Hello,
i could not manage to find a way to check if Timeshift is currently running a backup in the background!
I would like to have like a “one-line-command” for console to check if there is currently a backup going on.
My background is, that i want to create a icon changing its color and to be notified if a backup started while using awesomeWM
A solution would be something like
systemctl --type=service | grep timeshift
I know timeshift is ran via cron
To trigger “timeshift” commands from console i need sudo → Not possible
Maybe someone does have a solution for me.
I dont know if
systemctl status cronie.service
gives some information about currently running updates
Thanks a lot
What about…
ps aux | grep timeshift | grep -v grep
Perfect thanks!
From there on i can proceed!
The final solution for me is
ps aux | grep rsync | grep -v grep
Because
timeshift starts rsync if running
grep starts also a process wich then finds itsself because “rsync” is in the description of the grep process
Now if rsync is running, this line does NOT return NOTHING “”
My mistake… Yes, I know that timeshift
uses rsync
, and I was in doubt about whether timeshift
itself would also have a process in the list when run from a cron
job.
Fair is fair, the solution goes to you.
system
Closed
4 October 2021 02:02
6
