I’ve encountered a frustrating issue today while trying to update my programs. Every time I attempt to update, I’m greeted with an error message stating “Target not found: electron25”. This error is preventing me from keeping my programs up to date, and I’m not sure how to resolve it. Has anyone else experienced a similar issue or found a solution?
I’ve tried searching online for possible solutions, but unfortunately, I haven’t had much luck. Any help or advice would be greatly appreciated. Thank you in advance for your assistance!
## Manjaro Linux custom mirrorlist
## Generated on 2023-07-10 12:29
## Please use 'pacman-mirrors -id' To reset custom mirrorlist
## Please use 'pacman-mirrors -c all' To reset custom mirrorlist
## To remove custom config run 'pacman-mirrors -c all'
## Country : United_Kingdom
Server = https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
## Country : Global
Server = https://mirrors.manjaro.org/repo/stable/$repo/$arch
Server = https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Thank you, I ran the update through this command. As long as everything is going well. pacman -Syu
… UPD …
I have error:
error: failed to commit transaction (conflicting files)
npm: /usr/lib/node_modules/npm/lib/commands/login.js exists in filesystem
npm: /usr/lib/node_modules/npm/lib/utils/auth.js exists in filesystem
npm: /usr/lib/node_modules/npm/lib/utils/completion.fish exists in filesystem
facepalm
… UPD 2 …
Launched after the full download of all packages through the command line the usual program manager - everything was installed through it, since it renamed the existing npm files
