Okay, then the command to delete the snapshot is…
sudo rm -rf /timeshift/snapshots/2022-10-09_10-54-23
It truly is.
I have learned my lesson.
You are simply THE best forumers, hats down!
Well there is a Filebrowser available, for sure you can delete everything in Terminal but
you can screw sth up in Terminal also and the same goes to Filebrowser.
I would maybe more worried, when i copy + paste systemfiles in a filebrowser… when the access and security is demanding, but just deleting folder or files is another story. Go the easy path and find the middle way between safety and user experience.
