Tips for responding to N00bs
Over the last couple of days I've been:
  1. Starting my conversation with anyone that has this message displayed:
    This is the first time $USER has posted — let’s welcome them to our community!
    :+1: Welcome to Manjaro! :+1:
  2. For those that will "test and come back later" and thanking me, I tell them:
    Please don't forget to come back and share the final solution! :innocent:
  3. For all those that:
  • mark their subject [Solved]
  • profusely thank someone else (or very rarely myself),
    I DM¹ (Direct Message) / PM (Personal Message) them:
Thank you for your thank you:
[LinkToThankYou]
But it's better to mark the answer that solved your question as "Solution" like this:
Solution
so that your question gets removed from the "unsolved" queue and if anyone else has the same question as you and they look for a solution, they'll find it as well!
If that would not have resolved your issue, don't worry though, someone else more intelligent will drop by and give you a better answer!
We thank you for your cooperation...
:innocent: :wink: :+1:
  1. And for anyone retracting a question, (cc @tbg) I tell them:
Hey there,
Why did you retract your question?
[LinkToRetraction]
If you found a solution, just share it with the community in a reply and mark it as "solution" like this:
Solved
so that someone else can benefit from your investigations!
We thank you for your cooperation!
And I'm getting very positive feed-back on all of the above!
So feel free to copy-paste the above and start doing that too, or feel free to leave some constructive comments how we can improve or feel free to totally ignore me...
:angel:
Note 1: Nein! Kein Deutsche Marken! :stuck_out_tongue_winking_eye: :crazy_face:
Note 2: And before you tell anyone to do a Ctrl+Alt+F2,
tell them that Ctrl+Alt+F1 is their friend!!!
Problem is once the problem is solved the issue is forgotten even for people who asked (me).
That sometimes can be an issue. I used to do IT support online, and often after fixing a person's issue, they forget about it.
I try to make sure to mark something solved myself, though.
I do IT support in person and I still forget solutions for problems I have resolved in the past XD
