Hi,
After a time I tried to give Wayland a chance again, but noticed that the menu icon does not appear in the window bar of GTK+ apps (e.g. DBeaver, Handbrake).
Under X11 everything is as it should be.
The problem exists with different themes/window decorations.
Is this a known bug?
Any hints how to resolve the problem?
X11:
Wayland:
inxi -v7azy
System: Kernel: 6.1.35-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=e1875968-aed1-42d3-b90c-be51960c7910 rw resume=UUID=e1875968-aed1-42d3-b90c-be51960c7910 resume_offset=29833216 apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1 nvidia_drm.modeset=1 modprobe.blacklist=nouveau systemd.setenv=GPUMOD=nvidia nowatchdog intel_iommu=on iommu=pt Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux Machine: Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0 serial: <superuser required> BIOS: American Megatrends v: 1.9 date: 03/02/2011 Battery: Message: No system battery data found. Is one present? Memory: System RAM: available: 7.75 GiB used: 2.25 GiB (29.0%) RAM Report: permissions: Unable to run dmidecode. Root privileges required. CPU: Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6 model-id: 0x1E (30) stepping: 5 microcode: 0xA Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB Speed (MHz): avg: 1401 high: 2801 min/max: 1200/2801 boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1203 2: 1200 3: 2801 4: 1203 5: 1203 6: 1200 7: 1203 8: 1200 bogomips: 44935 Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable Type: meltdown mitigation: PTI Type: mmio_stale_data status: Unknown: No mitigations Type: retbleed status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+ status: current (as of 2023-05) arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: none off: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300 Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 102 s-size: 478x269mm (18.82x10.59") s-diag: 548mm (21.59") Monitor-1: DVI-I-1 note: disabled model: Samsung SyncMaster serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes: max: 1920x1080 min: 640x480 API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 direct-render: Yes Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Micro-Star MSI 5 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56 class-ID: 0403 Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403 Device-3: JMTek LLC. Lioncast_LX60_USB_Headset driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.2:3 chip-ID: 0c76:1617 class-ID: 0300 serial: <filter> API: ALSA v: k6.1.35-1-MANJARO status: kernel-api with: aoss type: oss-emulator tools: alsactl,alsamixer,amixer Server-1: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse status: active 2: pipewire-media-session status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter> IP v6: <filter> type: noprefixroute scope: link IF-ID-1: virbr0 state: down mac: <filter> IP v4: <filter> scope: global broadcast: <filter> WAN IP: <filter> Bluetooth: Message: No bluetooth data found. Logical: Message: No logical block device data found. RAID: Message: No RAID data found. Drives: Local Storage: total: 2.73 TiB used: 257.44 GiB (9.2%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3020ALA632 size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR Message: No optical or floppy data found. Partition: ID-1: / raw-size: 585.94 GiB size: 575.67 GiB (98.25%) used: 257.44 GiB (44.7%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A uuid: e1875968-aed1-42d3-b90c-be51960c7910 Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) ID-1: swap-1 type: file size: 11 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert uuid: 583E97273E96FD66 ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System uuid: 0A12C25D12C24CFF ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A uuid: 34862028861FE95E ID-4: /dev/sda4 maj-min: 8:4 size: 731.51 GiB fs: ntfs label: Daten uuid: 7024BEAB24BE73A6 ID-5: /dev/sdb1 maj-min: 8:17 size: 1.15 TiB fs: ntfs label: Daten3 uuid: 86E470A6E47099DF ID-6: /dev/sdb2 maj-min: 8:18 size: 100.18 GiB fs: ext4 label: Backup uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1 USB: Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900 Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020 class-ID: 0900 Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA chip-ID: 2516:0042 class-ID: 0301 Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301 Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900 Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020 class-ID: 0900 Device-1: 2-1.2:3 info: JMTek LLC. Lioncast_LX60_USB_Headset type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 0c76:1617 class-ID: 0300 serial: <filter> Device-2: 2-1.3:4 info: Genesys Logic USB 2.0 Card Reader type: mass storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 05e3:070e class-ID: 0806 serial: <filter> Sensors: System Temperatures: cpu: 49.0 C mobo: 40.0 C gpu: nvidia temp: 55 C Fan Speeds (RPM): cpu: 1072 fan-1: 826 fan-3: 915 gpu: nvidia fan: 0% Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.28 Info: Processes: 234 Uptime: 2h 50m wakeups: 0 Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1808 pm: pacman pkgs: 1798 libs: 482 tools: pamac,yay pm: flatpak pkgs: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.27
