> # /etc/pacman.conf
> # See the pacman.conf(5) manpage for option and repository directives
> # GENERAL OPTIONS
> [options]
> # The following paths are commented out with their default values listed.
> # If you wish to use different paths, uncomment and update the paths.
> #RootDir = /
> #DBPath = /var/lib/pacman/
> CacheDir = /var/cache/pacman/pkg/
> #LogFile = /var/log/pacman.log
> #GPGDir = /etc/pacman.d/gnupg/
> #HookDir = /etc/pacman.d/hooks/
> HoldPkg = pacman glibc manjaro-system
> # If upgrades are available for these packages they will be asked for first
> SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
> #XferCommand = /usr/bin/curl -L -C - -f -o %o %u
> #XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
> #CleanMethod = KeepInstalled
> #UseDelta = 0.7
> Architecture = auto
> # Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
> #IgnorePkg =
> #IgnoreGroup =
> #NoUpgrade =
> #NoExtract =
> # Misc options
> #UseSyslog
> #Color
> #NoProgressBar
> # We cannot check disk space from within a chroot environment
> CheckSpace
> #VerbosePkgLists
> #ParallelDownloads = 5
> # By default, pacman accepts packages signed by keys that its local keyring
> # trusts (see pacman-key and its man page), as well as unsigned packages.
> SigLevel = Required DatabaseOptional
> LocalFileSigLevel = Optional
> #RemoteFileSigLevel = Required
> # NOTE: You must run `pacman-key --init` before first using pacman; the local
> # keyring can then be populated with the keys of all official Manjaro Linux
> # packagers with `pacman-key --populate archlinux manjaro`.
> # REPOSITORIES
> # - can be defined here or included from another file
> # - pacman will search repositories in the order defined here
> # - local/custom mirrors can be added here or in separate files
> # - repositories listed first will take precedence when packages
> # have identical names, regardless of version number
> # - URLs will have $repo replaced by the name of the current repo
> # - URLs will have $arch replaced by the name of the architecture
> # Repository entries are of the format:
> # [repo-name]
> # Server = ServerName
> # Include = IncludePath
> # The header [repo-name] is crucial - it must be present and
> # uncommented to enable the repo.
> # The testing repositories are disabled by default. To enable, uncomment the
> # repo name header and Include lines. You can add preferred servers immediately
> # after the header, and they will be used before the default mirrors.
> [core]
> SigLevel = PackageRequired
> Include = /etc/pacman.d/mirrorlist
> [extra]
> [community]
> # If you want to run 32 bit applications on your x86_64 system,
> # enable the multilib repositories as required here.
> [multilib]
> # An example of a custom package repository. See the pacman manpage for
> # tips on creating your own repositories.
> #[custom]
> #SigLevel = Optional TrustAll
> #Server = file:///home/custompkgs
> [sublime-text]
> Server = *LINK REMOVED FOR FILTER*
sudo pacman -Syyu did not work the first time due to (unrelated) conflicting file issues but after working through that separate issue, my problem seems to have been solved.
