Today I ran timeshift under Ruah 21.3.7 then updated “add/remove software”
Noticed Linux was now Sikaris 22.0.0
So, I ran timeshift again but it now crashes every time.
Reboot and shutdown changed nothing.
Anyone else have this issue?
When they release a update that fixes the glib2 issue is it going to be noted here? Ask cause it would be a good heads up for us that will need to remove glib2 from IgnorePkg. Thanks
It’s already in Testing right now.
Thanks but I asked if it was going to be mentioned in this thread so peep can have a reminder to remove it from their ignore list.
If you put something on your ignore list you’ll still get notified (at least by pacman
) fo the package and (more importantly) target version you’re ignoring.
Aragorn
October 7, 2022, 11:52am
49
Indeed, and by pamac
too. They both tell you which packages are being ignored.
Locutus
October 7, 2022, 11:55am
50
Thanks guys very good to know.
I’m on unstable and Timeshift gui is still crashing. What glib2 update do you mean?
philm
October 7, 2022, 12:11pm
52
Let me know if updating to glib2-2.74.0-1.0 improve things …
Sorry, no, Timeshift gui still crashes for me with glib2-2.74.0-1.0
Don’t know if this is helpful, but there’s more crash info provided here:
opened 03:27AM - 01 Oct 22 UTC
**System:**
- Linux Distribution: Manjaro cinnamon
- timeshift version 22.06… .5, libc 2.36
Timeshift crashed twice while creating snapshot at seemingly random moment and also once while deleting snapshot. On the 3rd attempt to create snapshot, it worked normally.
Terminal output while creating snapshot:
App config loaded: /etc/timeshift/timeshift.json
Mounted '/dev/sda2' at '/run/timeshift/2706/backup'
Creating new snapshot...(RSYNC)
Saving to device: /dev/sda2, mounted at path: /run/timeshift/2706/backup
Linking from snapshot: 2022-09-14_08-46-23
Syncing files with rsync...
**7.36% complete (00:00:19 remaining)
ERROR:/build/timeshift/src/timeshift/src/Utility/TeeJee.Misc.vala.c:516:string_replace: code should not be reached
Bail out! ERROR:/build/timeshift/src/timeshift/src/Utility/TeeJee.Misc.vala.c:516:string_replace: code should not be reached
/usr/bin/timeshift-launcher: line 30: 2706 Aborted (core dumped) pkexec ${app_command}
journalctl:
Oct 01 03:57:35 fred-manjaro-cinnamon systemd[1]: Started Process Core Dump (PID 3023/UID 0).
Oct 01 03:57:35 fred-manjaro-cinnamon systemd-coredump[3024]: [🡕] Process 2706 (timeshift-gtk) of user 0 dumped core.
Module linux-vdso.so.1 with build-id 6a6aaf8fbb636bd2ab94dd5d8b44be5f8d4a6eb7
Module librsvg-2.so.2 with build-id c5d3f3e2ba0718c84f4f6f02974929f5459dde04
Module libpixbufloader-svg.so with build-id a145d079b95f06b08de3a1916110250de1ee889e
Module libnss_systemd.so.2 with build-id b7482bac90954fa3309c422c158d46c7ea27464b
Module libxkbfile.so.1 with build-id dc74ddc73cb1178f037cdc608f7029a0bc9f69a1
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libsqlite3.so.0 with build-id 9af0762dc0b9aa82565f566ef69424a8e4af58da
Module libxml2.so.2 with build-id 49868de417eee9052facae410a866ebfbd5cceb8
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libdbus-1.so.3 with build-id 130b4008893289a2628546d8f98f6977d61270cd
Module libatspi.so.0 with build-id 51fdaad17db96c5569b8f59908e7c076fbd6fe1c
Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
Module libgnomekbd.so.8 with build-id 9b50613358fc5812925d41109dae2ae6037d4310
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module ld-linux-x86-64.so.2 with build-id 075a6ad9f1c3f9cbb5f3301186bbe68c6a477808
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b4ae6341a6b845e55701dd4577a12cdc3ec0c73e
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 75ddfc46abae129a83449506506501117ce98ff8
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 007c5a54e838e649215b740df9568e4d4c9c6507
Module libgnomekbdui.so.8 with build-id 8587f7b950d379edef6c112b68075b3388b43b86
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libc.so.6 with build-id 90b9e4f641f8752292698389f241cbf0ff49d687
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libgobject-2.0.so.0 with build-id afb0315fefdf602be0615bd5c97f35a7ac1d6bbe
Module libgio-2.0.so.0 with build-id 804d947f8cb14bbbbf97e8bf2f93fd17b744e719
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libatk-1.0.so.0 with build-id c25517cd775e783725a3ed2815b09a8096bd6565
Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
Module libpango-1.0.so.0 with build-id bdcd807766c7b943b1ba1a00343adf73799e3f83
Module libpangocairo-1.0.so.0 with build-id 68bcb6fe10c46cb09c7228206e4dbb7e3940fd34
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgdk-3.so.0 with build-id f3bc07ea30b1a84c4e3df1d67deaadfcf747bc3c
Module libgtk-3.so.0 with build-id f25162b866dd8b576794f6f06b91a36ac8f570f8
Module libxapp.so.1 with build-id af7ce569cda64b23f0b4eea7018c0766b346ec38
Module libvte-2.91.so.0 with build-id 360ab033f3d0130660da4752207cb7a6923c535f
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libharfbuzz-gobject.so.0 with build-id 635f6578ccaa6d420c29806823569807388dfa34
Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
Module libgmodule-2.0.so.0 with build-id 95ec7a190858206b2eaba22e06b126e4a4449200
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libgee-0.8.so.2 with build-id 5cdccd3d1b5d1cc3e9ff84eaa95b3898aeaf7857
Module timeshift-gtk with build-id 05039dd659565d6a5c27543de09e9c5c523e4351
Stack trace of thread 2706:
#0 0x00007f2f93ba949c n/a (libc.so.6 + 0x8849c)
#1 0x00007f2f93b59958 raise (libc.so.6 + 0x38958)
#2 0x00007f2f93b4353d abort (libc.so.6 + 0x2253d)
#3 0x00007f2f94e3606a n/a (libglib-2.0.so.0 + 0x1d06a)
#4 0x00007f2f94e918d0 g_assertion_message_expr (libglib-2.0.so.0 + 0x788d0)
#5 0x0000565494e864bb n/a (timeshift-gtk + 0xfb4bb)
#6 0x0000565494e8657d tee_jee_misc_escape_html (timeshift-gtk + 0xfb57d)
#7 0x0000565494deba94 backup_box_take_snapshot (timeshift-gtk + 0x60a94)
#8 0x0000565494df6a5a n/a (timeshift-gtk + 0x6ba5a)
#9 0x0000565494df6284 n/a (timeshift-gtk + 0x6b284)
#10 0x0000565494df58a2 n/a (timeshift-gtk + 0x6a8a2)
#11 0x0000565494df4ed1 n/a (timeshift-gtk + 0x69ed1)
#12 0x00007f2f94e6f042 n/a (libglib-2.0.so.0 + 0x56042)
#13 0x00007f2f94e6e81b g_main_context_dispatch (libglib-2.0.so.0 + 0x5581b)
#14 0x00007f2f94ec4ec9 n/a (libglib-2.0.so.0 + 0xabec9)
#15 0x00007f2f94e6dd7f g_main_loop_run (libglib-2.0.so.0 + 0x54d7f)
#16 0x00007f2f9460fe9f gtk_main (libgtk-3.so.0 + 0x1d8e9f)
#17 0x0000565494de9c62 app_gtk_start_application (timeshift-gtk + 0x5ec62)
#18 0x0000565494de90d8 n/a (timeshift-gtk + 0x5e0d8)
#19 0x0000565494de9120 main (timeshift-gtk + 0x5e120)
#20 0x00007f2f93b44290 n/a (libc.so.6 + 0x23290)
#21 0x00007f2f93b4434a __libc_start_main (libc.so.6 + 0x2334a)
#22 0x0000565494da3245 _start (timeshift-gtk + 0x18245)
Stack trace of thread 2758:
#0 0x00007f2f93c1be5f __poll (libc.so.6 + 0xfae5f)
#1 0x00007f2f94ec4e2f n/a (libglib-2.0.so.0 + 0xabe2f)
#2 0x00007f2f94e6d0d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#3 0x00007f2f94e6d122 n/a (libglib-2.0.so.0 + 0x54122)
#4 0x00007f2f94e9bc55 n/a (libglib-2.0.so.0 + 0x82c55)
#5 0x00007f2f93ba774d n/a (libc.so.6 + 0x8674d)
#6 0x00007f2f93c29700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 2827:
#1 0x00007f2f94044041 n/a (libgio-2.0.so.0 + 0xce041)
#2 0x00007f2f93fec635 g_input_stream_read (libgio-2.0.so.0 + 0x76635)
#3 0x00007f2f93fb71c1 n/a (libgio-2.0.so.0 + 0x411c1)
#4 0x00007f2f93fb7e34 g_buffered_input_stream_fill (libgio-2.0.so.0 + 0x41e34)
#5 0x00007f2f93fc0dc7 g_data_input_stream_read_line (libgio-2.0.so.0 + 0x4adc7)
#6 0x0000565494e40656 n/a (timeshift-gtk + 0xb5656)
#7 0x0000565494e3f127 n/a (timeshift-gtk + 0xb4127)
#8 0x00007f2f94e9bc55 n/a (libglib-2.0.so.0 + 0x82c55)
#9 0x00007f2f93ba774d n/a (libc.so.6 + 0x8674d)
#10 0x00007f2f93c29700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 2826:
#6 0x0000565494e4023e n/a (timeshift-gtk + 0xb523e)
#7 0x0000565494e3f0f5 n/a (timeshift-gtk + 0xb40f5)
Stack trace of thread 2813:
#0 0x00007f2f93bee545 clock_nanosleep (libc.so.6 + 0xcd545)
#1 0x00007f2f93bf3057 __nanosleep (libc.so.6 + 0xd2057)
#2 0x00007f2f94e99391 g_usleep (libglib-2.0.so.0 + 0x80391)
#3 0x0000565494e8ecc4 tee_jee_system_sleep (timeshift-gtk + 0x103cc4)
#4 0x0000565494db71fb n/a (timeshift-gtk + 0x2c1fb)
#5 0x0000565494db413c n/a (timeshift-gtk + 0x2913c)
#6 0x0000565494db119a main_create_snapshot (timeshift-gtk + 0x2619a)
#7 0x0000565494dec59c n/a (timeshift-gtk + 0x6159c)
#8 0x0000565494deb46e n/a (timeshift-gtk + 0x6046e)
#9 0x00007f2f94e9bc55 n/a (libglib-2.0.so.0 + 0x82c55)
#10 0x00007f2f93ba774d n/a (libc.so.6 + 0x8674d)
#11 0x00007f2f93c29700 n/a (libc.so.6 + 0x108700)
philm
October 7, 2022, 1:28pm
54
Seems it only fixes some issues with Gimp . Let’s see. Most likely a git-bisect on glib2 might help. I did once for a kernel issue: GitHub - philmmanjaro/linux41: Manjaro Kernel 4.1
Yochanan
Split this topic
October 8, 2022, 10:07pm
55
7 posts were split to a new topic: I found a man page
after “sudo pacman -Syuu” , I was going to say solved but I was wrong, false alarm, sorry
korben
October 9, 2022, 9:01am
57
Lots of GB of data are left on my HDD, also the latest snapshot cannot be deleted.
In addition to that, I cannot make another manual snapshot due to the fact that each operation initiated by the user closes the GUI itself.
Should I provide logs from Timeshift now? I have no experience with Timeshift at all. Actually, I have used it for the first time in years.
Use the command line…
sudo timeshift --create --comments "Your comments go here"
For more information, please read through the whole thread.
Hi @Jim.B ,
Thank You, it works but it give Me an error message when trying to delete incomplete snapshots:
E: Failed to remove directory
Ret=256
I hope You take care of You
When cleaning up,
a snapshot can not be deleted by using rm !
(And not while you are inside the snapshot )
You have to use btrfs subvolume delete …
because a snapshot is a construct of btrfs and not part of the filesystem by itself.
You find good Information about Btrfs in the wiki
btrfs subvolume delete --help
Jim.B
October 10, 2022, 1:36am
61
Go to the folder where your snapshots are stored. Find the folder thats incomplete and delete it, its likely the smallest one. You can use sudo rm -r /path/to/timeshift/bad/snapshot
. Replace the path in that command with the path to the folder on your computer.
I had not read that you have btrfs… so as andreas85 said
There is also similar information at:
Mind you, the read only part is not in fstab, it is only in mtab, so that directory is mounted AFTER boot and is probably part of the BTRFS metadata somehow, it's a separate subvolume. When I run sudo btrfs subvolume list -r / I get the following...
good luck
I haven’t posted before, but I have also suffered with problem the mentioned in this thread. I downgraded to glib 2.72.3-3 and that worked for several days, but today timeshift crashed again midway through a snapshot so maybe glib isn’t all that is going on here?
CLI still works.
Manjaro Stable rsync snapshots.
