As a person who uses both fvwm3 & dwm on manjaro, I’d appreciate either a catch-all for other window managers or one for suckless and fvwm.
I am certain I’m a minority (probably of one) in using these wms.
Please note: I’m not a moderator, just an editor so I can be overruled if you would deem the following solution not good enough:
dwm
tag already existed (and only contains 4 topics)fvwm3
tag has just been created.If both of those tags become popular enough, the mods might be more willing to create a specific topic for questions containing those.
That works just fine…
what you say makes sence, even some categories we already have are not used, the forum had a clean up today because we had too many.
Sorry for the thread-hijack but would that explain the raft of “edited” posts/threads in the notification list which appeared some time in the last 24 hours?
Most likely.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
