TLP refuse to install
Hi, i try to install TLP but it refuse to install, something like serven not available
I want use tlp to manage my notebook hawei mate D Amd battery to reach 70% and than stop charging using command
/etc/tlp.conf
START_CHARGE_THRESH_BAT0=40
STOP_CHARGE_THRESH_BAT0=70
That because Huawei WMI-driver even if present on kernel is not properly working (it stay at 70% only if i boot on windows and than reboot on manjaro but after a restar doesn’t work anymore)
How install TLP? Thanks
Hello,
Please open terminal and run:
pamac install tlp
and provide the exact error you get, if any, because something something is not helpful for us to know what the issue is on your end.
I guess the mirrors are outdated.
Yes exactly what happens, my country server are down (Italy) solved using Austria+France+German. TLP and TLP gui (that helps me setting it) now are installed
Now I hope understand how use it and if it works to controll battery charge.
I will check if working
