So until a few days back, timeshift used to run just fine, and I even did a full system restore after reinstalling my system( borked something). But for a couple of days, timeshift is active but doesn’t make a backup. The last backup it made was on 01/07/22. I have set it to make 2 daily and 1 monthly backup ( rsync) on a separate partition( btrfs) on my HDD.
More curiously, recently, whenever I try to reboot/ shutdown, an error message come saying Failed to unmount /home and Failed to unmount /run/media/backup/(something) [this is the partition for backups]
System info:
Host: Omen Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=64731a57-69cf-4a5e-b7b7-d28659c3a3f2 rw quiet
resume=UUID=b58e5725-2527-4ab3-904b-d313418f1cf7 udev.log_priority=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 3
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8575 v: 21.17 serial: <superuser required> UEFI: AMI
v: F.23 date: 07/06/2021
ID-1: BAT0 charge: 13.0 Wh (71.4%) condition: 18.2/18.2 Wh (100.0%)
volts: 11.4 min: 11.6 model: HP Primary type: Li-ion serial: N/A
status: discharging
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1582 high: 2527 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 1157 3: 1087
4: 2069 5: 1911 6: 2059 7: 2165 8: 2527 9: 1039 10: 1206 11: 1854
12: 1119 bogomips: 62431
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0408:5300 class-ID: 0e02 serial: 200901010001
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_wayland driver: X: loaded: modesetting gpu: i915,nvidia
display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.53 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: up mac: 0c:dd:24:02:7a:c4
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 03:00.0
IF: eno1 state: down mac: f8:b4:6a:b4:41:10
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 248.64 GiB (21.3%)
model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: 192228803879 rev: 10112006 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: JR1000BDGT7WPE rev: A3T0
scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.07 GiB (97.69%) used: 16.82 GiB (43.0%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 88.8 MiB (34.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 58.91 GiB size: 57.68 GiB (97.92%)
used: 38.25 GiB (66.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.55 GiB used: 30.1 MiB (0.6%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 44.0 C pch: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1972 fan-2: 0
Processes: 316 Uptime: 11h 22m wakeups: 4 Memory: 7.57 GiB
used: 2.95 GiB (39.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1491
lib: 433 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.19
