Bluetooth errors on 5.16.2 which should have been fixed in rc8
Hello
There seems to be a bluetooth related bug in the 5.16 kernel which causes the following error:
[   18.389157] Bluetooth: hci0: Failed to read codec capabilities (-56)
Apparently, this was fixed but I’m still getting the error…
dmesg | egrep -i "(intel|bluetooth)"
[sudo] password for maazb:
Identified face as maazb
[   11.845049] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[   15.089858] Intel(R) Wireless WiFi driver for Linux
[   15.243889] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[   15.355017] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[   15.362280] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   15.362585] intel_rapl_common: Found RAPL domain package
[   15.362588] intel_rapl_common: Found RAPL domain core
[   16.315303] Bluetooth: Core ver 2.22
[   16.315337] NET: Registered PF_BLUETOOTH protocol family
[   16.315338] Bluetooth: HCI device and connection manager initialized
[   16.315344] Bluetooth: HCI socket layer initialized
[   16.315347] Bluetooth: L2CAP socket layer initialized
[   16.315351] Bluetooth: SCO socket layer initialized
[   16.729191] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[   16.731173] Bluetooth: hci0: Device revision is 1
[   16.731176] Bluetooth: hci0: Secure boot is enabled
[   16.731177] Bluetooth: hci0: OTP lock is enabled
[   16.731178] Bluetooth: hci0: API lock is enabled
[   16.731178] Bluetooth: hci0: Debug lock is disabled
[   16.731179] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   16.739785] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[   16.739818] Bluetooth: hci0: Boot Address: 0x24800
[   16.739820] Bluetooth: hci0: Firmware Version: 125-46.21
[   18.211369] Bluetooth: hci0: Waiting for firmware download to complete
[   18.212124] Bluetooth: hci0: Firmware loaded in 1437826 usecs
[   18.212232] Bluetooth: hci0: Waiting for device to boot
[   18.227157] Bluetooth: hci0: Device booted in 14612 usecs
[   18.227276] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[   18.233168] Bluetooth: hci0: Applying Intel DDC parameters completed
[   18.236164] Bluetooth: hci0: Firmware revision 0.3 build 125 week 46 2021
[   18.392157] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.395158] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.398158] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.401147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.404147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.407154] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   19.899913] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.899917] Bluetooth: BNEP filters: protocol multicast
[   19.899923] Bluetooth: BNEP socket layer initialized
[   21.811717] Bluetooth: RFCOMM TTY layer initialized
[   21.811726] Bluetooth: RFCOMM socket layer initialized
[   21.811728] Bluetooth: RFCOMM ver 1.11
[   22.204160] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.207147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.210169] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.213161] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.216163] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.219133] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.222129] Bluetooth: hci0: Failed to read codec capabilities (-56)
[ 5882.097316] Bluetooth: hci0: Timed out waiting for suspend events
[ 5882.097324] Bluetooth: hci0: Suspend timeout bit: 6
[ 5882.097341] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[ 8712.369737] Bluetooth: hci0: Timed out waiting for suspend events
[ 8712.369749] Bluetooth: hci0: Suspend timeout bit: 6
[ 8712.369785] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[43300.386741] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[43300.386843] Bluetooth: hci0: Boot Address: 0x24800
[43300.386845] Bluetooth: hci0: Firmware Version: 125-46.21
[43300.386847] Bluetooth: hci0: Firmware already loaded
[43300.538732] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.541724] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.544710] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.547738] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.550732] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.553731] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.556732] Bluetooth: hci0: Failed to read codec capabilities (-56)
dmesg
[    0.000000] Linux version 5.16.2-1-MANJARO (bernhard@mk5) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Jan 20 17:33:11 CET 2022
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.16-x86_64 root=UUID=423d5eb4-3305-4b6c-93ed-e207306475a6 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor cryptdevice=UUID=b3474c04-99b8-4700-8764-db447f5c9e01:cr_root root=/dev/mapper/cr_root acpi_backlight=vendor udev.log_priority=3 resume=/dev/mapper/cr_swap
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 3376
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
[    0.000000] BIOS-e820: [mem 0x0000000009bff000-0x000000000a000fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000a001000-0x000000000a1fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000a20f000-0x00000000c983efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000c983f000-0x00000000cae3efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cae3f000-0x00000000caedefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000caedf000-0x00000000cc4defff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cc4df000-0x00000000cccdefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cccdf000-0x00000000ccdfefff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000ccdff000-0x00000000cdffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fdffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedc4000-0x00000000fedc9fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedcc000-0x00000000fedcefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedd5000-0x00000000fedd5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000040e2fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000040e300000-0x000000042fffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi: ACPI=0xcaede000 ACPI 2.0=0xcaede014 TPMFinalLog=0xcc496000 SMBIOS=0xccb7e000 SMBIOS 3.0=0xccb7d000 MEMATTR=0xc6430018 ESRT=0xc6465418
[    0.000000] SMBIOS 3.3.0 present.
[    0.000000] DMI: ASUSTeK COMPUTER INC. ZenBook UX325SA_UM325SA/UX325SA, BIOS UX325SA.301 04/01/2021
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1896.417 MHz processor
[    0.000150] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000151] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000155] last_pfn = 0x40e300 max_arch_pfn = 0x400000000
[    0.000844] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001125] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[    0.001133] last_pfn = 0xce000 max_arch_pfn = 0x400000000
[    0.003848] esrt: Reserving ESRT space from 0x00000000c6465418 to 0x00000000c6465450.
[    0.003852] e820: update [mem 0xc6465000-0xc6465fff] usable ==> reserved
[    0.003864] Using GB pages for direct mapping
[    0.004269] Secure boot disabled
[    0.004270] RAMDISK: [mem 0x3217b000-0x350b4fff]
[    0.004274] ACPI: Early table checksum verification disabled
[    0.004277] ACPI: RSDP 0x00000000CAEDE014 000024 (v02 _ASUS_)
[    0.004281] ACPI: XSDT 0x00000000CAEDD728 00010C (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.004285] ACPI: FACP 0x00000000CAECE000 000114 (v06 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.004289] ACPI: DSDT 0x00000000CAEC0000 00D035 (v02 _ASUS_ Notebook 01072009 INTL 20190509)
[    0.004291] ACPI: FACS 0x00000000CC494000 000040
[    0.004293] ACPI: MSDM 0x00000000CAEDC000 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
[    0.004294] ACPI: SSDT 0x00000000CAED4000 007229 (v02 AMD    AmdTable 00000002 MSFT 04000000)
[    0.004296] ACPI: IVRS 0x00000000CAED3000 0001A4 (v02 AMD    AmdTable 00000001 AMD  00000000)
[    0.004298] ACPI: SSDT 0x00000000CAECF000 003A21 (v01 AMD    AMD AOD  00000001 INTL 20190509)
[    0.004299] ACPI: FIDT 0x00000000CAEBF000 00009C (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.004301] ACPI: MCFG 0x00000000CAEBE000 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00010013)
[    0.004302] ACPI: HPET 0x00000000CAEBD000 000038 (v01 _ASUS_ Notebook 01072009 AMI  00000005)
[    0.004304] ACPI: VFCT 0x00000000CAEAF000 00D884 (v01 _ASUS_ Notebook 00000001 AMD  31504F47)
[    0.004305] ACPI: BGRT 0x00000000CAEAE000 000038 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.004307] ACPI: TPM2 0x00000000CAEAD000 00004C (v04 _ASUS_ Notebook 00000001 AMI  00000000)
[    0.004308] ACPI: SSDT 0x00000000CAEA7000 005354 (v02 AMD    AmdTable 00000001 AMD  00000001)
[    0.004310] ACPI: CRAT 0x00000000CAEA6000 000EE8 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.004311] ACPI: CDIT 0x00000000CAEA5000 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.004313] ACPI: SSDT 0x00000000CAEA4000 000149 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004314] ACPI: SSDT 0x00000000CAEA3000 00048C (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004316] ACPI: SSDT 0x00000000CAEA1000 001486 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004317] ACPI: SSDT 0x00000000CAE9F000 0014F6 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004319] ACPI: SSDT 0x00000000CAE9B000 0036E3 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004320] ACPI: WSMT 0x00000000CAE9A000 000028 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.004322] ACPI: APIC 0x00000000CAE99000 0000DE (v03 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.004323] ACPI: SSDT 0x00000000CAE98000 0000C6 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004325] ACPI: SSDT 0x00000000CAE97000 000917 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004326] ACPI: SSDT 0x00000000CAE95000 001215 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004328] ACPI: SSDT 0x00000000CAE94000 00004A (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004329] ACPI: SSDT 0x00000000CAE93000 000241 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004331] ACPI: SSDT 0x00000000CAE92000 00067A (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004332] ACPI: SSDT 0x00000000CAE91000 0007E4 (v01 AMD    AmdTable 00000001 INTL 20190509)
[    0.004334] ACPI: FPDT 0x00000000CAE90000 000044 (v01 _ASUS_ A M I    01072009 AMI  01000013)
[    0.004335] ACPI: Reserving FACP table memory at [mem 0xcaece000-0xcaece113]
[    0.004336] ACPI: Reserving DSDT table memory at [mem 0xcaec0000-0xcaecd034]
[    0.004336] ACPI: Reserving FACS table memory at [mem 0xcc494000-0xcc49403f]
[    0.004337] ACPI: Reserving MSDM table memory at [mem 0xcaedc000-0xcaedc054]
[    0.004337] ACPI: Reserving SSDT table memory at [mem 0xcaed4000-0xcaedb228]
[    0.004338] ACPI: Reserving IVRS table memory at [mem 0xcaed3000-0xcaed31a3]
[    0.004338] ACPI: Reserving SSDT table memory at [mem 0xcaecf000-0xcaed2a20]
[    0.004339] ACPI: Reserving FIDT table memory at [mem 0xcaebf000-0xcaebf09b]
[    0.004339] ACPI: Reserving MCFG table memory at [mem 0xcaebe000-0xcaebe03b]
[    0.004340] ACPI: Reserving HPET table memory at [mem 0xcaebd000-0xcaebd037]
[    0.004340] ACPI: Reserving VFCT table memory at [mem 0xcaeaf000-0xcaebc883]
[    0.004340] ACPI: Reserving BGRT table memory at [mem 0xcaeae000-0xcaeae037]
[    0.004341] ACPI: Reserving TPM2 table memory at [mem 0xcaead000-0xcaead04b]
[    0.004341] ACPI: Reserving SSDT table memory at [mem 0xcaea7000-0xcaeac353]
[    0.004342] ACPI: Reserving CRAT table memory at [mem 0xcaea6000-0xcaea6ee7]
[    0.004342] ACPI: Reserving CDIT table memory at [mem 0xcaea5000-0xcaea5028]
[    0.004343] ACPI: Reserving SSDT table memory at [mem 0xcaea4000-0xcaea4148]
[    0.004343] ACPI: Reserving SSDT table memory at [mem 0xcaea3000-0xcaea348b]
[    0.004344] ACPI: Reserving SSDT table memory at [mem 0xcaea1000-0xcaea2485]
[    0.004344] ACPI: Reserving SSDT table memory at [mem 0xcae9f000-0xcaea04f5]
[    0.004345] ACPI: Reserving SSDT table memory at [mem 0xcae9b000-0xcae9e6e2]
[    0.004345] ACPI: Reserving WSMT table memory at [mem 0xcae9a000-0xcae9a027]
[    0.004346] ACPI: Reserving APIC table memory at [mem 0xcae99000-0xcae990dd]
[    0.004346] ACPI: Reserving SSDT table memory at [mem 0xcae98000-0xcae980c5]
[    0.004346] ACPI: Reserving SSDT table memory at [mem 0xcae97000-0xcae97916]
[    0.004347] ACPI: Reserving SSDT table memory at [mem 0xcae95000-0xcae96214]
[    0.004347] ACPI: Reserving SSDT table memory at [mem 0xcae94000-0xcae94049]
[    0.004348] ACPI: Reserving SSDT table memory at [mem 0xcae93000-0xcae93240]
[    0.004348] ACPI: Reserving SSDT table memory at [mem 0xcae92000-0xcae92679]
[    0.004349] ACPI: Reserving SSDT table memory at [mem 0xcae91000-0xcae917e3]
[    0.004349] ACPI: Reserving FPDT table memory at [mem 0xcae90000-0xcae90043]
[    0.004402] No NUMA configuration found
[    0.004403] Faking a node at [mem 0x0000000000000000-0x000000040e2fffff]
[    0.004406] NODE_DATA(0) allocated [mem 0x40e2fc000-0x40e2fffff]
[    0.004427] Zone ranges:
[    0.004427]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.004428]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.004429]   Normal   [mem 0x0000000100000000-0x000000040e2fffff]
[    0.004430]   Device   empty
[    0.004430] Movable zone start for each node
[    0.004431] Early memory node ranges
[    0.004431]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.004432]   node   0: [mem 0x0000000000100000-0x0000000009bfefff]
[    0.004433]   node   0: [mem 0x000000000a001000-0x000000000a1fffff]
[    0.004433]   node   0: [mem 0x000000000a20f000-0x00000000c983efff]
[    0.004434]   node   0: [mem 0x00000000ccdff000-0x00000000cdffffff]
[    0.004434]   node   0: [mem 0x0000000100000000-0x000000040e2fffff]
[    0.004435] Initmem setup node 0 [mem 0x0000000000001000-0x000000040e2fffff]
[    0.004438] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.004450] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.004558] On node 0, zone DMA32: 1026 pages in unavailable ranges
[    0.008631] On node 0, zone DMA32: 15 pages in unavailable ranges
[    0.008753] On node 0, zone DMA32: 13760 pages in unavailable ranges
[    0.027260] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.027313] On node 0, zone Normal: 7424 pages in unavailable ranges
[    0.027515] ACPI: PM-Timer IO Port: 0x808
[    0.027521] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.027533] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[    0.027538] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[    0.027540] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.027541] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.027543] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.027544] ACPI: HPET id: 0x10228201 base: 0xfed00000
[    0.027552] e820: update [mem 0xc6909000-0xc6937fff] usable ==> reserved
[    0.027561] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[    0.027579] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.027581] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.027582] PM: hibernation: Registered nosave memory: [mem 0x09bff000-0x0a000fff]
[    0.027583] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20efff]
[    0.027584] PM: hibernation: Registered nosave memory: [mem 0xc6465000-0xc6465fff]
[    0.027585] PM: hibernation: Registered nosave memory: [mem 0xc6909000-0xc6937fff]
[    0.027586] PM: hibernation: Registered nosave memory: [mem 0xc983f000-0xcae3efff]
[    0.027586] PM: hibernation: Registered nosave memory: [mem 0xcae3f000-0xcaedefff]
[    0.027587] PM: hibernation: Registered nosave memory: [mem 0xcaedf000-0xcc4defff]
[    0.027587] PM: hibernation: Registered nosave memory: [mem 0xcc4df000-0xcccdefff]
[    0.027587] PM: hibernation: Registered nosave memory: [mem 0xcccdf000-0xccdfefff]
[    0.027588] PM: hibernation: Registered nosave memory: [mem 0xce000000-0xcfffffff]
[    0.027589] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xefffffff]
[    0.027589] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.027589] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfcffffff]
[    0.027590] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xfdffffff]
[    0.027590] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfeb7ffff]
[    0.027590] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[    0.027591] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[    0.027591] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.027591] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[    0.027592] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.027592] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[    0.027593] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[    0.027593] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[    0.027593] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[    0.027594] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc3fff]
[    0.027594] PM: hibernation: Registered nosave memory: [mem 0xfedc4000-0xfedc9fff]
[    0.027594] PM: hibernation: Registered nosave memory: [mem 0xfedca000-0xfedcbfff]
[    0.027595] PM: hibernation: Registered nosave memory: [mem 0xfedcc000-0xfedcefff]
[    0.027595] PM: hibernation: Registered nosave memory: [mem 0xfedcf000-0xfedd4fff]
[    0.027595] PM: hibernation: Registered nosave memory: [mem 0xfedd5000-0xfedd5fff]
[    0.027596] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[    0.027596] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.027597] [mem 0xd0000000-0xefffffff] available for PCI devices
[    0.027598] Booting paravirtualized kernel on bare hardware
[    0.027600] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.030556] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[    0.031034] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[    0.031039] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[    0.031041] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.031060] Fallback order for Node 0: 0
[    0.031063] Built 1 zonelists, mobility grouping on.  Total pages: 3969546
[    0.031064] Policy zone: Normal
[    0.031065] Kernel command line: BOOT_IMAGE=/vmlinuz-5.16-x86_64 root=UUID=423d5eb4-3305-4b6c-93ed-e207306475a6 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor cryptdevice=UUID=b3474c04-99b8-4700-8764-db447f5c9e01:cr_root root=/dev/mapper/cr_root acpi_backlight=vendor udev.log_priority=3 resume=/dev/mapper/cr_swap
[    0.031143] Unknown kernel command line parameters "BOOT_IMAGE=/vmlinuz-5.16-x86_64 cryptdevice=UUID=b3474c04-99b8-4700-8764-db447f5c9e01:cr_root", will be passed to user space.
[    0.032575] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.033330] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.033553] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.068743] Memory: 15613088K/16130872K available (16392K kernel code, 2115K rwdata, 11064K rodata, 1804K init, 3740K bss, 517524K reserved, 0K cma-reserved)
[    0.068750] random: get_random_u64 called from __kmem_cache_create+0x2a/0x560 with crng_init=0
[    0.068830] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.068839] ftrace: allocating 45442 entries in 178 pages
[    0.081008] ftrace: allocated 178 pages with 4 groups
[    0.081072] Dynamic Preempt: full
[    0.081101] rcu: Preemptible hierarchical RCU implementation.
[    0.081102] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.081102] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.081103] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.081104] 	Trampoline variant of Tasks RCU enabled.
[    0.081104] 	Rude variant of Tasks RCU enabled.
[    0.081104] 	Tracing variant of Tasks RCU enabled.
[    0.081105] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.081105] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.083079] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[    0.083327] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.083425] Console: colour dummy device 80x25
[    0.083433] printk: console [tty0] enabled
[    0.083448] ACPI: Core revision 20210930
[    0.083607] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.083623] APIC: Switch to symmetric I/O mode setup
[    0.084203] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
[    0.084204] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
[    0.084205] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
[    0.084205] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
[    0.084445] Switched APIC routing to physical flat.
[    0.085038] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.100297] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x36abe71c279, max_idle_ns: 881590718971 ns
[    0.100301] Calibrating delay loop (skipped), value calculated using timer frequency.. 3794.86 BogoMIPS (lpj=6321390)
[    0.100303] pid_max: default: 32768 minimum: 301
[    0.101834] LSM: Security Framework initializing
[    0.101842] landlock: Up and running.
[    0.101842] Yama: becoming mindful.
[    0.101860] AppArmor: AppArmor initialized
[    0.101901] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.101936] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.102134] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.102143] LVT offset 1 assigned for vector 0xf9
[    0.102156] LVT offset 2 assigned for vector 0xf4
[    0.102159] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[    0.102159] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[    0.102162] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.102165] Spectre V2 : Mitigation: Full AMD retpoline
[    0.102166] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.102166] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.102167] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.102168] Spectre V2 : User space: Mitigation: STIBP always-on protection
[    0.102170] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.106112] Freeing SMP alternatives memory: 36K
[    0.213496] smpboot: CPU0: AMD Ryzen 7 5800U with Radeon Graphics (family: 0x19, model: 0x50, stepping: 0x0)
[    0.213605] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.213609] ... version:                0
[    0.213610] ... bit width:              48
[    0.213610] ... generic registers:      6
[    0.213610] ... value mask:             0000ffffffffffff
[    0.213611] ... max period:             00007fffffffffff
[    0.213611] ... fixed-purpose events:   0
[    0.213611] ... event mask:             000000000000003f
[    0.213633] rcu: Hierarchical SRCU implementation.
[    0.213633] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.213633] smp: Bringing up secondary CPUs ...
[    0.213633] x86: Booting SMP configuration:
[    0.213633] .... node  #0, CPUs:        #1
[    0.213745] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[    0.213799]   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
[    0.243691] smp: Brought up 1 node, 16 CPUs
[    0.243691] smpboot: Max logical packages: 1
[    0.243691] smpboot: Total of 16 processors activated (60709.90 BogoMIPS)
[    0.247002] devtmpfs: initialized
[    0.247005] x86/mm: Memory block size: 128MB
[    0.247472] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20efff] (61440 bytes)
[    0.247472] ACPI: PM: Registering ACPI NVS region [mem 0xcaedf000-0xcc4defff] (23068672 bytes)
[    0.247472] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.247472] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.247472] pinctrl core: initialized pinctrl subsystem
[    0.247472] PM: RTC time: 19:33:20, date: 2022-01-28
[    0.247542] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.247711] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.247808] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.247904] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.247910] audit: initializing netlink subsys (disabled)
[    0.247915] audit: type=2000 audit(1643398400.163:1): state=initialized audit_enabled=0 res=1
[    0.247915] thermal_sys: Registered thermal governor 'fair_share'
[    0.247915] thermal_sys: Registered thermal governor 'bang_bang'
[    0.247915] thermal_sys: Registered thermal governor 'step_wise'
[    0.247915] thermal_sys: Registered thermal governor 'user_space'
[    0.247915] thermal_sys: Registered thermal governor 'power_allocator'
[    0.247915] cpuidle: using governor ladder
[    0.247915] cpuidle: using governor menu
[    0.247915] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[    0.247915] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.247915] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.247915] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.247915] PCI: Using configuration type 1 for base access
[    0.247915] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.247915] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[    0.247915] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.247915] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.247915] ACPI: Added _OSI(Module Device)
[    0.247915] ACPI: Added _OSI(Processor Device)
[    0.247915] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.247915] ACPI: Added _OSI(Processor Aggregator Device)
[    0.247915] ACPI: Added _OSI(Linux-Dell-Video)
[    0.247915] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.247915] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.259475] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.WLAN], AE_NOT_FOUND (20210930/dswload2-162)
[    0.259480] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210930/psobject-220)
[    0.259481] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[    0.261167] ACPI: 16 ACPI AML tables successfully acquired and loaded
[    0.262323] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.263942] ACPI: EC: EC started
[    0.263943] ACPI: EC: interrupt blocked
[    0.264004] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.264006] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[    0.264008] ACPI: Interpreter enabled
[    0.264020] ACPI: PM: (supports S0 S4 S5)
[    0.264020] ACPI: Using IOAPIC for interrupt routing
[    0.264189] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.264950] ACPI: PM: Power Resource [WRST]
[    0.265121] ACPI: PM: Power Resource [PWRE]
[    0.265633] ACPI: PM: Power Resource [P0U0]
[    0.265693] ACPI: PM: Power Resource [P3U0]
[    0.266018] ACPI: PM: Power Resource [P0U1]
[    0.266073] ACPI: PM: Power Resource [P3U1]
[    0.266880] ACPI: PM: Power Resource [P0NV]
[    0.271094] ACPI: PM: Power Resource [PRWL]
[    0.271561] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.271565] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.271628] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[    0.271741] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.271751] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[    0.272014] PCI host bridge to bus 0000:00
[    0.272015] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.272016] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.272017] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.272018] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.272019] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[    0.272019] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfebfffff window]
[    0.272020] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.272021] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.272031] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[    0.272107] pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
[    0.272177] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[    0.272227] pci 0000:00:01.1: [1022:1634] type 01 class 0x060400
[    0.272247] pci 0000:00:01.1: enabling Extended Tags
[    0.272277] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    0.272331] pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
[    0.272351] pci 0000:00:01.2: enabling Extended Tags
[    0.272378] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[    0.272431] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[    0.272482] pci 0000:00:02.4: [1022:1634] type 01 class 0x060400
[    0.272502] pci 0000:00:02.4: enabling Extended Tags
[    0.272531] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[    0.272585] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[    0.272633] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[    0.272652] pci 0000:00:08.1: enabling Extended Tags
[    0.272678] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.272757] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.272853] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.272954] pci 0000:00:18.0: [1022:166a] type 00 class 0x060000
[    0.272986] pci 0000:00:18.1: [1022:166b] type 00 class 0x060000
[    0.273016] pci 0000:00:18.2: [1022:166c] type 00 class 0x060000
[    0.273043] pci 0000:00:18.3: [1022:166d] type 00 class 0x060000
[    0.273073] pci 0000:00:18.4: [1022:166e] type 00 class 0x060000
[    0.273101] pci 0000:00:18.5: [1022:166f] type 00 class 0x060000
[    0.273134] pci 0000:00:18.6: [1022:1670] type 00 class 0x060000
[    0.273165] pci 0000:00:18.7: [1022:1671] type 00 class 0x060000
[    0.273278] pci 0000:01:00.0: [8086:2723] type 00 class 0x028000
[    0.273309] pci 0000:01:00.0: reg 0x10: [mem 0xfcf00000-0xfcf03fff 64bit]
[    0.273446] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.273593] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.273597] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.273665] pci 0000:02:00.0: [10ec:522a] type 00 class 0xff0000
[    0.273679] pci 0000:02:00.0: reg 0x10: [mem 0xfce00000-0xfce00fff]
[    0.273778] pci 0000:02:00.0: supports D1 D2
[    0.273779] pci 0000:02:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.273875] pci 0000:00:01.2: PCI bridge to [bus 02]
[    0.273879] pci 0000:00:01.2:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.273960] pci 0000:03:00.0: [1c5c:174a] type 00 class 0x010802
[    0.273975] pci 0000:03:00.0: reg 0x10: [mem 0xfcd00000-0xfcd03fff 64bit]
[    0.273982] pci 0000:03:00.0: reg 0x18: [mem 0xfcd05000-0xfcd05fff]
[    0.273989] pci 0000:03:00.0: reg 0x1c: [mem 0xfcd04000-0xfcd04fff]
[    0.274175] pci 0000:00:02.4: PCI bridge to [bus 03]
[    0.274179] pci 0000:00:02.4:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.274233] pci 0000:04:00.0: [1002:1638] type 00 class 0x030000
[    0.274243] pci 0000:04:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.274250] pci 0000:04:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.274255] pci 0000:04:00.0: reg 0x20: [io  0xf000-0xf0ff]
[    0.274259] pci 0000:04:00.0: reg 0x24: [mem 0xfcc00000-0xfcc7ffff]
[    0.274266] pci 0000:04:00.0: enabling Extended Tags
[    0.274277] pci 0000:04:00.0: BAR 0: assigned to efifb
[    0.274311] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.274342] pci 0000:04:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.274375] pci 0000:04:00.1: [1002:1637] type 00 class 0x040300
[    0.274383] pci 0000:04:00.1: reg 0x10: [mem 0xfccc8000-0xfcccbfff]
[    0.274408] pci 0000:04:00.1: enabling Extended Tags
[    0.274433] pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
[    0.274471] pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
[    0.274483] pci 0000:04:00.2: reg 0x18: [mem 0xfcb00000-0xfcbfffff]
[    0.274491] pci 0000:04:00.2: reg 0x24: [mem 0xfcccc000-0xfcccdfff]
[    0.274497] pci 0000:04:00.2: enabling Extended Tags
[    0.274571] pci 0000:04:00.3: [1022:1639] type 00 class 0x0c0330
[    0.274581] pci 0000:04:00.3: reg 0x10: [mem 0xfca00000-0xfcafffff 64bit]
[    0.274602] pci 0000:04:00.3: enabling Extended Tags
[    0.274629] pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
[    0.274670] pci 0000:04:00.4: [1022:1639] type 00 class 0x0c0330
[    0.274679] pci 0000:04:00.4: reg 0x10: [mem 0xfc900000-0xfc9fffff 64bit]
[    0.274701] pci 0000:04:00.4: enabling Extended Tags
[    0.274728] pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
[    0.274767] pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000
[    0.274773] pci 0000:04:00.5: reg 0x10: [mem 0xfcc80000-0xfccbffff]
[    0.274792] pci 0000:04:00.5: enabling Extended Tags
[    0.274817] pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
[    0.274855] pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
[    0.274862] pci 0000:04:00.6: reg 0x10: [mem 0xfccc0000-0xfccc7fff]
[    0.274888] pci 0000:04:00.6: enabling Extended Tags
[    0.274913] pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
[    0.274962] pci 0000:00:08.1: PCI bridge to [bus 04]
[    0.274965] pci 0000:00:08.1:   bridge window [io  0xf000-0xffff]
[    0.274966] pci 0000:00:08.1:   bridge window [mem 0xfc900000-0xfccfffff]
[    0.274969] pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.275632] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.275671] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.275703] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.275742] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.275777] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.275806] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.275836] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.275865] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.278808] ACPI: EC: interrupt unblocked
[    0.278809] ACPI: EC: event unblocked
[    0.278814] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.278814] ACPI: EC: GPE=0x3
[    0.278815] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[    0.278816] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[    0.278838] iommu: Default domain type: Translated
[    0.278838] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.278838] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.278838] pci 0000:04:00.0: vgaarb: bridge control possible
[    0.278838] pci 0000:04:00.0: vgaarb: setting as boot device
[    0.278838] vgaarb: loaded
[    0.278838] SCSI subsystem initialized
[    0.278838] libata version 3.00 loaded.
[    0.278838] ACPI: bus type USB registered
[    0.278838] usbcore: registered new interface driver usbfs
[    0.278838] usbcore: registered new interface driver hub
[    0.278838] usbcore: registered new device driver usb
[    0.281779] pps_core: LinuxPPS API ver. 1 registered
[    0.281780] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.281782] PTP clock support registered
[    0.281787] EDAC MC: Ver: 3.0.0
[    0.281851] Registered efivars operations
[    0.281851] NetLabel: Initializing
[    0.281851] NetLabel:  domain hash size = 128
[    0.281851] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.281851] NetLabel:  unlabeled traffic allowed by default
[    0.281851] PCI: Using ACPI for IRQ routing
[    0.286233] PCI: pci_cache_line_size set to 64 bytes
[    0.286294] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[    0.286296] e820: reserve RAM buffer [mem 0x09bff000-0x0bffffff]
[    0.286297] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    0.286298] e820: reserve RAM buffer [mem 0xc6465000-0xc7ffffff]
[    0.286298] e820: reserve RAM buffer [mem 0xc6909000-0xc7ffffff]
[    0.286299] e820: reserve RAM buffer [mem 0xc983f000-0xcbffffff]
[    0.286299] e820: reserve RAM buffer [mem 0xce000000-0xcfffffff]
[    0.286300] e820: reserve RAM buffer [mem 0x40e300000-0x40fffffff]
[    0.286325] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.286325] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.288022] clocksource: Switched to clocksource tsc-early
[    0.292779] VFS: Disk quotas dquot_6.6.0
[    0.292789] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.292857] AppArmor: AppArmor Filesystem Enabled
[    0.292876] pnp: PnP ACPI init
[    0.292929] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.293164] system 00:03: [io  0x04d0-0x04d1] has been reserved
[    0.293166] system 00:03: [io  0x040b] has been reserved
[    0.293167] system 00:03: [io  0x04d6] has been reserved
[    0.293167] system 00:03: [io  0x0c00-0x0c01] has been reserved
[    0.293168] system 00:03: [io  0x0c14] has been reserved
[    0.293168] system 00:03: [io  0x0c50-0x0c51] has been reserved
[    0.293169] system 00:03: [io  0x0c52] has been reserved
[    0.293170] system 00:03: [io  0x0c6c] has been reserved
[    0.293170] system 00:03: [io  0x0c6f] has been reserved
[    0.293171] system 00:03: [io  0x0cd8-0x0cdf] has been reserved
[    0.293171] system 00:03: [io  0x0800-0x089f] has been reserved
[    0.293172] system 00:03: [io  0x0b00-0x0b0f] has been reserved
[    0.293173] system 00:03: [io  0x0b20-0x0b3f] has been reserved
[    0.293173] system 00:03: [io  0x0900-0x090f] has been reserved
[    0.293174] system 00:03: [io  0x0910-0x091f] has been reserved
[    0.293175] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.293176] system 00:03: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.293177] system 00:03: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.293178] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.293178] system 00:03: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.293179] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.293180] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[    0.293762] pnp: PnP ACPI: found 4 devices
[    0.298956] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.299013] NET: Registered PF_INET protocol family
[    0.299237] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.300413] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.300519] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.300672] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.300743] TCP: Hash tables configured (established 131072 bind 65536)
[    0.300815] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.300870] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.300912] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.300960] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.300964] NET: Registered PF_XDP protocol family
[    0.300967] pci 0000:00:01.2: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.300969] pci 0000:00:01.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.300975] pci 0000:00:01.2: BAR 15: assigned [mem 0xe0200000-0xe03fffff 64bit pref]
[    0.300977] pci 0000:00:01.2: BAR 13: assigned [io  0x1000-0x1fff]
[    0.300978] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.300981] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.300985] pci 0000:00:01.2: PCI bridge to [bus 02]
[    0.300986] pci 0000:00:01.2:   bridge window [io  0x1000-0x1fff]
[    0.300988] pci 0000:00:01.2:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.300989] pci 0000:00:01.2:   bridge window [mem 0xe0200000-0xe03fffff 64bit pref]
[    0.300992] pci 0000:00:02.4: PCI bridge to [bus 03]
[    0.300994] pci 0000:00:02.4:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.300997] pci 0000:00:08.1: PCI bridge to [bus 04]
[    0.300998] pci 0000:00:08.1:   bridge window [io  0xf000-0xffff]
[    0.301000] pci 0000:00:08.1:   bridge window [mem 0xfc900000-0xfccfffff]
[    0.301002] pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.301004] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.301005] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.301006] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.301006] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.301007] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[    0.301007] pci_bus 0000:00: resource 9 [mem 0xd0000000-0xfebfffff window]
[    0.301008] pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
[    0.301009] pci_bus 0000:01: resource 1 [mem 0xfcf00000-0xfcffffff]
[    0.301009] pci_bus 0000:02: resource 0 [io  0x1000-0x1fff]
[    0.301010] pci_bus 0000:02: resource 1 [mem 0xfce00000-0xfcefffff]
[    0.301010] pci_bus 0000:02: resource 2 [mem 0xe0200000-0xe03fffff 64bit pref]
[    0.301011] pci_bus 0000:03: resource 1 [mem 0xfcd00000-0xfcdfffff]
[    0.301012] pci_bus 0000:04: resource 0 [io  0xf000-0xffff]
[    0.301012] pci_bus 0000:04: resource 1 [mem 0xfc900000-0xfccfffff]
[    0.301013] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.301090] pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
[    0.301112] pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
[    0.301207] pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
[    0.301254] PCI: CLS 64 bytes, default 64
[    0.301263] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.301289] pci 0000:00:00.2: can't derive routing for PCI INT A
[    0.301290] pci 0000:00:00.2: PCI INT A: not connected
[    0.301302] pci 0000:00:01.0: Adding to iommu group 0
[    0.301302] Trying to unpack rootfs image as initramfs...
[    0.301307] pci 0000:00:01.1: Adding to iommu group 1
[    0.301312] pci 0000:00:01.2: Adding to iommu group 2
[    0.301318] pci 0000:00:02.0: Adding to iommu group 3
[    0.301322] pci 0000:00:02.4: Adding to iommu group 4
[    0.301328] pci 0000:00:08.0: Adding to iommu group 5
[    0.301332] pci 0000:00:08.1: Adding to iommu group 5
[    0.301338] pci 0000:00:14.0: Adding to iommu group 6
[    0.301341] pci 0000:00:14.3: Adding to iommu group 6
[    0.301353] pci 0000:00:18.0: Adding to iommu group 7
[    0.301356] pci 0000:00:18.1: Adding to iommu group 7
[    0.301360] pci 0000:00:18.2: Adding to iommu group 7
[    0.301363] pci 0000:00:18.3: Adding to iommu group 7
[    0.301367] pci 0000:00:18.4: Adding to iommu group 7
[    0.301370] pci 0000:00:18.5: Adding to iommu group 7
[    0.301374] pci 0000:00:18.6: Adding to iommu group 7
[    0.301378] pci 0000:00:18.7: Adding to iommu group 7
[    0.301383] pci 0000:01:00.0: Adding to iommu group 8
[    0.301388] pci 0000:02:00.0: Adding to iommu group 9
[    0.301392] pci 0000:03:00.0: Adding to iommu group 10
[    0.301403] pci 0000:04:00.0: Adding to iommu group 5
[    0.301405] pci 0000:04:00.1: Adding to iommu group 5
[    0.301407] pci 0000:04:00.2: Adding to iommu group 5
[    0.301409] pci 0000:04:00.3: Adding to iommu group 5
[    0.301411] pci 0000:04:00.4: Adding to iommu group 5
[    0.301415] pci 0000:04:00.5: Adding to iommu group 5
[    0.301418] pci 0000:04:00.6: Adding to iommu group 5
[    0.302540] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.302542] AMD-Vi: Extended features (0x206d73ef22254ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[    0.302546] AMD-Vi: Interrupt remapping enabled
[    0.302546] AMD-Vi: Virtual APIC enabled
[    0.302546] AMD-Vi: X2APIC enabled
[    0.331744] software IO TLB: tearing down default memory pool
[    0.332232] LVT offset 0 assigned for vector 0x400
[    0.332467] perf: AMD IBS detected (0x000003ff)
[    0.332472] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.333908] Initialise system trusted keyrings
[    0.333916] Key type blacklist registered
[    0.333944] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.334548] zbud: loaded
[    0.337626] Key type asymmetric registered
[    0.337627] Asymmetric key parser 'x509' registered
[    0.337646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.337679] io scheduler mq-deadline registered
[    0.337680] io scheduler kyber registered
[    0.337698] io scheduler bfq registered
[    0.337990] pcieport 0000:00:01.1: PME: Signaling with IRQ 26
[    0.338074] pcieport 0000:00:01.2: PME: Signaling with IRQ 27
[    0.338086] pcieport 0000:00:01.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    0.338196] pcieport 0000:00:02.4: PME: Signaling with IRQ 28
[    0.338278] pcieport 0000:00:08.1: PME: Signaling with IRQ 29
[    0.338337] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.341321] ACPI: AC: AC Adapter [ACAD] (off-line)
[    0.341362] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:33/PNP0C09:00/PNP0C0D:00/input/input0
[    0.341377] ACPI: button: Lid Switch [LID0]
[    0.341392] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.341400] ACPI: button: Power Button [PWRB]
[    0.341468] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1726
[    0.341482] Monitor-Mwait will be used to enter C-1 state
[    0.341485] ACPI: \_SB_.PLTF.P000: Found 3 idle states
[    0.341607] ACPI: \_SB_.PLTF.P001: Found 3 idle states
[    0.341683] ACPI: \_SB_.PLTF.P002: Found 3 idle states
[    0.341743] ACPI: \_SB_.PLTF.P003: Found 3 idle states
[    0.341856] ACPI: \_SB_.PLTF.P004: Found 3 idle states
[    0.342032] ACPI: \_SB_.PLTF.P005: Found 3 idle states
[    0.342156] ACPI: \_SB_.PLTF.P006: Found 3 idle states
[    0.342293] ACPI: \_SB_.PLTF.P007: Found 3 idle states
[    0.342404] ACPI: \_SB_.PLTF.P008: Found 3 idle states
[    0.342524] ACPI: \_SB_.PLTF.P009: Found 3 idle states
[    0.342644] ACPI: \_SB_.PLTF.P00A: Found 3 idle states
[    0.342764] ACPI: \_SB_.PLTF.P00B: Found 3 idle states
[    0.342886] ACPI: \_SB_.PLTF.P00C: Found 3 idle states
[    0.343009] ACPI: \_SB_.PLTF.P00D: Found 3 idle states
[    0.343110] ACPI: \_SB_.PLTF.P00E: Found 3 idle states
[    0.343218] ACPI: \_SB_.PLTF.P00F: Found 3 idle states
[    0.343508] thermal LNXTHERM:00: registered as thermal_zone0
[    0.343509] ACPI: thermal: Thermal Zone [TZ0] (0 C)
[    0.343611] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.344075] ACPI: battery: Slot [BATT] (battery present)
[    0.344395] Non-volatile memory driver v1.3
[    0.344396] Linux agpgart interface v0.103
[    0.344431] AMD-Vi: AMD IOMMUv2 loaded and initialized
[    0.344485] ACPI: bus type drm_connector registered
[    0.345371] nvme 0000:03:00.0: platform quirk: setting simple suspend
[    0.345395] nvme nvme0: pci function 0000:03:00.0
[    0.345480] libphy: Fixed MDIO Bus: probed
[    0.345488] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.345490] ehci-pci: EHCI PCI platform driver
[    0.345496] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.345501] ohci-pci: OHCI PCI platform driver
[    0.345507] uhci_hcd: USB Universal Host Controller Interface driver
[    0.345538] usbcore: registered new interface driver usbserial_generic
[    0.345541] usbserial: USB Serial support registered for generic
[    0.345591] rtc_cmos 00:01: RTC can wake from S4
[    0.345772] rtc_cmos 00:01: registered as rtc0
[    0.345802] rtc_cmos 00:01: setting system clock to 2022-01-28T19:33:20 UTC (1643398400)
[    0.345811] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.346020] ledtrig-cpu: registered to indicate activity on CPUs
[    0.346113] efifb: probing for efifb
[    0.346121] efifb: showing boot graphics
[    0.347591] efifb: framebuffer at 0xd0000000, using 8128k, total 8128k
[    0.347592] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.347593] efifb: scrolling: redraw
[    0.347593] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.347618] fbcon: Deferring console take-over
[    0.347619] fb0: EFI VGA frame buffer device
[    0.347634] hid: raw HID events driver (C) Jiri Kosina
[    0.347670] ashmem: initialized
[    0.347712] drop_monitor: Initializing network drop monitor service
[    0.347758] Initializing XFRM netlink socket
[    0.347804] NET: Registered PF_INET6 protocol family
[    0.420817] nvme nvme0: 16/0/0 default/read/poll queues
[    0.427181]  nvme0n1: p1 p2 p3 p4 p5 p6 p7
[    0.660454] Freeing initrd memory: 48360K
[    0.664173] Segment Routing with IPv6
[    0.664176] RPL Segment Routing with IPv6
[    0.664217] In-situ OAM (IOAM) with IPv6
[    0.664279] NET: Registered PF_PACKET protocol family
[    0.665209] microcode: CPU0: patch_level=0x0a50000c
[    0.665215] microcode: CPU1: patch_level=0x0a50000c
[    0.665229] microcode: CPU2: patch_level=0x0a50000c
[    0.665236] microcode: CPU3: patch_level=0x0a50000c
[    0.665242] microcode: CPU4: patch_level=0x0a50000c
[    0.665246] microcode: CPU5: patch_level=0x0a50000c
[    0.665260] microcode: CPU6: patch_level=0x0a50000c
[    0.665269] microcode: CPU7: patch_level=0x0a50000c
[    0.665277] microcode: CPU8: patch_level=0x0a50000c
[    0.665284] microcode: CPU9: patch_level=0x0a50000c
[    0.665291] microcode: CPU10: patch_level=0x0a50000c
[    0.665298] microcode: CPU11: patch_level=0x0a50000c
[    0.665318] microcode: CPU12: patch_level=0x0a50000c
[    0.665326] microcode: CPU13: patch_level=0x0a50000c
[    0.665342] microcode: CPU14: patch_level=0x0a50000c
[    0.665349] microcode: CPU15: patch_level=0x0a50000c
[    0.665352] microcode: Microcode Update Driver: v2.2.
[    0.665559] resctrl: L3 allocation detected
[    0.665560] resctrl: MB allocation detected
[    0.665560] resctrl: L3 monitoring detected
[    0.665563] IPI shorthand broadcast: enabled
[    0.665571] sched_clock: Marking stable (665180609, 365633)->(670209113, -4662871)
[    0.665904] registered taskstats version 1
[    0.666345] Loading compiled-in X.509 certificates
[    0.668141] Loaded X.509 cert 'Build time autogenerated kernel key: d5fe13df3eca5581c2cc832e3f935f0384928e8f'
[    0.671168] zswap: loaded using pool zstd/z3fold
[    0.671679] Key type ._fscrypt registered
[    0.671680] Key type .fscrypt registered
[    0.671681] Key type fscrypt-provisioning registered
[    0.671711] AppArmor: AppArmor sha1 policy hashing enabled
[    0.672659] PM:   Magic number: 6:120:598
[    0.672838] RAS: Correctable Errors collector initialized.
[    0.673652] Freeing unused decrypted memory: 2036K
[    0.673937] Freeing unused kernel image (initmem) memory: 1804K
[    0.712258] Write protecting the kernel read-only data: 30720k
[    0.712954] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    0.713265] Freeing unused kernel image (rodata/data gap) memory: 1224K
[    0.735043] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.735048] rodata_test: all tests were successful
[    0.735062] Run /init as init process
[    0.735063]   with arguments:
[    0.735064]     /init
[    0.735065]   with environment:
[    0.735065]     HOME=/
[    0.735066]     TERM=linux
[    0.735066]     BOOT_IMAGE=/vmlinuz-5.16-x86_64
[    0.735067]     cryptdevice=UUID=b3474c04-99b8-4700-8764-db447f5c9e01:cr_root
[    0.846006] [drm] amdgpu kernel modesetting enabled.
[    0.851638] amdgpu: Virtual CRAT table created for CPU
[    0.851644] amdgpu: Topology: Add CPU node
[    0.851696] checking generic (d0000000 7f0000) vs hw (d0000000 10000000)
[    0.851698] checking generic (d0000000 7f0000) vs hw (d0000000 10000000)
[    0.851698] fb0: switching to amdgpu from EFI VGA
[    0.851755] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[    0.851802] amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
[    0.851852] [drm] initializing kernel modesetting (RENOIR 0x1002:0x1638 0x1043:0x161C 0xC1).
[    0.851854] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
[    0.851907] [drm] register mmio base: 0xFCC00000
[    0.851908] [drm] register mmio size: 524288
[    0.853061] [drm] add ip block number 0 <soc15_common>
[    0.853062] [drm] add ip block number 1 <gmc_v9_0>
[    0.853063] [drm] add ip block number 2 <vega10_ih>
[    0.853063] [drm] add ip block number 3 <psp>
[    0.853064] [drm] add ip block number 4 <smu>
[    0.853064] [drm] add ip block number 5 <dm>
[    0.853065] [drm] add ip block number 6 <gfx_v9_0>
[    0.853065] [drm] add ip block number 7 <sdma_v4_0>
[    0.853066] [drm] add ip block number 8 <vcn_v2_0>
[    0.853067] [drm] add ip block number 9 <jpeg_v2_0>
[    0.853082] amdgpu 0000:04:00.0: amdgpu: Fetched VBIOS from VFCT
[    0.853083] amdgpu: ATOM BIOS: 113-CEZANNE-018
[    0.853124] [drm] VCN decode is enabled in VM mode
[    0.853124] [drm] VCN encode is enabled in VM mode
[    0.853124] [drm] JPEG decode is enabled in VM mode
[    0.853125] amdgpu 0000:04:00.0: amdgpu: PCIE atomic ops is not supported
[    0.853145] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[    0.853150] amdgpu 0000:04:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[    0.853151] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[    0.853152] amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[    0.853157] [drm] Detected VRAM RAM=512M, BAR=512M
[    0.853158] [drm] RAM width 128bits DDR4
[    0.853181] [drm] amdgpu: 512M of VRAM memory ready
[    0.853182] [drm] amdgpu: 3072M of GTT memory ready.
[    0.853184] [drm] GART: num cpu pages 262144, num gpu pages 262144
[    0.853304] [drm] PCIE GART of 1024M enabled.
[    0.853306] [drm] PTB located at 0x000000F400900000
[    0.853469] amdgpu 0000:04:00.0: amdgpu: PSP runtime database doesn't exist
[    0.853505] [drm] Loading DMUB firmware via PSP: version=0x0101001C
[    0.854345] [drm] Found VCN firmware Version ENC: 1.16 DEC: 5 VEP: 0 Revision: 3
[    0.854349] amdgpu 0000:04:00.0: amdgpu: Will use PSP to load VCN firmware
[    1.333655] tsc: Refined TSC clocksource calibration: 1896.437 MHz
[    1.333659] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x36ac0c539a6, max_idle_ns: 881590694765 ns
[    1.334239] clocksource: Switched to clocksource tsc
[    1.594760] [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
[    1.697925] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[    1.707393] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[    1.707398] amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[    1.708863] amdgpu 0000:04:00.0: amdgpu: SMU is initialized successfully!
[    1.709071] [drm] Display Core initialized with v3.2.160!
[    1.709736] [drm] DMUB hardware initialized: version=0x0101001C
[    1.850123] [drm] kiq ring mec 2 pipe 1 q 0
[    1.853162] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[    1.853184] [drm] JPEG decode initialized successfully.
[    1.854653] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[    1.882159] memmap_init_zone_device initialised 131072 pages in 0ms
[    1.882170] amdgpu: HMM registered 512MB device memory
[    1.882217] amdgpu: SRAT table not found
[    1.882218] amdgpu: Virtual CRAT table created for GPU
[    1.882289] amdgpu: Topology: Add dGPU node [0x1638:0x1002]
[    1.882293] kfd kfd: amdgpu: added device 1002:1638
[    1.882455] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 8, active_cu_number 8
[    1.885660] [drm] fb mappable at 0x410CD3000
[    1.885664] [drm] vram apper at 0x410000000
[    1.885665] [drm] size 8294400
[    1.885665] [drm] fb depth is 24
[    1.885666] [drm]    pitch is 7680
[    1.885791] fbcon: amdgpudrmfb (fb0) is primary device
[    1.885792] fbcon: Deferring console take-over
[    1.885795] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    1.921289] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[    1.921299] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[    1.921302] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[    1.921304] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[    1.921306] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[    1.921308] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[    1.921310] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[    1.921312] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[    1.921313] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[    1.921317] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[    1.921320] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[    1.921325] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[    1.921327] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[    1.921329] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[    1.921332] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[    1.923868] [drm] Initialized amdgpu 3.44.0 20150101 for 0000:04:00.0 on minor 0
[    1.926810] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    1.933527] ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    1.933899] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:00/input/input2
[    1.938292] asus_wmi: ASUS WMI generic driver loaded
[    1.962313] device-mapper: uevent: version 1.0.3
[    1.962348] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    1.968752] Key type encrypted registered
[    2.037514] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    2.037516] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    2.038595] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.043314] xhci_hcd 0000:04:00.3: xHCI Host Controller
[    2.043320] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
[    2.043413] xhci_hcd 0000:04:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[    2.043711] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[    2.043713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.043714] usb usb1: Product: xHCI Host Controller
[    2.043715] usb usb1: Manufacturer: Linux 5.16.2-1-MANJARO xhci-hcd
[    2.043716] usb usb1: SerialNumber: 0000:04:00.3
[    2.043838] hub 1-0:1.0: USB hub found
[    2.043868] hub 1-0:1.0: 4 ports detected
[    2.044062] xhci_hcd 0000:04:00.3: xHCI Host Controller
[    2.044064] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
[    2.044066] xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    2.044077] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.044089] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
[    2.044091] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.044092] usb usb2: Product: xHCI Host Controller
[    2.044093] usb usb2: Manufacturer: Linux 5.16.2-1-MANJARO xhci-hcd
[    2.044094] usb usb2: SerialNumber: 0000:04:00.3
[    2.044144] hub 2-0:1.0: USB hub found
[    2.044149] hub 2-0:1.0: 2 ports detected
[    2.044289] xhci_hcd 0000:04:00.4: xHCI Host Controller
[    2.044292] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
[    2.044383] xhci_hcd 0000:04:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[    2.044667] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[    2.044668] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.044669] usb usb3: Product: xHCI Host Controller
[    2.044670] usb usb3: Manufacturer: Linux 5.16.2-1-MANJARO xhci-hcd
[    2.044670] usb usb3: SerialNumber: 0000:04:00.4
[    2.044723] hub 3-0:1.0: USB hub found
[    2.044728] hub 3-0:1.0: 4 ports detected
[    2.044899] xhci_hcd 0000:04:00.4: xHCI Host Controller
[    2.044903] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
[    2.044907] xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[    2.044914] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.044924] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
[    2.044925] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.044926] usb usb4: Product: xHCI Host Controller
[    2.044926] usb usb4: Manufacturer: Linux 5.16.2-1-MANJARO xhci-hcd
[    2.044927] usb usb4: SerialNumber: 0000:04:00.4
[    2.044976] hub 4-0:1.0: USB hub found
[    2.044980] hub 4-0:1.0: 2 ports detected
[    2.048761] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    2.097259] rtsx_pci 0000:02:00.0: enabling device (0000 -> 0002)
[    2.101384] ccp 0000:04:00.2: enabling device (0000 -> 0002)
[    2.101573] ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[    2.106918] cryptd: max_cpu_qlen set to 1000
[    2.111724] ccp 0000:04:00.2: tee enabled
[    2.111728] ccp 0000:04:00.2: psp enabled
[    2.120206] AVX2 version of gcm_enc/dec engaged.
[    2.120256] AES CTR mode by8 optimization enabled
[    2.231620] fbcon: Taking over console
[    2.294237] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[    2.437789] usb 1-3: New USB device found, idVendor=13d3, idProduct=56eb, bcdDevice=19.64
[    2.437798] usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.437803] usb 1-3: Product: USB2.0 HD UVC WebCam
[    2.437805] usb 1-3: Manufacturer: Azurewave
[    2.437807] usb 1-3: SerialNumber: 0x0001
[    2.537959] Console: switching to colour frame buffer device 240x67
[    2.570566] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[    2.738417] usb 1-4: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[    2.738430] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.974165] random: fast init done
[    8.858375] random: crng init done
[   11.775177] raid6: skip pq benchmark and using algorithm avx2x4
[   11.775181] raid6: using avx2x2 recovery algorithm
[   11.777201] xor: automatically using best checksumming function   avx
[   11.845049] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[   11.845417] BTRFS: device label manjaro-root devid 1 transid 72904 /dev/dm-0 scanned by systemd-udevd (362)
[   11.913986] BTRFS info (device dm-0): flagging fs with big metadata feature
[   11.913993] BTRFS info (device dm-0): disk space caching is enabled
[   11.913995] BTRFS info (device dm-0): has skinny extents
[   11.920468] BTRFS info (device dm-0): enabling ssd optimizations
[   14.352457] PM: Image not found (code -22)
[   14.367795] BTRFS info (device dm-0): flagging fs with big metadata feature
[   14.367798] BTRFS info (device dm-0): disk space caching is enabled
[   14.367799] BTRFS info (device dm-0): has skinny extents
[   14.375443] BTRFS info (device dm-0): enabling ssd optimizations
[   14.454269] systemd[1]: systemd 250.2-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[   14.470851] systemd[1]: Detected architecture x86-64.
[   14.471761] systemd[1]: Hostname set to <zenbook-ws>.
[   14.554247] systemd[1]: Queued start job for default target Graphical Interface.
[   14.601135] systemd[1]: Created slice Slice /system/getty.
[   14.601662] systemd[1]: Created slice Slice /system/modprobe.
[   14.601868] systemd[1]: Created slice Cryptsetup Units Slice.
[   14.602047] systemd[1]: Created slice Slice /system/systemd-fsck.
[   14.602191] systemd[1]: Created slice User and Session Slice.
[   14.602236] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   14.602261] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   14.602401] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   14.602469] systemd[1]: Reached target Login Prompts.
[   14.602480] systemd[1]: Reached target Local Integrity Protected Volumes.
[   14.602499] systemd[1]: Reached target Path Units.
[   14.602510] systemd[1]: Reached target Remote File Systems.
[   14.602519] systemd[1]: Reached target Slice Units.
[   14.602540] systemd[1]: Reached target Local Verity Protected Volumes.
[   14.602579] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   14.602963] systemd[1]: Listening on LVM2 poll daemon socket.
[   14.603712] systemd[1]: Listening on Process Core Dump Socket.
[   14.603972] systemd[1]: Listening on Journal Audit Socket.
[   14.604046] systemd[1]: Listening on Journal Socket (/dev/log).
[   14.604108] systemd[1]: Listening on Journal Socket.
[   14.604389] systemd[1]: Listening on udev Control Socket.
[   14.604439] systemd[1]: Listening on udev Kernel Socket.
[   14.604998] systemd[1]: Mounting Huge Pages File System...
[   14.605447] systemd[1]: Mounting POSIX Message Queue File System...
[   14.605973] systemd[1]: Mounting Kernel Debug File System...
[   14.606469] systemd[1]: Mounting Kernel Trace File System...
[   14.607031] systemd[1]: Starting Create List of Static Device Nodes...
[   14.607507] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   14.607956] systemd[1]: Starting Load Kernel Module configfs...
[   14.608377] systemd[1]: Starting Load Kernel Module drm...
[   14.608834] systemd[1]: Starting Load Kernel Module fuse...
[   14.609551] systemd[1]: Starting Load Kernel Modules...
[   14.610113] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.610162] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[   14.610766] systemd[1]: Starting Coldplug All udev Devices...
[   14.611860] systemd[1]: Mounted Huge Pages File System.
[   14.611930] systemd[1]: Mounted POSIX Message Queue File System.
[   14.611980] systemd[1]: Mounted Kernel Debug File System.
[   14.612026] systemd[1]: Mounted Kernel Trace File System.
[   14.612185] systemd[1]: Finished Create List of Static Device Nodes.
[   14.612381] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   14.612464] systemd[1]: Finished Load Kernel Module configfs.
[   14.612620] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.612710] systemd[1]: Finished Load Kernel Module drm.
[   14.613450] systemd[1]: Mounting Kernel Configuration File System...
[   14.615795] systemd[1]: Mounted Kernel Configuration File System.
[   14.624822] fuse: init (API version 7.35)
[   14.625461] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   14.625549] systemd[1]: Finished Load Kernel Module fuse.
[   14.626159] systemd[1]: Mounting FUSE Control File System...
[   14.627277] systemd[1]: Mounted FUSE Control File System.
[   14.631053] IPMI message handler: version 39.2
[   14.634179] ipmi device interface
[   14.647153] vboxdrv: loading out-of-tree module taints kernel.
[   14.647330] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   14.650825] vboxdrv: Found 16 processor cores
[   14.663468] systemd[1]: Finished Coldplug All udev Devices.
[   14.673959] vboxdrv: TSC mode is Invariant, tentative frequency 1896436777 Hz
[   14.673961] vboxdrv: Successfully loaded version 6.1.30 r148432 (interface 0x00320000)
[   14.675881] BTRFS info (device dm-0): enabling auto defrag
[   14.675884] BTRFS info (device dm-0): use zstd compression, level 3
[   14.675886] BTRFS info (device dm-0): disk space caching is enabled
[   14.676599] VBoxNetAdp: Successfully started.
[   14.676693] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.676796] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.677673] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.678624] systemd[1]: Starting Load/Save Random Seed...
[   14.678695] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.679384] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.680627] VBoxNetFlt: Successfully started.
[   14.681410] systemd[1]: Finished Load Kernel Modules.
[   14.682232] systemd[1]: Starting Apply Kernel Variables...
[   14.685176] systemd[1]: Finished Load/Save Random Seed.
[   14.685278] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.685547] systemd[1]: Finished Apply Kernel Variables.
[   14.686995] systemd[1]: Starting CLI Netfilter Manager...
[   14.693423] systemd[1]: Finished Create Static Device Nodes in /dev.
[   14.693489] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[   14.694905] systemd[1]: Starting Journal Service...
[   14.696000] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   14.714232] audit: type=1325 audit(1643398414.865:2): table=filter family=10 entries=0 op=xt_register pid=602 subj==unconfined comm="ip6tables"
[   14.715504] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   14.715550] audit: type=1130 audit(1643398414.865:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.715662] systemd[1]: Reached target Preparation for Local File Systems.
[   14.715713] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[   14.715737] audit: type=1325 audit(1643398414.865:4): table=filter family=2 entries=4 op=xt_replace pid=607 subj==unconfined comm="iptables-restor"
[   14.715757] audit: type=1300 audit(1643398414.865:4): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5559905dd8c0 items=0 ppid=597 pid=607 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables-restor" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[   14.715760] audit: type=1327 audit(1643398414.865:4): proctitle=69707461626C65732D726573746F7265002D6E
[   14.718188] audit: type=1325 audit(1643398414.868:5): table=filter family=2 entries=4 op=xt_replace pid=610 subj==unconfined comm="iptables-restor"
[   14.718192] audit: type=1300 audit(1643398414.868:5): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=56225a95c940 items=0 ppid=597 pid=610 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables-restor" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[   14.718195] audit: type=1327 audit(1643398414.868:5): proctitle=69707461626C65732D726573746F7265002D6E
[   14.729011] systemd[1]: Started Rule-based Manager for Device Events and Files.
[   14.729078] audit: type=1130 audit(1643398414.878:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.730459] systemd[1]: Started Journal Service.
[   14.730552] audit: type=1130 audit(1643398414.881:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.828283] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xff00, revision 15
[   14.828293] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[   14.833621] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xff20
[   14.872663] input: PC Speaker as /devices/platform/pcspkr/input/input4
[   14.882849] input: ASUE140A:00 04F3:3134 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input5
[   14.882915] input: ASUE140A:00 04F3:3134 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input6
[   14.882969] input: ASUE140A:00 04F3:3134 Keyboard as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input7
[   14.883093] hid-generic 0018:04F3:3134.0001: input,hidraw0: I2C HID v1.00 Mouse [ASUE140A:00 04F3:3134] on i2c-ASUE140A:00
[   14.887070] asus_wmi: Initialization: 0x1
[   14.887240] asus_wmi: SFUN value: 0x21
[   14.887243] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[   14.887247] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[   14.891263] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input8
[   14.897412] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[   14.897613] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[   14.897621] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[   14.898404] ACPI: battery: new extension: ASUS Battery Extension
[   14.906732] snd_rn_pci_acp3x 0000:04:00.5: enabling device (0000 -> 0002)
[   14.907137] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[   14.907139] RAPL PMU: hw unit of domain package 2^-16 Joules
[   14.963510] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   15.006100] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.039018] BTRFS info (device dm-0): devid 1 device path /dev/mapper/cr_root changed to /dev/dm-0 scanned by systemd-udevd (663)
[   15.043726] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   15.089858] Intel(R) Wireless WiFi driver for Linux
[   15.090047] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[   15.097529] BTRFS info (device dm-0): devid 1 device path /dev/dm-0 changed to /dev/mapper/cr_root scanned by systemd-udevd (663)
[   15.101828] iwlwifi 0000:01:00.0: api flags index 2 larger than supported by driver
[   15.101859] iwlwifi 0000:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[   15.102672] iwlwifi 0000:01:00.0: loaded firmware version 67.8f59b80b.0 cc-a0-67.ucode op_mode iwlmvm
[   15.108929] Adding 15608828k swap on /dev/mapper/cr_swap.  Priority:-2 extents:1 across:15608828k SSFS
[   15.114828] SVM: TSC scaling supported
[   15.114833] kvm: Nested Virtualization enabled
[   15.114835] SVM: kvm: Nested Paging enabled
[   15.114863] SVM: Virtual VMLOAD VMSAVE supported
[   15.114864] SVM: Virtual GIF supported
[   15.114865] SVM: LBR virtualization supported
[   15.225684] MCE: In-kernel MCE decoding enabled.
[   15.243889] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[   15.355017] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[   15.357169] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input9
[   15.362280] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   15.362585] intel_rapl_common: Found RAPL domain package
[   15.362588] intel_rapl_common: Found RAPL domain core
[   15.371034] thermal thermal_zone1: failed to read out thermal zone (-61)
[   15.400661] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input10
[   15.400748] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input11
[   15.410592] input: ASUE140A:00 04F3:3134 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input12
[   15.410710] input: ASUE140A:00 04F3:3134 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input13
[   15.410781] input: ASUE140A:00 04F3:3134 Keyboard as /devices/platform/AMDI0010:03/i2c-0/i2c-ASUE140A:00/0018:04F3:3134.0001/input/input14
[   15.410944] hid-multitouch 0018:04F3:3134.0001: input,hidraw0: I2C HID v1.00 Mouse [ASUE140A:00 04F3:3134] on i2c-ASUE140A:00
[   15.414775] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[   15.414789] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   15.414791] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   15.414793] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   15.414795] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   15.490236] iwlwifi 0000:01:00.0: Detected RF HR B3, rfid=0x10a100
[   15.494762] mousedev: PS/2 mouse device common for all mice
[   15.555850] iwlwifi 0000:01:00.0: base HW address: b4:0e:de:2a:7d:fd
[   15.572053] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
[   15.623648] systemd-journald[600]: Received client request to flush runtime journal.
[   16.125466] mc: Linux media interface: v0.10
[   16.187030] ucsi_acpi USBC000:00: PPM init failed (-110)
[   16.307265] videodev: Linux video capture interface: v2.00
[   16.315303] Bluetooth: Core ver 2.22
[   16.315337] NET: Registered PF_BLUETOOTH protocol family
[   16.315338] Bluetooth: HCI device and connection manager initialized
[   16.315344] Bluetooth: HCI socket layer initialized
[   16.315347] Bluetooth: L2CAP socket layer initialized
[   16.315351] Bluetooth: SCO socket layer initialized
[   16.724610] usb 1-3: Found UVC 1.10 device USB2.0 HD UVC WebCam (13d3:56eb)
[   16.726388] usbcore: registered new interface driver btusb
[   16.729191] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[   16.731173] Bluetooth: hci0: Device revision is 1
[   16.731176] Bluetooth: hci0: Secure boot is enabled
[   16.731177] Bluetooth: hci0: OTP lock is enabled
[   16.731178] Bluetooth: hci0: API lock is enabled
[   16.731178] Bluetooth: hci0: Debug lock is disabled
[   16.731179] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   16.731516] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/input/input15
[   16.732249] usb 1-3: Found UVC 1.50 device USB2.0 HD UVC WebCam (13d3:56eb)
[   16.733816] input: USB2.0 HD UVC WebCam: USB2.0 IR as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.2/input/input16
[   16.733918] usbcore: registered new interface driver uvcvideo
[   16.739785] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[   16.739818] Bluetooth: hci0: Boot Address: 0x24800
[   16.739820] Bluetooth: hci0: Firmware Version: 125-46.21
[   18.211369] Bluetooth: hci0: Waiting for firmware download to complete
[   18.212124] Bluetooth: hci0: Firmware loaded in 1437826 usecs
[   18.212232] Bluetooth: hci0: Waiting for device to boot
[   18.227157] Bluetooth: hci0: Device booted in 14612 usecs
[   18.227276] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[   18.233168] Bluetooth: hci0: Applying Intel DDC parameters completed
[   18.236164] Bluetooth: hci0: Firmware revision 0.3 build 125 week 46 2021
[   18.389157] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.392157] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.395158] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.398158] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.401147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.404147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   18.407154] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   19.760038] F2FS-fs (dm-2): Mounted with checkpoint version = 1b14a94d
[   19.809371] kauditd_printk_skb: 74 callbacks suppressed
[   19.809377] audit: type=1130 audit(1643398419.958:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.823825] audit: type=1130 audit(1643398419.975:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.824625] audit: type=1334 audit(1643398419.975:39): prog-id=9 op=LOAD
[   19.828640] audit: type=1127 audit(1643398419.978:40): pid=1271 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[   19.830763] audit: type=1130 audit(1643398419.981:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.849006] audit: type=1130 audit(1643398419.998:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.854851] audit: type=1130 audit(1643398420.005:43): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=clamav-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.857155] audit: type=1130 audit(1643398420.008:44): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.860609] audit: type=1334 audit(1643398420.011:45): prog-id=10 op=LOAD
[   19.860743] audit: type=1334 audit(1643398420.011:46): prog-id=11 op=LOAD
[   19.899913] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.899917] Bluetooth: BNEP filters: protocol multicast
[   19.899923] Bluetooth: BNEP socket layer initialized
[   19.909430] NET: Registered PF_ALG protocol family
[   19.980601] NET: Registered PF_QIPCRTR protocol family
[   21.811717] Bluetooth: RFCOMM TTY layer initialized
[   21.811726] Bluetooth: RFCOMM socket layer initialized
[   21.811728] Bluetooth: RFCOMM ver 1.11
[   22.083055] rfkill: input handler disabled
[   22.204160] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.207147] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.210169] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.213161] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.216163] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.219133] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   22.222129] Bluetooth: hci0: Failed to read codec capabilities (-56)
[   26.089614] wlp1s0: authenticate with 68:ff:7b:de:ef:aa
[   26.093204] wlp1s0: send auth to 68:ff:7b:de:ef:aa (try 1/3)
[   26.184871] wlp1s0: authenticated
[   26.187484] wlp1s0: associate with 68:ff:7b:de:ef:aa (try 1/3)
[   26.188628] wlp1s0: RX AssocResp from 68:ff:7b:de:ef:aa (capab=0x111 status=0 aid=2)
[   26.193664] wlp1s0: associated
[   26.534886] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[   26.557455] kauditd_printk_skb: 48 callbacks suppressed
[   26.557458] audit: type=1130 audit(1643398426.708:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.585182] audit: type=1130 audit(1643398426.735:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=clamav-freshclam comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.769526] audit: type=1400 audit(1643398426.918:91): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=2111 comm="apparmor_parser"
[   26.769534] audit: type=1300 audit(1643398426.918:91): arch=c000003e syscall=1 success=yes exit=7945 a0=4 a1=56452a666fc0 a2=1f09 a3=0 items=0 ppid=2110 pid=2111 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[   26.769537] audit: type=1327 audit(1643398426.918:91): proctitle=61707061726D6F725F706172736572002D4B72002F7661722F6C69622F646F636B65722F313030302E313030312F746D702F646F636B65722D64656661756C74313631373730383538
[   26.809634] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   26.814992] Bridge firewalling registered
[   26.830621] audit: type=1325 audit(1643398426.965:92): table=nat family=2 entries=0 op=xt_register pid=2113 subj==unconfined comm="iptables"
[   26.830629] audit: type=1300 audit(1643398426.965:92): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffed836ded0 items=0 ppid=2074 pid=2113 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[   26.830633] audit: type=1327 audit(1643398426.965:92): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D74006E6174002D4C002D6E
[   26.845540] audit: type=1325 audit(1643398426.995:93): table=nat family=2 entries=5 op=xt_replace pid=2134 subj==unconfined comm="iptables"
[   26.845548] audit: type=1300 audit(1643398426.995:93): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5645fc139a60 items=0 ppid=2074 pid=2134 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[   36.002819] kauditd_printk_skb: 119 callbacks suppressed
[   36.002825] audit: type=1334 audit(1643398436.151:136): prog-id=22 op=LOAD
[   36.040222] audit: type=1130 audit(1643398436.188:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.676338] audit: type=1100 audit(1643398439.825:138): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   39.677507] audit: type=1101 audit(1643398439.828:139): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   39.678057] audit: type=1110 audit(1643398439.828:140): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   39.679424] audit: type=1105 audit(1643398439.828:141): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   39.690875] audit: type=1106 audit(1643398439.841:142): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   39.690907] audit: type=1104 audit(1643398439.841:143): pid=2508 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   52.757459] audit: type=1131 audit(1643398452.316:144): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.844775] audit: type=1131 audit(1643398452.402:145): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.946114] audit: type=1334 audit(1643398452.502:146): prog-id=0 op=UNLOAD
[   52.946122] audit: type=1334 audit(1643398452.502:147): prog-id=0 op=UNLOAD
[   52.946125] audit: type=1334 audit(1643398452.502:148): prog-id=0 op=UNLOAD
[   53.157520] audit: type=1334 audit(1643398452.716:149): prog-id=0 op=UNLOAD
[   53.157540] audit: type=1334 audit(1643398452.716:150): prog-id=0 op=UNLOAD
[   53.157547] audit: type=1334 audit(1643398452.716:151): prog-id=0 op=UNLOAD
[   66.032877] audit: type=1131 audit(1643398465.589:152): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   66.125843] audit: type=1334 audit(1643398465.682:153): prog-id=0 op=UNLOAD
[   69.287652] input: CX 6.00BT (AVRCP) as /devices/virtual/input/input17
[   82.006862] audit: type=1131 audit(1643398481.562:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  876.044597] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[  915.658303] audit: type=1130 audit(1643399315.249:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  915.658311] audit: type=1131 audit(1643399315.249:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2126.351494] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 3500.974646] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 4246.996009] audit: type=1130 audit(1643402646.610:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4257.007983] audit: type=1131 audit(1643402656.620:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5876.348615] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 5878.653293] audit: type=1130 audit(1643404278.271:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5878.654144] wlp1s0: deauthenticating from 68:ff:7b:de:ef:aa by local choice (Reason: 3=DEAUTH_LEAVING)
[ 5879.947374] PM: suspend entry (s2idle)
[ 5879.960264] Filesystems sync: 0.012 seconds
[ 5882.097316] Bluetooth: hci0: Timed out waiting for suspend events
[ 5882.097324] Bluetooth: hci0: Suspend timeout bit: 6
[ 5882.097341] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[ 5882.097344] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 5882.099529] OOM killer disabled.
[ 5882.099530] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 5882.100791] printk: Suspending console(s) (use no_console_suspend to debug)
[ 5882.263904] ACPI: EC: interrupt blocked
[ 6222.315947] ACPI: EC: interrupt unblocked
[ 6222.350970] [drm] PCIE GART of 1024M enabled.
[ 6222.350979] [drm] PTB located at 0x000000F400900000
[ 6222.351013] amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
[ 6222.353520] amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
[ 6222.354681] amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
[ 6222.355521] [drm] DMUB hardware initialized: version=0x0101001C
[ 6222.404329] nvme nvme0: 16/0/0 default/read/poll queues
[ 6222.449333] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6222.449636] [drm] JPEG decode initialized successfully.
[ 6222.449653] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 6222.449658] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6222.449661] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6222.449662] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 6222.449664] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 6222.449666] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 6222.449667] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 6222.449669] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 6222.449670] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 6222.449672] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 6222.449674] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 6222.449675] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 6222.449677] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 6222.449678] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 6222.449679] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 6222.643471] OOM killer enabled.
[ 6222.643476] Restarting tasks ... done.
[ 6222.647870] PM: suspend exit
[ 6222.805089] audit: type=1130 audit(1643404622.489:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6222.805098] audit: type=1131 audit(1643404622.489:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6222.841596] audit: type=1130 audit(1643404622.526:162): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6222.841604] audit: type=1131 audit(1643404622.526:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6224.103975] audit: type=1334 audit(1643404623.786:164): prog-id=23 op=LOAD
[ 6224.142242] audit: type=1130 audit(1643404623.826:165): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6227.889776] audit: type=1100 audit(1643404627.573:166): pid=8565 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[ 6227.891565] audit: type=1101 audit(1643404627.576:167): pid=8565 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[ 6227.892571] audit: type=1110 audit(1643404627.576:168): pid=8565 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[ 6228.652309] audit: type=1131 audit(1643404628.336:169): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6228.881391] wlp1s0: authenticate with 68:ff:7b:de:ef:aa
[ 6228.884678] wlp1s0: send auth to 68:ff:7b:de:ef:aa (try 1/3)
[ 6228.976928] wlp1s0: authenticated
[ 6228.978116] wlp1s0: associate with 68:ff:7b:de:ef:aa (try 1/3)
[ 6228.979274] wlp1s0: RX AssocResp from 68:ff:7b:de:ef:aa (capab=0x111 status=0 aid=2)
[ 6228.985360] wlp1s0: associated
[ 6229.302589] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[ 6229.386978] audit: type=1130 audit(1643404629.069:170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6239.398567] audit: type=1131 audit(1643404639.083:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6253.957536] audit: type=1131 audit(1643404653.639:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6254.032978] audit: type=1334 audit(1643404653.716:173): prog-id=0 op=UNLOAD
[ 6285.473002] input: CX 6.00BT (AVRCP) as /devices/virtual/input/input18
[ 6376.161000] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6568.377284] [UFW BLOCK] IN=wlp1s0 OUT= MAC=b4:0e:de:2a:7d:fd:98:da:c4:02:9f:20:08:00 SRC=216.58.196.65 DST=192.168.15.135 LEN=1278 TOS=0x00 PREC=0x60 TTL=62 ID=0 DF PROTO=UDP SPT=443 DPT=45293 LEN=1258
[ 6568.377304] [UFW BLOCK] IN=wlp1s0 OUT= MAC=b4:0e:de:2a:7d:fd:98:da:c4:02:9f:20:08:00 SRC=216.58.196.65 DST=192.168.15.135 LEN=1278 TOS=0x00 PREC=0x60 TTL=62 ID=0 DF PROTO=UDP SPT=443 DPT=45293 LEN=1258
[ 6568.377312] [UFW BLOCK] IN=wlp1s0 OUT= MAC=b4:0e:de:2a:7d:fd:98:da:c4:02:9f:20:08:00 SRC=216.58.196.65 DST=192.168.15.135 LEN=1278 TOS=0x00 PREC=0x60 TTL=62 ID=0 DF PROTO=UDP SPT=443 DPT=45293 LEN=1258
[ 6568.377320] [UFW BLOCK] IN=wlp1s0 OUT= MAC=b4:0e:de:2a:7d:fd:98:da:c4:02:9f:20:08:00 SRC=216.58.196.65 DST=192.168.15.135 LEN=1278 TOS=0x00 PREC=0x60 TTL=62 ID=0 DF PROTO=UDP SPT=443 DPT=45293 LEN=1258
[ 7001.109151] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8001.355734] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8708.802885] audit: type=1130 audit(1643407108.445:174): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8708.803613] wlp1s0: deauthenticating from 68:ff:7b:de:ef:aa by local choice (Reason: 3=DEAUTH_LEAVING)
[ 8710.197958] PM: suspend entry (s2idle)
[ 8710.211123] Filesystems sync: 0.013 seconds
[ 8712.369737] Bluetooth: hci0: Timed out waiting for suspend events
[ 8712.369749] Bluetooth: hci0: Suspend timeout bit: 6
[ 8712.369785] Bluetooth: hci0: Suspend notifier action (3) failed: -110
[ 8712.369791] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 8712.372350] OOM killer disabled.
[ 8712.372350] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 8712.373550] printk: Suspending console(s) (use no_console_suspend to debug)
[ 8712.545773] ACPI: EC: interrupt blocked
[33657.794527] ACPI: EC: interrupt unblocked
[33657.830905] [drm] PCIE GART of 1024M enabled.
[33657.830921] [drm] PTB located at 0x000000F400900000
[33657.830945] amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
[33657.833404] amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
[33657.834577] amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
[33657.835437] [drm] DMUB hardware initialized: version=0x0101001C
[33657.868286] nvme nvme0: 16/0/0 default/read/poll queues
[33657.928848] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[33657.929337] [drm] JPEG decode initialized successfully.
[33657.929353] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[33657.929359] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[33657.929361] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[33657.929363] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[33657.929364] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[33657.929366] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[33657.929367] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[33657.929369] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[33657.929371] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[33657.929373] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[33657.929374] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[33657.929376] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[33657.929377] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[33657.929378] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[33657.929379] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[33658.122545] OOM killer enabled.
[33658.122549] Restarting tasks ... done.
[33658.126334] PM: suspend exit
[33658.267241] audit: type=1130 audit(1643432058.469:175): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33658.267247] audit: type=1131 audit(1643432058.469:176): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33658.293423] audit: type=1130 audit(1643432058.496:177): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33658.293429] audit: type=1131 audit(1643432058.496:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33659.746776] audit: type=1334 audit(1643432059.949:179): prog-id=24 op=LOAD
[33659.785125] audit: type=1130 audit(1643432059.989:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33661.916866] audit: type=1100 audit(1643432062.119:181): pid=12165 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[33661.919528] audit: type=1101 audit(1643432062.122:182): pid=12165 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[33661.920507] audit: type=1110 audit(1643432062.122:183): pid=12165 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[33663.940250] wlp1s0: authenticate with 68:ff:7b:de:ef:aa
[33663.946614] wlp1s0: send auth to 68:ff:7b:de:ef:aa (try 1/3)
[33663.974574] wlp1s0: authenticated
[33663.978449] wlp1s0: associate with 68:ff:7b:de:ef:aa (try 1/3)
[33663.979812] wlp1s0: RX AssocResp from 68:ff:7b:de:ef:aa (capab=0x111 status=0 aid=2)
[33663.983753] wlp1s0: associated
[33664.000479] audit: type=1131 audit(1643432064.202:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33664.292841] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[33664.636654] audit: type=1130 audit(1643432064.839:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33674.641820] audit: type=1131 audit(1643432074.841:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33690.189763] audit: type=1131 audit(1643432090.390:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33690.280872] audit: type=1334 audit(1643432090.483:188): prog-id=0 op=UNLOAD
[34375.884398] [UFW BLOCK] IN=wlp1s0 OUT= MAC=01:00:5e:00:00:01:98:da:c4:02:9f:20:08:00 SRC=192.168.15.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[35197.376364] audit: type=1130 audit(1643433597.512:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35197.377368] wlp1s0: deauthenticating from 68:ff:7b:de:ef:aa by local choice (Reason: 3=DEAUTH_LEAVING)
[35198.759728] PM: suspend entry (s2idle)
[35198.780765] Filesystems sync: 0.021 seconds
[35199.055324] Freezing user space processes ... (elapsed 0.002 seconds) done.
[35199.057826] OOM killer disabled.
[35199.057828] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[35199.059095] printk: Suspending console(s) (use no_console_suspend to debug)
[35199.320966] ACPI: EC: interrupt blocked
[43299.655566] ACPI: EC: interrupt unblocked
[43299.688855] [drm] PCIE GART of 1024M enabled.
[43299.688864] [drm] PTB located at 0x000000F400900000
[43299.688886] amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
[43299.690634] amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
[43299.692404] amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
[43299.693356] [drm] DMUB hardware initialized: version=0x0101001C
[43299.735470] nvme nvme0: 16/0/0 default/read/poll queues
[43299.787036] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[43299.787628] [drm] JPEG decode initialized successfully.
[43299.787645] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[43299.787650] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[43299.787653] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[43299.787654] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[43299.787656] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[43299.787658] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[43299.787659] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[43299.787661] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[43299.787662] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[43299.787664] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[43299.787666] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[43299.787667] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[43299.787668] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[43299.787670] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[43299.787671] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[43299.944024] usb 1-3: reset high-speed USB device number 2 using xhci_hcd
[43300.208081] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[43300.373114] OOM killer enabled.
[43300.373117] Restarting tasks ... done.
[43300.380002] PM: suspend exit
[43300.386741] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[43300.386843] Bluetooth: hci0: Boot Address: 0x24800
[43300.386845] Bluetooth: hci0: Firmware Version: 125-46.21
[43300.386847] Bluetooth: hci0: Firmware already loaded
[43300.413719] audit: type=1130 audit(1643441700.756:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43300.538732] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.541724] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.543625] audit: type=1130 audit(1643441700.886:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43300.543629] audit: type=1131 audit(1643441700.886:192): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43300.544710] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.547738] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.550732] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.553731] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.556732] Bluetooth: hci0: Failed to read codec capabilities (-56)
[43300.574597] audit: type=1130 audit(1643441700.916:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43300.574606] audit: type=1131 audit(1643441700.916:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bat-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43301.420360] audit: type=1334 audit(1643441701.763:195): prog-id=25 op=LOAD
[43301.457793] audit: type=1130 audit(1643441701.800:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43303.513040] audit: type=1100 audit(1643441703.857:197): pid=15080 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[43303.514852] audit: type=1101 audit(1643441703.857:198): pid=15080 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[43303.516287] audit: type=1110 audit(1643441703.860:199): pid=15080 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="maazb" exe="/usr/lib/gdm-session-worker" hostname=zenbook-ws addr=? terminal=/dev/tty1 res=success'
[43305.420013] audit: type=1131 audit(1643441705.764:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43306.412591] wlp1s0: authenticate with 68:ff:7b:de:ef:aa
[43306.418771] wlp1s0: send auth to 68:ff:7b:de:ef:aa (try 1/3)
[43306.508380] wlp1s0: authenticated
[43306.511920] wlp1s0: associate with 68:ff:7b:de:ef:aa (try 1/3)
[43306.513266] wlp1s0: RX AssocResp from 68:ff:7b:de:ef:aa (capab=0x111 status=0 aid=3)
[43306.519424] wlp1s0: associated
[43306.859709] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[43307.660752] audit: type=1131 audit(1643441708.004:201): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43309.642568] audit: type=1130 audit(1643441709.988:202): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43315.187471] audit: type=1100 audit(1643441715.532:203): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_python acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43315.188632] audit: type=1101 audit(1643441715.532:204): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43315.189232] audit: type=1110 audit(1643441715.532:205): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43315.192247] audit: type=1105 audit(1643441715.535:206): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43315.199131] audit: type=1106 audit(1643441715.542:207): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43315.199199] audit: type=1104 audit(1643441715.542:208): pid=15574 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[43319.652510] audit: type=1131 audit(1643441719.995:209): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43331.519498] audit: type=1131 audit(1643441731.867:210): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[43331.589125] audit: type=1334 audit(1643441731.937:211): prog-id=0 op=UNLOAD
[44409.936674] audit: type=1334 audit(1643442810.361:212): prog-id=26 op=LOAD
[44409.973597] audit: type=1130 audit(1643442810.398:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44413.802938] audit: type=1100 audit(1643442814.228:214): pid=16787 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_python acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[44413.804165] audit: type=1101 audit(1643442814.231:215): pid=16787 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="maazb" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[44413.805789] audit: type=1110 audit(1643442814.231:216): pid=16787 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_python acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[44413.808624] audit: type=1105 audit(1643442814.235:217): pid=16787 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
inxi -Fazy
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/vmlinuz-5.16-x86_64
    root=UUID=423d5eb4-3305-4b6c-93ed-e207306475a6 rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    cryptdevice=UUID=b3474c04-99b8-4700-8764-db447f5c9e01:cr_root
    root=/dev/mapper/cr_root acpi_backlight=vendor udev.log_priority=3
    resume=/dev/mapper/cr_swap
  Console: pty pts/0 wm: gnome-shell DM: GDM 41.3 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ZenBook UX325SA_UM325SA v: 1.0
    serial: <filter>
  Mobo: ASUSTeK model: UX325SA v: 1.0 serial: <filter>
    UEFI: American Megatrends LLC. v: UX325SA.301 date: 04/01/2021
  ID-1: BATT charge: 42.7 Wh (65.1%) condition: 65.6/67.1 Wh (97.8%)
    volts: 15.9 min: 15.9 model: ASUSTeK UX325 type: Li-ion serial: <filter>
    status: Discharging cycles: 44
  Info: model: AMD Ryzen 7 5800U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1618 high: 1900 min/max: 1600/4505 boost: enabled
    base/boost: 1900/4450 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1600 2: 1600 3: 1600 4: 1600
    5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
    13: 1600 14: 1600 15: 1600 16: 1900 bogomips: 60717
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-3:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
  Display: server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: amdgpu note: n/a (using device driver)
  Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: ASUSTeK driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: no
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
    chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Local Storage: total: 953.87 GiB used: 252.56 GiB (26.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 59.6 GiB size: 59.6 GiB (100.00%) used: 11.86 GiB (19.9%)
    fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0 mapped: cr_root
  ID-2: /boot raw-size: 488 MiB size: 447.1 MiB (91.62%)
    used: 144.5 MiB (32.3%) fs: ext4 block-size: 1024 B dev: /dev/nvme0n1p2
    maj-min: 259:2
  ID-3: /boot/efi raw-size: 488 MiB size: 487 MiB (99.80%)
    used: 27.6 MiB (5.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-4: /home raw-size: 788.99 GiB size: 788.98 GiB (100.00%)
    used: 240.53 GiB (30.5%) fs: f2fs block-size: 4096 B dev: /dev/dm-2
    maj-min: 254:2 mapped: cr_home
  ID-5: /var/log raw-size: 59.6 GiB size: 59.6 GiB (100.00%)
    used: 11.86 GiB (19.9%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
  ID-1: swap-1 type: partition size: 14.89 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: cr_swap
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Processes: 420 Uptime: 12h 21m wakeups: 2632 Memory: 15.08 GiB
  used: 3.72 GiB (24.7%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1246 lib: 361 Shell: Zsh (sudo)
  v: 5.8 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Note: Other than the general flakyness of the Intel AX200 on Linux - my bluetooth seems to be working fine.
