'Too many levels of symbolic links' - trying to mount network drive
#1
been screwing with this for way too long and it’s time to solicit some help…
running Manjaro 18.x on a laptop which is wired to network router
running a Raspberry Pi with Kodi on it (LibreELEC, connected to TV) which is wired to router
the Pi has a USB SSD formatted ext4
i can SSH to the Pi, no problem
what i want to is be able to play videos from the Pi on the laptop without the KIO problems and so as i understand i need to mount the drive locally on the laptop
i also want to mount the Pi drive on-demand so i can read/write using Dolphin, so in fstab i have (line breaks for readability):
root@192.168.50.111:/
/home/atom/kodi
fuse.sshfs noauto,
x-systemd.automount,
_netdev,
users,
idmap=user,
IdentityFile=/home/user/.ssh/LibreELEC_root_id_rsa,
allow_other,
reconnect
0
0
if i restart the system and try to cd into /home/atom/kodi, i get “Too many levels of symbolic links”, however there are no symlinks in play so far as i’m aware - /home/atom/kodi is a directory, not a symlink, and there is nothing in it since it’s supposed to be used only as a mount point
note also that i tried the above many different way, including creating the mount point as /mnt/kodi and i always have the same problem - at the start of fstab i also tried the path:
root@192.168.50.111:/media/sda1-ata-SanDisk_SDSSDH32/
#2
Not sure, but should that be
instead?
#3
I use samba to access my raspberry pi (openelec). Works fine for transferring videos to it or even playing from the share directly on my laptop (although I do that very rarely).
#4
the colon actually was in fstab - i deleted it in the post because i thought it wasn’t
#5
still struggling with this - i can use SMB, but i don’t want to and i’d like to figure out why the fstab string isn’t working
this works in terminal:
sshfs root@kodi.lan:/ /home/atom/kodi
i just tried the following in fstab as a test and it didn’t work at all - the drive was never mounted after reboot:
sshfs#root@kodi.lan:/ /home/atom/kodi fuse user,_netdev,reconnect,uid=1000,gid=1000,idmap=user,allow_other 0 0
#6
What I would try is to mount in a terminal as root using the same options you’re using in /etc/fstab and see what happens.
#7
i don’t know how to do that - can you provide the syntax? this is what i’m currently working with…
#root@192.168.50.111:/   /home/atom/kodi  fuse.sshfs   noauto,x-systemd.automount,_netdev,IdentityFile=/home/user/.ssh/LibreELEC_root_id_rsa,allow_other,reconnect 0 0
#8
https://wiki.archlinux.org/index.php/SSHFS#Mounting
#9
options are listed here :https://jlk.fjfi.cvut.cz/arch/manpages/man/sshfs.1
but not all of those options seem to correspond to the options i have in fstab - for instance noauto,x-systemd.automount - hence i don’t see how i can recreate the mount options from the terminal
#10
The idea is you miss out ones which aren’t relevant.
Start with a minimal set of arguments then add them in turn until you find one which stops it working. If they all work then you’ve at least removed them as variables.
#11
i understand what you’re saying, but there’s no counterpart to x-systemd.automount that i’m aware of and that seems to be what’s breaking everything
i can ssh into the server without issue, or manually mount the drive, but i can’t (so far) mount it on-demand
Righty.
Your original fstab line matches exactly what’s in the Arch wiki (https://wiki.archlinux.org/index.php/SSHFS#On_demand) so it “should work”.
Have you tried with a different mount point e.g. /mnt or /media/kodi ?
#13
yes i have - starting to wonder if the problem isn’t on the R-Pi end - i opened a thread in the LibreELEC forum, maybe they can help
starting over, sorta…
so i still can’t mount a network drive via fstab - here is the last fstab entry i tried:
root@192.168.50.111:/var/ /home/atom/kodi ext4 noauto,_netdev,user,idmap=user,identityfile=/home/atom/.ssh/LibreELEC_root_id_rsa,port=22,allow_other 0 0
after saving fstab i run systemctl daemon-reload && systemctl restart home-atom-kodi.mount and the drive is not mounted
then when i run ‘systemctl status home-atom-kodi.mount’…
# systemctl status home-atom-kodi.mount
● home-atom-kodi.mount - /home/atom/kodi
   Loaded: loaded (/etc/fstab; generated)
   Active: failed (Result: exit-code) since Tue 2019-03-05 08:43:31 EST; 3s ago
    Where: /home/atom/kodi
     What: 192.168.50.111:/var/
     Docs: man:fstab(5)
           man:systemd-fstab-generator(8)
Mar 05 08:43:31 atom-pc systemd[1]: Mounting /home/atom/kodi...
Mar 05 08:43:31 atom-pc mount[7436]: mount: /home/atom/kodi: special device 192.168.50.111:/var/ does not exist.
Mar 05 08:43:31 atom-pc systemd[1]: home-atom-kodi.mount: Mount process exited, code=exited, status=32/n/a
Mar 05 08:43:31 atom-pc systemd[1]: home-atom-kodi.mount: Failed with result 'exit-code'.
Mar 05 08:43:31 atom-pc systemd[1]: Failed to mount /home/atom/kodi.
so what does ‘special device 192.168.50.111:/var/ does not exist’ mean?
the path ‘192.168.50.111:/’ (the subfolder path doesn’t matter) certainly does exist, as does the mount folder, and i can ssh and sshfs to it from the terminal - for instance, this works (non-root user)…
sshfs root@192.168.50.111:/ /home/atom/kodi -o identityfile=/home/atom/.ssh/LibreELEC_root_id_rsa
#15
It probably means /var/ isn’t accessible on the server.
#16
/var is accessible - the sub directory doesn’t matter - i could’ve used root ‘/’ as the example
i can sshfs/ssh into any directory from the terminal just fine
#17
Maybe try systemd mount units instead:
closed #18
