TLP 1.5 not starting on bootup
Hi all,
I searched a bit and found this thread ‘tlp-not-starting-at-boot’ in this forum, but it didn’t help.
If I manually start tlp it works as configured, but after reboot the service does not start.
I’ve done sudo systemctl enable tlp.service several times, but it doesn’t start at boot.
It could be conflicting with power-profiles-daemon.service
To fix it try
sudo systemctl disable --now power-profiles-daemon
sudo systemctl mask power-profiles-daemon
sudo systemctl enable --now tlp.service
Look good now.
Thank you
