, top_name_width = true, total_run_times = true,
update_interval = true, update_interval_on_battery = true, xftalpha = true,
xinerama_head = true,
local split_setting = {
default_bar_size = true, default_gauge_size = true, default_graph_size = true,
minimum_size = true
local colour_setting = {
color0 = true, color1 = true, color2 = true, color3 = true, color4 = true, color5 = true,
color6 = true, color7 = true, color8 = true, color9 = true, default_color = true,
default_outline_color = true, default_shade_color = true, own_window_colour = true
local function alignment_map(value)
local map = { m = 'middle', t = 'top', b = 'bottom', r = 'right', l = 'left' };
if map[value] == nil then
return value;
else
return map[value];
end;
end;
local function handle(setting, value)
setting = setting:lower();
if setting == '' then
return '';
end;
if split_setting[setting] then
local x, y = value:match('^(%S+)%s*(%S*)$');
local ret = setting:gsub('_size', '_width = ') .. x .. ',';
if y ~= '' then
ret = ret .. ' ' .. setting:gsub('_size', '_height = ') .. y .. ',';
end;
return '\t' .. ret;
end;
if bool_setting[setting] then
value = value:lower();
if value == 'yes' or value == 'true' or value == '1' or value == '' then
value = 'true';
else
value = 'false';
end;
elseif not num_setting[setting] then
if setting == 'alignment' and value:len() == 2 then
value = alignment_map(value:sub(1,1)) .. '_' .. alignment_map(value:sub(2,2));
elseif colour_setting[setting] and value:match('^[0-9a-fA-F]+$') then
value = '#' .. value;
elseif setting == 'xftfont' then
setting = 'font';
end;
value = quote(value);
end;
return '\t' .. setting .. ' = ' .. value .. ',';
end;
local function convert(s)
local setting, comment = s:match('^([^#]*)#?(.*)\n$');
if comment ~= '' then
comment = '--' .. comment;
end;
comment = comment .. '\n';
return handle(setting:match('^%s*(%S*)%s*(.-)%s*$')) .. comment;
end;
local input;
local output;
if conky == nil then --> standalone program
-- 1 arg: arg is input and outputfile
-- 2 args: 1st is inputfile, 2nd is outputfile
-- 0, 3 or more args: print usage to STDERR and quit
if #arg == 1 or #arg == 2 then
if os.execute('command -v dos2unix 2>&1 >/dev/null') == 0 then
os.execute('dos2unix ' .. arg[1]);
end
input = io.input(arg[1]);
else
io.stderr:write(usage);
return;
end;
else
-- we are called from conky, the filename is the first argument
input = io.open(..., 'r');
end;
local config = input:read('*a');
input:close();
local settings, text = config:match('^(.-)TEXT\n(.*)$');
local converted = 'conky.config = {\n' .. settings:gsub('.-\n', convert) .. '};\n\nconky.text = ' ..
quote(text) .. ';\n';
if #arg == 2 then
output = io.output(arg[2]);
else
output = io.output(arg[1]);
end
output:write(converted);
output:close();
else
return assert(load(converted, 'converted config'));
end;
If you want to learn more about Lua scripts:
You will need to edit your conky.conf
file to fit your needs.
I would suggest to start from a basic example, to make it work and then try some more fancy ones.
By the way, this website have some great examples:
http://conky.pitstop.free.fr/wiki/index.php5?title=Main_Page
Many thanks I will read about it tomorrow
i will take a break from conky tonight
can any one share there config file with me please
i am learning to set up conky , and want it to look sharp
but Because i am new to this , im not getting the results i want
thank u
Here’s a good place to start, plenty of examples:
There’s thousands more if you search the internet. Please don’t be a Help Vampire.
Never heard of help Vampire First Time
When you are asking for help to have your system look sharp - without actually being able to do it your self - when you keep asking for others to share what they are using without actually doing work yourself - then it begin to look like a vampire - the expression is very much like leeches on torrents - sucking without giving.
There was a thread on the archived forum - maybe you can find som inspiration there? I have posted a link the conky I use on Openbox - others have posted similar.
Often a given conky will require some finish because you would probably want to look slightly different.
There is also Conky Manager from the repo - you can get a lot of inspiration from there - but as all those are in the old conky format they can be hard to work with. I started with the conky-manager package but quickly found they are hard to use and they required polish and finish to work as would like.
With relation to the inclusion of LUA scripts you need a version of conky compiled with LUA support which is not default. Those are usually in AUR but Manjaro has one in the repo with support for lua and nvidia.
sudo pacman -Syu conky-lua-nv
Conky themes are really a script which load different conky script to create a theme. You can easily find conkies on the spider’s web
That’s right. And if you use terminal and run conky && it will be detached from the terminal and run after closing the terminal.
By default, if there IS a file .conkyrc it will be used. If there isn’t, then you end up with a bog standard basic version as you showed.
if you run ‘conky -h’ in terminal, you get help.
-c for a config file, for example. -d to daemonize.
So if you put a file (named conky.conky) in a folder (like ~/Admin/Conky/conky.conky) then you can run conky using that file using
conky -d -c ~/Admin/conky/conky.conky
I have a simple conky to show networking on my desktop - I keep it separate, try it:
conky.config = {
– Conky settings
background = true,
update_interval = 1,
no_buffers = true,
imlib_cache_size = 10,
window = 'specifications',
gap_x = 5,
gap_y = 0,
minimum_width = 20, minimum_height = 0,
maximum_width = 220,
alignment = 'top_right',
own_window = true,
own_window_type = 'normal',
own_window_transparent = false,
own_window_argb_value = 80,
own_window_hints = 'undecorated,sticky,skip_taskbar,skip_pager',
–own_window_type normal
–own_window_transparent no
–own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
–own_window_argb_visual yes
–own_window_argb_value 0
border_inner_margin = 0,
border_outer_margin = 0,
graphics = ‘settings’,
draw_shades = false,
default_shade_color = '#484848',
draw_outline = false,
default_outline_color = '#dddddd',
draw_borders = false,
draw_graph_borders = false,
default_graph_width = 40, default_graph_height = 80,
show_graph_range = false,
text = 'settings',
use_xft = true,
xftalpha = 0,
font = 'Droid Sans:size=9',
text_buffer_size = 256,
useful = 'shortenings',
short_units = true,
pad_percents = 2,
top_name_width = 30,
color = 'scheme',
default_color = '#FFFFFF',
color1 = '#FFFFFF',
color2 = '#2dcba5',-- teal
color3 = '#16a085',-- teal2
color4 = '#FFFFFF',
color5 = '#DCDCDC',
–DCDCDC
color6 = ‘#FFFFFF’,
color7 = ‘#FFFFFF’,
color8 = ‘#A9CFF4’,
–A9CFF4
– iphone wlp0s20u12
conky.text = [[
${if_existing /proc/net/route enp2s0} ${upspeedgraph enp2s0 30,50 efa644 ff5b00 3500 -l} ${alignr}${downspeedgraph enp2s0 30,50 88a669 55ff1a 10000 -l}${color }${font mitr:bold:size=2}
${color2}${font mitr:bold:size=9}${upspeed enp2s0} ${alignr}${downspeed enp2s0}${endif} ]];
You must edit details to suit your system - maybe you don’t have enp2s0, but you should be able to isolate and see a pattern to look for (if existing) and define a graph for that.
I have more than one entry in the real file - one for cable, the other for WiFi, another for my phone connection if I use that.
Another way to start conky I came up with when I started using mouse gestures is a simple script:
#!/bin/bash
if pgrep -x “conky”
then killall conky
else
conky -d -c ~/Admin/conky/network.conky
fi
conky.conky is set to run for only 1 minute for extra information, whilst the first one runs indefinitely. Using a gesture to run the script again will 1. remove any/all conkies or 2. Start the conkies mentioned in the script (so it would be easy to add a line, for example, to add something else, like a fuzzy clock, if you like).
Whilst there are very fancy conkies out there, I always ended up stripping mine down to be simpler - often showing only a semi transparent orange/green graph for network upload/download with a gesture adding cpu/ram, HDD info/temps, Top processes and backup statusses. The ‘fancy’ feature, for me, is the quick switch and timeout on the main conky window to revert to minimalism. No point wasting resources monitoring resources
