It is impossible to connect a Bluetooth speaker JBL Flip 5 and several other Bluetooth devices to the laptop.
system information, please
inxi -Fazy
Is it possible to connect any BT device?
You just spoke about those which you could not connect.
Why is the title of the post the same as the post itself?
The former should be short and descriptive - the latter should be longer and contain the details.
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already for your problem in the forum ? (Wisdom lies in asking → listening → reading )
