Hi, i know tls 1.0 is outdated and manjaro disabled this. But for now, I need tls 1.0, because my wifi doesn’t work. It’s the fault of my internet provider, they use the out to date protocol. Yea i know its stupid and yes i want to use another provider, but this happens not for today. Please, how can i enable tls 1.0 again in manjaro? I know how it works in debian, ubuntu (?), fedora, etc, but manjaro makes it not easy.
This is the command for other distros:
update-crypto-policies --set LEGACY
https://askubuntu.com/questions/1233186/ubuntu-20-04-how-to-set-lower-ssl-security-level
may help to configure openssl for desired level of insecurity. But you must understand you risks.
For example, after update I got error Failed to transport message. Error during SSL handshake: error:0A0C0103:SSL routines::internal error at Kmail when letter must go to SMTP server of our organization. It has only tls1.0. First, I solved problem with connection with such modifications of /etc/ssl/openssl.cnf
[openssl_init]
ssl_conf = ssl_sect
[ssl_sect]
system_default = system_default_sect
[system_default_sect]
CipherString = DEFAULT:@SECLEVEL=0
But after I told with admin and I knew about new SMTP server at use. That solved my problem without needed modify config.
