TLP query
I am running a new installation of Manjaro KDE with Kernel 4.19.56 on a Thinkpad X250
I'd like to get TLP installed correctly. Output from tlp-stat -b on my laptop indicates:
natacpi = active (data, thresholds)
tpacpi-bat = inactive (kernel module 'acpi_call' not installed)
tp-smapi = inactive (ThinkPad not supported)
Recommendations
  • Install acpi_call kernel module for ThinkPad battery recalibration
However in the linrunner guidance it says that:
starting with Kernel 4.17 tpacpi-bat gets superseded by a new, native kernel API called 'natacpi'. tlp-stat -b indicates this as follows:
+++ Battery Features
tpacpi-bat = inactive (discharge)
With full natacpi support, you won't need external kernel module packages anymore.
My question is, do I need to install an additional kernel module (e.g. acpi_call) or not?
Any guidance welcome, thanks.
I have a ThinkPad T530 and get with every new kernel-version (XY) automatically a package linuxXY-acpi_call. Don't remember if it's because of the packages acpi and acpid which are installed too or if I sometime did write something in a certain file. All I know is, yes you need the kernel modules to get it working.
Hi,
the suggestion from tlp-stat -b is correct. The FAQ is a bit outdated, i'll update it asap.
Hey! Its you :heart:
Thanks all for your replies.
So just to clarify, I will use the following command to install acpi_call:
sudo apt-get install acpi-call-dkms
uh... Manjaro doesn't use apt-get. It's pacman or pamac ? pamac might be more familiar.
pamac install acpi_call-dkms
honestly... neither does ubuntu or mint .. they all just use apt now ...
anyways, yes please use one of our package managers :wink:
Oops, my bad! Accidentally copied command from the Ubuntu section.
Thanks everyone.
Why would you want to use the dkms packages instead of the precompiled module packages:
linux419-acpi_call 1.1.0-52
linux52-acpi_call 1.1.0-2
Just curious...
I was purely following guidance at https://linrunner.de/en/tlp/docs/tlp-linux-advanced-power-management.html No mention of the above there, unless I missed it. Is this method preferable?
Well, I guess it is a matter of taste or personal preference. I always prefer the precompiled binary packages coming with Manjaro. This is a competitive advantage of Manjaro compared to other distros. It comes with a whole bunch of precompiled modules, incl. ZFS for example. I rely on that. I also believe it helps trouble shooting and bug fixing if everybody uses the same binary.
Thanks. Can I just go ahead and install these two module packages via Pamac? Or is it more involved than this?
No. Just go ahead and install. Afterwards a reboot will be necessary.
Strictly speaking, you only need acpi_call for some battery related features on ThinkPads, like battery calibration or discharge.
As mbod said, always use the precompiled modules unless you run a custom kernel.
Ok, so hopefully my last question. I tried the following command:
sudo pacman linux419-acpi_call 1.1.0-52
and it returned:
error: no operation specified
Forgive my ignorance :grimacing:
You ran the wrong command :wink:
You should run
pamac install linux419-acpi_call
or:
sudo pacman -S linux419-acpi_call
Notice that pacman and pamac have different syntax!
