Thunderbolt not detected after update
#1
After Stable Update 2-19-19, my thunderbolt is dead and I can no longer use my docking station. Gnome reports that Thunderbolt could not be detected.
After the update, I started receiving errors about /usr/bin/boltctl already existing and was unable to update other applications. I manually removed bolt, deleted this file, and then reinstalled bolt and related packages, but I’m unable to get my thunderbolt to re-enable.
[Stable Update] 2019-02-19 - Kernels, KDE, LibreOffice, Systemd, VirtualBox, Deepin, Qt, Firmwares, Wine
Missing /var/lib/pacman/local/bolt-0.7-2/desc after an update
#2
Did you reboot after the update? You need to do that when you update the kernel otherwise new devices and drivers won’t work.
#3
Yes, I have multiple times, and also checked to make sure nothing changed in the BIOS.
#4
Have you looked at dmesg?
#5
I didn’t realise who had asked the question when I replied (I looked at the question, thought, “Oh, another kernel-update-needs-a-reboot-question”), but @asynec isn’t someone to ask questions without having tried stuff.
Therefore I’d assume there’s a regression somewhere, e.g. in a kernel driver or module.
#6
aw, shucks @jonathon
That means a lot! I sometimes feel like I still have noob tendencies, but I’ve learned a lot from you guys.
I took a peak at dmesg and didn’t see anything of interest, but I could be missing something:
[xps@xps-laptop ~]$ dmesg
[    0.000000] Linux version 4.14.101-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Fri Feb 15 21:24:02 UTC 2019
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=8a536a03-dfe7-489f-9756-8e6c0dbd0040 rw quiet resume=UUID=c37a09e3-58f8-4066-84d4-b8d8b929c9ec
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000002ce0afff] usable
[    0.000000] BIOS-e820: [mem 0x000000002ce0b000-0x000000002ce0bfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000002ce0c000-0x000000002ce0cfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000002ce0d000-0x000000003e3ddfff] usable
[    0.000000] BIOS-e820: [mem 0x000000003e3de000-0x000000003e7a0fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000003e7a1000-0x000000003e7edfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000003e7ee000-0x000000003f13afff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000003f13b000-0x000000003ff31fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000003ff32000-0x000000003fffefff] type 20
[    0.000000] BIOS-e820: [mem 0x000000003ffff000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x0000000047ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000048000000-0x00000000485fffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000048600000-0x000000004e7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004af7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.40 by American Megatrends
[    0.000000] efi:  ACPI=0x3e7b0000  ACPI 2.0=0x3e7b0000  SMBIOS=0x3fc83000  SMBIOS 3.0=0x3fc82000  ESRT=0x3fc54018  MPS=0xfcd70  MEMATTR=0x3bb67018
[    0.000000] SMBIOS 3.1.1 present.
[    0.000000] DMI: Dell Inc. XPS 15 9575/0C32VW, BIOS 1.2.0 10/10/2018
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x4af800 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: write-back
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0080000000 mask 7F80000000 uncachable
[    0.000000]   1 base 0060000000 mask 7FE0000000 uncachable
[    0.000000]   2 base 0050000000 mask 7FF0000000 uncachable
[    0.000000]   3 base 004C000000 mask 7FFC000000 uncachable
[    0.000000]   4 base 004A000000 mask 7FFE000000 uncachable
[    0.000000]   5 base 2000000000 mask 7000000000 uncachable
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] e820: last_pfn = 0x48600 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd0c0-0x000fd0cf] mapped at [ffffffffff2400c0]
[    0.000000] esrt: Reserving ESRT space from 0x000000003fc54018 to 0x000000003fc54050.
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff964c40097000] 97000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x1ba63c000, 0x1ba63cfff] PGTABLE
[    0.000000] BRK [0x1ba63d000, 0x1ba63dfff] PGTABLE
[    0.000000] BRK [0x1ba63e000, 0x1ba63efff] PGTABLE
[    0.000000] BRK [0x1ba63f000, 0x1ba63ffff] PGTABLE
[    0.000000] BRK [0x1ba640000, 0x1ba640fff] PGTABLE
[    0.000000] BRK [0x1ba641000, 0x1ba641fff] PGTABLE
[    0.000000] BRK [0x1ba642000, 0x1ba642fff] PGTABLE
[    0.000000] BRK [0x1ba643000, 0x1ba643fff] PGTABLE
[    0.000000] BRK [0x1ba644000, 0x1ba644fff] PGTABLE
[    0.000000] Secure boot could not be determined
[    0.000000] RAMDISK: [mem 0x36b5f000-0x375a6fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x000000003E7B0000 000024 (v02 DELL  )
[    0.000000] ACPI: XSDT 0x000000003E7B00D0 000124 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x000000003E7D98B8 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x000000003E7B0288 02962E (v02 DELL   CBX3     01072009 INTL 20160422)
[    0.000000] ACPI: FACS 0x000000003F138180 000040
[    0.000000] ACPI: APIC 0x000000003E7D99C8 0000BC (v03 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x000000003E7D9A88 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0x000000003E7D9AD0 0000AC (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x000000003E7D9B80 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x000000003E7D9BC0 000038 (v01 DELL   CBX3     01072009 AMI. 0005000B)
[    0.000000] ACPI: SSDT 0x000000003E7D9BF8 000359 (v01 SataRe SataTabl 00001000 INTL 20160422)
[    0.000000] ACPI: BOOT 0x000000003E7D9F58 000028 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x000000003E7D9F80 0012EF (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x000000003E7DB270 002896 (v02 PegSsd PegSsdt  00001000 INTL 20160422)
[    0.000000] ACPI: HPET 0x000000003E7DDB08 000038 (v01 INTEL  KBL      00000001 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x000000003E7DDB40 000CA5 (v02 INTEL  xh_rvp11 00000000 INTL 20160422)
[    0.000000] ACPI: UEFI 0x000000003E7DE7E8 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: SSDT 0x000000003E7DE830 0017AE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.000000] ACPI: LPIT 0x000000003E7DFFE0 000094 (v01 INTEL  KBL      00000000 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x000000003E7E0078 000161 (v02 INTEL  HdaDsp   00000000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x000000003E7E01E0 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x000000003E7E0480 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x000000003E7E3488 000512 (v02 INTEL  TbtTypeC 00000000 INTL 20160422)
[    0.000000] ACPI: DBGP 0x000000003E7E39A0 000034 (v01 INTEL           00000002 MSFT 0000005F)
[    0.000000] ACPI: DBG2 0x000000003E7E39D8 000054 (v00 INTEL           00000002 MSFT 0000005F)
[    0.000000] ACPI: SSDT 0x000000003E7E3A30 00085D (v02 INTEL  UsbCTabl 00001000 INTL 20160422)
[    0.000000] ACPI: SSDT 0x000000003E7E4290 006DCD (v02 DptfTa DptfTabl 00001000 INTL 20160422)
[    0.000000] ACPI: MSDM 0x000000003E7EB060 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
[    0.000000] ACPI: SLIC 0x000000003E7EB0B8 000176 (v03 DELL   CBX3     01072009 MSFT 00010013)
[    0.000000] ACPI: SSDT 0x000000003E7EB230 0000AE (v02 SgRef  SgPeg    00001000 INTL 20160422)
[    0.000000] ACPI: NHLT 0x000000003E7EB2E0 00002D (v00 INTEL  EDK2     00000002      01000013)
[    0.000000] ACPI: BGRT 0x000000003E7EB310 000038 (v00 \xf3\xee              01072009 AMI  00010013)
[    0.000000] ACPI: TPM2 0x000000003E7EB348 000034 (v03 DELL   CBX3     00000001 AMI  00000000)
[    0.000000] ACPI: SSDT 0x000000003E7EB380 000F52 (v01 AmdRef AmdTabl  00001000 INTL 20160422)
[    0.000000] ACPI: ASF! 0x000000003E7EC2D8 0000A0 (v32 INTEL   HCG     00000001 TFSM 000F4240)
[    0.000000] ACPI: DMAR 0x000000003E7EC378 0000F0 (v01 INTEL  EDK2     00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x00000004af7fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x4af7fc000-0x4af7fffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000004af7fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.000000]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000002ce0afff]
[    0.000000]   node   0: [mem 0x000000002ce0d000-0x000000003e3ddfff]
[    0.000000]   node   0: [mem 0x000000003ffff000-0x000000003fffffff]
[    0.000000]   node   0: [mem 0x0000000048000000-0x00000000485fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000004af7fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000004af7fffff]
[    0.000000] On node 0 totalpages: 4120954
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 25 pages reserved
[    0.000000]   DMA zone: 3997 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 3944 pages used for memmap
[    0.000000]   DMA32 zone: 252381 pages, LIFO batch:31
[    0.000000]   Normal zone: 60384 pages used for memmap
[    0.000000]   Normal zone: 3864576 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x000000004a800000-0x000000004e7fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x2ce0b000-0x2ce0bfff]
[    0.000000] PM: Registered nosave memory: [mem 0x2ce0c000-0x2ce0cfff]
[    0.000000] PM: Registered nosave memory: [mem 0x3e3de000-0x3e7a0fff]
[    0.000000] PM: Registered nosave memory: [mem 0x3e7a1000-0x3e7edfff]
[    0.000000] PM: Registered nosave memory: [mem 0x3e7ee000-0x3f13afff]
[    0.000000] PM: Registered nosave memory: [mem 0x3f13b000-0x3ff31fff]
[    0.000000] PM: Registered nosave memory: [mem 0x3ff32000-0x3fffefff]
[    0.000000] PM: Registered nosave memory: [mem 0x40000000-0x47ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0x48600000-0x4e7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x4e800000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x4e800000-0xefffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.000000] random: get_random_bytes called from start_kernel+0x93/0x4d3 with crng_init=0
[    0.000000] setup_percpu: NR_CPUS:128 nr_cpumask_bits:128 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] percpu: Embedded 42 pages/cpu @ffff9650ef400000 s134296 r8192 d29544 u262144
[    0.000000] pcpu-alloc: s134296 r8192 d29544 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4056537
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=8a536a03-dfe7-489f-9756-8e6c0dbd0040 rw quiet resume=UUID=c37a09e3-58f8-4066-84d4-b8d8b929c9ec
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 16075880K/16483816K available (10252K kernel code, 1172K rwdata, 2880K rodata, 1384K init, 956K bss, 407936K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] ftrace: allocating 29548 entries in 116 pages
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=128 to nr_cpu_ids=8.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 8448, nr_irqs: 2048, preallocated irqs: 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.000000] hpet clockevent registered
[    0.003333] tsc: Detected 3100.000 MHz processor
[    0.003333] Calibrating delay loop (skipped), value calculated using timer frequency.. 6194.00 BogoMIPS (lpj=10320000)
[    0.003333] pid_max: default: 32768 minimum: 301
[    0.003333] ACPI: Core revision 20170728
[    0.028346] ACPI Error: [\_SB_.PCI0.XHC_.RHUB.HS11] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload-210)
[    0.028352] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170728/psobject-252)
[    0.028377] ACPI Exception: AE_NOT_FOUND, (SSDT:xh_rvp11) while loading table (20170728/tbxfload-228)
[    0.031110] ACPI Error: 1 table load failures, 13 successful (20170728/tbxfload-246)
[    0.031989] Security Framework initialized
[    0.031989] Yama: becoming mindful.
[    0.033400] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.034077] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.034105] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.034124] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.034245] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.034246] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.034249] mce: CPU supports 10 MCE banks
[    0.034256] CPU0: Thermal monitoring enabled (TM1)
[    0.034269] process: using mwait in idle threads
[    0.034270] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.034271] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.034272] Spectre V2 : Mitigation: Full generic retpoline
[    0.034272] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.034272] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.034276] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.034276] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.034277] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.036739] Freeing SMP alternatives memory: 24K
[    0.038792] smpboot: Max logical packages: 2
[    0.038795] DMAR: Host address width 39
[    0.038796] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.038800] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.038801] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.038804] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.038804] DMAR: RMRR base: 0x0000003e4bc000 end: 0x0000003e4dbfff
[    0.038805] DMAR: RMRR base: 0x0000004a000000 end: 0x0000004e7fffff
[    0.038806] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.038807] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.038808] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.038808] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.038809] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.040240] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.040240] x2apic enabled
[    0.040251] Switched APIC routing to cluster x2apic.
[    0.044368] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.077408] TSC deadline timer enabled
[    0.077412] smpboot: CPU0: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz (family: 0x6, model: 0x9e, stepping: 0x9)
[    0.090015] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.090107] ... version:                4
[    0.090109] ... bit width:              48
[    0.090110] ... generic registers:      4
[    0.090113] ... value mask:             0000ffffffffffff
[    0.090114] ... max period:             00007fffffffffff
[    0.090116] ... fixed-purpose events:   3
[    0.090118] ... event mask:             000000070000000f
[    0.096673] Hierarchical SRCU implementation.
[    0.110273] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.116672] smp: Bringing up secondary CPUs ...
[    0.143361] x86: Booting SMP configuration:
[    0.143364] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.304028] smp: Brought up 1 node, 8 CPUs
[    0.304028] smpboot: Total of 8 processors activated (49555.00 BogoMIPS)
[    0.306966] devtmpfs: initialized
[    0.306966] x86/mm: Memory block size: 128MB
[    0.307404] PM: Registering ACPI NVS region [mem 0x2ce0b000-0x2ce0bfff] (4096 bytes)
[    0.307404] PM: Registering ACPI NVS region [mem 0x3e7ee000-0x3f13afff] (9752576 bytes)
[    0.307404] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.307404] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.307404] pinctrl core: initialized pinctrl subsystem
[    0.307404] RTC time: 21:33:02, date: 02/21/19
[    0.307404] NET: Registered protocol family 16
[    0.307404] cpuidle: using governor ladder
[    0.307404] cpuidle: using governor menu
[    0.307404] Simple Boot Flag at 0x47 set to 0x80
[    0.307404] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.307404] ACPI: bus type PCI registered
[    0.307404] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.307404] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.307404] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.307404] PCI: Using configuration type 1 for base access
[    0.307404] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.307404] mtrr: probably your BIOS does not setup all CPUs.
[    0.307404] mtrr: corrected configuration.
[    0.307404] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.307404] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.307404] ACPI: Added _OSI(Module Device)
[    0.307404] ACPI: Added _OSI(Processor Device)
[    0.307404] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.307404] ACPI: Added _OSI(Processor Aggregator Device)
[    0.311463] ACPI Error: [_SB_.PCI0.RP05.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload2-191)
[    0.311470] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170728/psobject-252)
[    0.311473] ACPI Error: Method parse/execution failed \_SB.PCI0.RP04.PXSX, AE_NOT_FOUND (20170728/psparse-550)
[    0.311719] ACPI Error: [_SB_.PCI0.RP09.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170728/dswload2-191)
[    0.311723] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170728/psobject-252)
[    0.311725] ACPI Error: Method parse/execution failed \_SB.PCI0.RP08.PXSX, AE_NOT_FOUND (20170728/psparse-550)
[    0.312600] ACPI: Executed 54 blocks of module-level executable AML code
[    0.378938] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.388250] ACPI: Dynamic OEM Table Load:
[    0.388256] ACPI: SSDT 0xFFFF9650DCEDF000 0006B4 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.388447] ACPI: Executed 1 blocks of module-level executable AML code
[    0.388512] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[    0.389274] ACPI: Dynamic OEM Table Load:
[    0.389278] ACPI: SSDT 0xFFFF9650DCB04C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.389457] ACPI: Executed 1 blocks of module-level executable AML code
[    0.389589] ACPI: Dynamic OEM Table Load:
[    0.389592] ACPI: SSDT 0xFFFF9650DCB38600 0000BA (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.389753] ACPI: Executed 1 blocks of module-level executable AML code
[    0.389844] ACPI: Dynamic OEM Table Load:
[    0.389848] ACPI: SSDT 0xFFFF9650DCEDE000 000628 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.390008] ACPI: Executed 1 blocks of module-level executable AML code
[    0.390355] ACPI: Dynamic OEM Table Load:
[    0.390361] ACPI: SSDT 0xFFFF9650DCB22000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.390908] ACPI: Executed 1 blocks of module-level executable AML code
[    0.391044] ACPI: Dynamic OEM Table Load:
[    0.391047] ACPI: SSDT 0xFFFF9650DCB00C00 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.391247] ACPI: Executed 1 blocks of module-level executable AML code
[    0.391390] ACPI: Dynamic OEM Table Load:
[    0.391394] ACPI: SSDT 0xFFFF9650DCB04000 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.391592] ACPI: Executed 1 blocks of module-level executable AML code
[    0.393577] ACPI: EC: EC started
[    0.393577] ACPI: EC: interrupt blocked
[    0.400878] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
[    0.400879] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.400880] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions
[    0.400881] ACPI: Interpreter enabled
[    0.400917] ACPI: (supports S0 S3 S4 S5)
[    0.400918] ACPI: Using IOAPIC for interrupt routing
[    0.400960] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.401435] ACPI: GPE 0x42 active on init
[    0.401498] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.408499] ACPI: Power Resource [PG00] (on)
[    0.430355] ACPI: Power Resource [PG01] (on)
[    0.430614] ACPI: Power Resource [PG02] (on)
[    0.456874] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[    0.456878] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.457422] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME AER]
[    0.457945] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability]
[    0.457946] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.458568] PCI host bridge to bus 0000:00
[    0.458570] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.458571] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.458572] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.458573] pci_bus 0000:00: root bus resource [mem 0x4e800000-0xefffffff window]
[    0.458574] pci_bus 0000:00: root bus resource [mem 0x2000000000-0x2fffffffff window]
[    0.458575] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.458577] pci_bus 0000:00: root bus resource [bus 00-7e]
[    0.458583] pci 0000:00:00.0: [8086:5910] type 00 class 0x060000
[    0.458670] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.458703] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.458835] pci 0000:00:02.0: [8086:591b] type 00 class 0x030000
[    0.458844] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
[    0.458849] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.458852] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.458863] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.458952] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.458961] pci 0000:00:04.0: reg 0x10: [mem 0x2ffff10000-0x2ffff17fff 64bit]
[    0.459125] pci 0000:00:13.0: [8086:a135] type 00 class 0x000000
[    0.459156] pci 0000:00:13.0: reg 0x10: [mem 0x2ffff1c000-0x2ffff1cfff 64bit]
[    0.459339] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.459371] pci 0000:00:14.0: reg 0x10: [mem 0xec500000-0xec50ffff 64bit]
[    0.459469] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.459623] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.459647] pci 0000:00:14.2: reg 0x10: [mem 0xec518000-0xec518fff 64bit]
[    0.459863] pci 0000:00:15.0: [8086:a160] type 00 class 0x118000
[    0.460084] pci 0000:00:15.0: reg 0x10: [mem 0x2ffff1b000-0x2ffff1bfff 64bit]
[    0.460780] pci 0000:00:15.1: [8086:a161] type 00 class 0x118000
[    0.460956] pci 0000:00:15.1: reg 0x10: [mem 0x2ffff1a000-0x2ffff1afff 64bit]
[    0.461614] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.461644] pci 0000:00:16.0: reg 0x10: [mem 0x2ffff19000-0x2ffff19fff 64bit]
[    0.461719] pci 0000:00:16.0: PME# supported from D3hot
[    0.461864] pci 0000:00:1c.0: [8086:a110] type 01 class 0x060400
[    0.461954] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.462093] pci 0000:00:1c.4: [8086:a114] type 01 class 0x060400
[    0.462173] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.462308] pci 0000:00:1d.0: [8086:a118] type 01 class 0x060400
[    0.462389] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.462527] pci 0000:00:1d.4: [8086:a11c] type 01 class 0x060400
[    0.462620] pci 0000:00:1d.4: PME# supported from D0 D3hot D3cold
[    0.462748] pci 0000:00:1f.0: [8086:a153] type 00 class 0x060100
[    0.462922] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.462939] pci 0000:00:1f.2: reg 0x10: [mem 0xec514000-0xec517fff]
[    0.463079] pci 0000:00:1f.3: [8086:a171] type 00 class 0x040380
[    0.463105] pci 0000:00:1f.3: reg 0x10: [mem 0xec510000-0xec513fff 64bit]
[    0.463134] pci 0000:00:1f.3: reg 0x20: [mem 0x2ffff00000-0x2ffff0ffff 64bit]
[    0.463182] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.463357] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.463418] pci 0000:00:1f.4: reg 0x10: [mem 0x2ffff18000-0x2ffff180ff 64bit]
[    0.463490] pci 0000:00:1f.4: reg 0x20: [io  0xf040-0xf05f]
[    0.463686] pci 0000:01:00.0: [1002:694e] type 00 class 0x038000
[    0.463715] pci 0000:01:00.0: reg 0x10: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.463726] pci 0000:01:00.0: reg 0x18: [mem 0xb0000000-0xb01fffff 64bit pref]
[    0.463734] pci 0000:01:00.0: reg 0x20: [io  0xe000-0xe0ff]
[    0.463741] pci 0000:01:00.0: reg 0x24: [mem 0xec400000-0xec43ffff]
[    0.463749] pci 0000:01:00.0: reg 0x30: [mem 0xec440000-0xec45ffff pref]
[    0.463816] pci 0000:01:00.0: supports D1 D2
[    0.463817] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.473375] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.473382] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.473388] pci 0000:00:01.0:   bridge window [mem 0xec400000-0xec4fffff]
[    0.473396] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb01fffff 64bit pref]
[    0.473772] pci 0000:02:00.0: [168c:003e] type 00 class 0x028000
[    0.474098] pci 0000:02:00.0: reg 0x10: [mem 0xec000000-0xec1fffff 64bit]
[    0.475281] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.483815] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.483821] pci 0000:00:1c.0:   bridge window [mem 0xec000000-0xec1fffff]
[    0.483936] pci 0000:03:00.0: [10ec:525a] type 00 class 0xff0000
[    0.483972] pci 0000:03:00.0: reg 0x14: [mem 0xec300000-0xec300fff]
[    0.484090] pci 0000:03:00.0: supports D1 D2
[    0.484091] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.493382] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.493394] pci 0000:00:1c.4:   bridge window [mem 0xec300000-0xec3fffff]
[    0.493533] pci 0000:04:00.0: [8086:15d3] type 01 class 0x060400
[    0.493606] pci 0000:04:00.0: enabling Extended Tags
[    0.493704] pci 0000:04:00.0: supports D1 D2
[    0.493705] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.503375] pci 0000:00:1d.0: PCI bridge to [bus 04-6e]
[    0.503387] pci 0000:00:1d.0:   bridge window [mem 0xbc000000-0xea0fffff]
[    0.503413] pci 0000:00:1d.0:   bridge window [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.503480] pci 0000:05:00.0: [8086:15d3] type 01 class 0x060400
[    0.503554] pci 0000:05:00.0: enabling Extended Tags
[    0.503654] pci 0000:05:00.0: supports D1 D2
[    0.503655] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.503748] pci 0000:05:01.0: [8086:15d3] type 01 class 0x060400
[    0.503823] pci 0000:05:01.0: enabling Extended Tags
[    0.503919] pci 0000:05:01.0: supports D1 D2
[    0.503920] pci 0000:05:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.504008] pci 0000:05:02.0: [8086:15d3] type 01 class 0x060400
[    0.504081] pci 0000:05:02.0: enabling Extended Tags
[    0.504177] pci 0000:05:02.0: supports D1 D2
[    0.504178] pci 0000:05:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.504270] pci 0000:05:04.0: [8086:15d3] type 01 class 0x060400
[    0.504344] pci 0000:05:04.0: enabling Extended Tags
[    0.504440] pci 0000:05:04.0: supports D1 D2
[    0.504441] pci 0000:05:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.504551] pci 0000:04:00.0: PCI bridge to [bus 05-6e]
[    0.504561] pci 0000:04:00.0:   bridge window [mem 0xbc000000-0xea0fffff]
[    0.504568] pci 0000:04:00.0:   bridge window [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.504612] pci 0000:05:00.0: PCI bridge to [bus 06]
[    0.504622] pci 0000:05:00.0:   bridge window [mem 0xea000000-0xea0fffff]
[    0.504672] pci 0000:05:01.0: PCI bridge to [bus 07-39]
[    0.504682] pci 0000:05:01.0:   bridge window [mem 0xbc000000-0xd3efffff]
[    0.504689] pci 0000:05:01.0:   bridge window [mem 0x2fb0000000-0x2fcfffffff 64bit pref]
[    0.504754] pci 0000:3a:00.0: [8086:15d4] type 00 class 0x0c0330
[    0.504793] pci 0000:3a:00.0: reg 0x10: [mem 0xd3f00000-0xd3f0ffff]
[    0.504864] pci 0000:3a:00.0: enabling Extended Tags
[    0.504966] pci 0000:3a:00.0: supports D1 D2
[    0.504967] pci 0000:3a:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.505134] pci 0000:05:02.0: PCI bridge to [bus 3a]
[    0.505144] pci 0000:05:02.0:   bridge window [mem 0xd3f00000-0xd3ffffff]
[    0.505194] pci 0000:05:04.0: PCI bridge to [bus 3b-6e]
[    0.505205] pci 0000:05:04.0:   bridge window [mem 0xd4000000-0xe9ffffff]
[    0.505211] pci 0000:05:04.0:   bridge window [mem 0x2fd0000000-0x2ff9ffffff 64bit pref]
[    0.505618] pci 0000:6f:00.0: [8086:f1a6] type 00 class 0x010802
[    0.505659] pci 0000:6f:00.0: reg 0x10: [mem 0xec200000-0xec203fff 64bit]
[    0.513483] pci 0000:00:1d.4: PCI bridge to [bus 6f]
[    0.513490] pci 0000:00:1d.4:   bridge window [mem 0xec200000-0xec2fffff]
[    0.515063] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515106] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.515146] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515187] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515227] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515266] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515305] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.515344] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.519342] ACPI: EC: interrupt unblocked
[    0.519350] ACPI: EC: event unblocked
[    0.519373] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x6e, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[    0.519374] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions and events
[    0.519581] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.519581] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.519581] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.519581] vgaarb: loaded
[    0.519581] EDAC MC: Ver: 3.0.0
[    0.520336] Registered efivars operations
[    0.526967] PCI: Using ACPI for IRQ routing
[    0.533592] PCI: pci_cache_line_size set to 64 bytes
[    0.534130] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.534131] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.534131] e820: reserve RAM buffer [mem 0x2ce0b000-0x2fffffff]
[    0.534132] e820: reserve RAM buffer [mem 0x3e3de000-0x3fffffff]
[    0.534133] e820: reserve RAM buffer [mem 0x48600000-0x4bffffff]
[    0.534134] e820: reserve RAM buffer [mem 0x4af800000-0x4afffffff]
[    0.534185] NetLabel: Initializing
[    0.534186] NetLabel:  domain hash size = 128
[    0.534186] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.534195] NetLabel:  unlabeled traffic allowed by default
[    0.534208] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.534208] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.535724] clocksource: Switched to clocksource hpet
[    0.539594] VFS: Disk quotas dquot_6.6.0
[    0.539604] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.539637] pnp: PnP ACPI init
[    0.539817] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.539818] system 00:00: [io  0xffff] has been reserved
[    0.539820] system 00:00: [io  0xffff] has been reserved
[    0.539821] system 00:00: [io  0xffff] has been reserved
[    0.539822] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.539823] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.539826] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.539905] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.539907] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.539921] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.539950] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.539953] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.540149] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.540324] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.540325] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.540326] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.540327] system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.540328] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.540330] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.540331] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.540332] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    0.540333] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.540334] system 00:05: [mem 0xeffe0000-0xefffffff] has been reserved
[    0.540337] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.540371] system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.540372] system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.540373] system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.540377] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.540378] system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.540379] system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.540380] system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.540383] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.540629] system 00:07: [io  0xff00-0xfffe] has been reserved
[    0.540632] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.541548] system 00:08: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.541549] system 00:08: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.541550] system 00:08: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.541552] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.544664] pnp: PnP ACPI: found 9 devices
[    0.552389] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.552434] pci 0000:05:01.0: bridge window [io  0x1000-0x0fff] to [bus 07-39] add_size 1000
[    0.552444] pci 0000:05:02.0: bridge window [io  0x1000-0x0fff] to [bus 3a] add_size 1000
[    0.552445] pci 0000:05:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3a] add_size 200000 add_align 100000
[    0.552455] pci 0000:05:04.0: bridge window [io  0x1000-0x0fff] to [bus 3b-6e] add_size 1000
[    0.552465] pci 0000:04:00.0: bridge window [io  0x1000-0x0fff] to [bus 05-6e] add_size 3000
[    0.552475] pci 0000:00:1d.0: bridge window [io  0x1000-0x0fff] to [bus 04-6e] add_size 3000
[    0.552488] pci 0000:00:1d.0: BAR 13: assigned [io  0x2000-0x4fff]
[    0.552489] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.552491] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.552492] pci 0000:00:01.0:   bridge window [mem 0xec400000-0xec4fffff]
[    0.552494] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb01fffff 64bit pref]
[    0.552497] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.552503] pci 0000:00:1c.0:   bridge window [mem 0xec000000-0xec1fffff]
[    0.552513] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.552518] pci 0000:00:1c.4:   bridge window [mem 0xec300000-0xec3fffff]
[    0.552528] pci 0000:04:00.0: BAR 13: assigned [io  0x2000-0x4fff]
[    0.552531] pci 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    0.552532] pci 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    0.552533] pci 0000:05:01.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.552534] pci 0000:05:02.0: BAR 13: assigned [io  0x3000-0x3fff]
[    0.552535] pci 0000:05:04.0: BAR 13: assigned [io  0x4000-0x4fff]
[    0.552536] pci 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[    0.552537] pci 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[    0.552539] pci 0000:05:00.0: PCI bridge to [bus 06]
[    0.552544] pci 0000:05:00.0:   bridge window [mem 0xea000000-0xea0fffff]
[    0.552553] pci 0000:05:01.0: PCI bridge to [bus 07-39]
[    0.552555] pci 0000:05:01.0:   bridge window [io  0x2000-0x2fff]
[    0.552560] pci 0000:05:01.0:   bridge window [mem 0xbc000000-0xd3efffff]
[    0.552564] pci 0000:05:01.0:   bridge window [mem 0x2fb0000000-0x2fcfffffff 64bit pref]
[    0.552571] pci 0000:05:02.0: PCI bridge to [bus 3a]
[    0.552573] pci 0000:05:02.0:   bridge window [io  0x3000-0x3fff]
[    0.552578] pci 0000:05:02.0:   bridge window [mem 0xd3f00000-0xd3ffffff]
[    0.552588] pci 0000:05:04.0: PCI bridge to [bus 3b-6e]
[    0.552590] pci 0000:05:04.0:   bridge window [io  0x4000-0x4fff]
[    0.552595] pci 0000:05:04.0:   bridge window [mem 0xd4000000-0xe9ffffff]
[    0.552598] pci 0000:05:04.0:   bridge window [mem 0x2fd0000000-0x2ff9ffffff 64bit pref]
[    0.552605] pci 0000:04:00.0: PCI bridge to [bus 05-6e]
[    0.552607] pci 0000:04:00.0:   bridge window [io  0x2000-0x4fff]
[    0.552612] pci 0000:04:00.0:   bridge window [mem 0xbc000000-0xea0fffff]
[    0.552616] pci 0000:04:00.0:   bridge window [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.552622] pci 0000:00:1d.0: PCI bridge to [bus 04-6e]
[    0.552625] pci 0000:00:1d.0:   bridge window [io  0x2000-0x4fff]
[    0.552630] pci 0000:00:1d.0:   bridge window [mem 0xbc000000-0xea0fffff]
[    0.552633] pci 0000:00:1d.0:   bridge window [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.552640] pci 0000:00:1d.4: PCI bridge to [bus 6f]
[    0.552645] pci 0000:00:1d.4:   bridge window [mem 0xec200000-0xec2fffff]
[    0.552655] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.552656] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.552657] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.552658] pci_bus 0000:00: resource 7 [mem 0x4e800000-0xefffffff window]
[    0.552659] pci_bus 0000:00: resource 8 [mem 0x2000000000-0x2fffffffff window]
[    0.552659] pci_bus 0000:00: resource 9 [mem 0xfd000000-0xfe7fffff window]
[    0.552660] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.552661] pci_bus 0000:01: resource 1 [mem 0xec400000-0xec4fffff]
[    0.552662] pci_bus 0000:01: resource 2 [mem 0xa0000000-0xb01fffff 64bit pref]
[    0.552663] pci_bus 0000:02: resource 1 [mem 0xec000000-0xec1fffff]
[    0.552664] pci_bus 0000:03: resource 1 [mem 0xec300000-0xec3fffff]
[    0.552664] pci_bus 0000:04: resource 0 [io  0x2000-0x4fff]
[    0.552665] pci_bus 0000:04: resource 1 [mem 0xbc000000-0xea0fffff]
[    0.552666] pci_bus 0000:04: resource 2 [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.552667] pci_bus 0000:05: resource 0 [io  0x2000-0x4fff]
[    0.552668] pci_bus 0000:05: resource 1 [mem 0xbc000000-0xea0fffff]
[    0.552669] pci_bus 0000:05: resource 2 [mem 0x2fb0000000-0x2ff9ffffff 64bit pref]
[    0.552669] pci_bus 0000:06: resource 1 [mem 0xea000000-0xea0fffff]
[    0.552670] pci_bus 0000:07: resource 0 [io  0x2000-0x2fff]
[    0.552671] pci_bus 0000:07: resource 1 [mem 0xbc000000-0xd3efffff]
[    0.552672] pci_bus 0000:07: resource 2 [mem 0x2fb0000000-0x2fcfffffff 64bit pref]
[    0.552673] pci_bus 0000:3a: resource 0 [io  0x3000-0x3fff]
[    0.552673] pci_bus 0000:3a: resource 1 [mem 0xd3f00000-0xd3ffffff]
[    0.552674] pci_bus 0000:3b: resource 0 [io  0x4000-0x4fff]
[    0.552675] pci_bus 0000:3b: resource 1 [mem 0xd4000000-0xe9ffffff]
[    0.552676] pci_bus 0000:3b: resource 2 [mem 0x2fd0000000-0x2ff9ffffff 64bit pref]
[    0.552677] pci_bus 0000:6f: resource 1 [mem 0xec200000-0xec2fffff]
[    0.552764] NET: Registered protocol family 2
[    0.552850] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.552955] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.553035] TCP: Hash tables configured (established 131072 bind 65536)
[    0.553056] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.553081] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.553120] NET: Registered protocol family 1
[    0.553128] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.555020] pci 0000:04:00.0: enabling device (0006 -> 0007)
[    0.555055] pci 0000:05:02.0: enabling device (0006 -> 0007)
[    0.555219] PCI: CLS 128 bytes, default 64
[    0.555240] Unpacking initramfs...
[    0.639808] Freeing initrd memory: 10528K
[    0.639831] DMAR: ACPI device "device:77" under DMAR at fed91000 as 00:15.0
[    0.639833] DMAR: ACPI device "device:78" under DMAR at fed91000 as 00:15.1
[    0.639844] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.639845] software IO TLB: mapped [mem 0x32b5f000-0x36b5f000] (64MB)
[    0.640143] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2ca08564bf3, max_idle_ns: 440795312460 ns
[    0.640362] Scanning for low memory corruption every 60 seconds
[    0.640780] Initialise system trusted keyrings
[    0.640785] Key type blacklist registered
[    0.640860] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.641400] zbud: loaded
[    0.643911] Key type asymmetric registered
[    0.643919] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.643977] io scheduler noop registered
[    0.643978] io scheduler deadline registered
[    0.643994] io scheduler cfq registered
[    0.643995] io scheduler mq-deadline registered
[    0.643995] io scheduler kyber registered
[    0.644008] io scheduler bfq registered
[    0.644020] io scheduler bfq-sq registered (default)
[    0.644020] BFQ I/O-scheduler: v8r12 (with cgroups support)
[    0.644032] io scheduler bfq-mq registered
[    0.644032] BFQ I/O-scheduler: v8r12 (with cgroups support)
[    0.645142] pcieport 0000:05:01.0: enabling device (0006 -> 0007)
[    0.645460] pcieport 0000:05:04.0: enabling device (0006 -> 0007)
[    0.645651] efifb: probing for efifb
[    0.645660] efifb: framebuffer at 0x90000000, using 32448k, total 32448k
[    0.645660] efifb: mode is 3840x2160x32, linelength=15360, pages=1
[    0.645661] efifb: scrolling: redraw
[    0.645662] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.655339] Console: switching to colour frame buffer device 480x135
[    0.664925] fb0: EFI VGA frame buffer device
[    0.664930] intel_idle: MWAIT substates: 0x11142120
[    0.664930] intel_idle: v0.4.1 model 0x9E
[    0.665282] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.666087] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.667029] rtc_cmos 00:02: RTC can wake from S4
[    0.667415] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    0.667498] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.667502] intel_pstate: Intel P-state driver initializing
[    0.667525] intel_pstate: Disabling energy efficiency optimization
[    0.668831] intel_pstate: HWP enabled
[    0.669213] ledtrig-cpu: registered to indicate activity on CPUs
[    0.669259] vlv2_plat_clk vlv2_plat_clk: vlv2_plat_clk initialized
[    0.669466] NET: Registered protocol family 10
[    0.674004] Segment Routing with IPv6
[    0.674014] NET: Registered protocol family 17
[    0.674899] RAS: Correctable Errors collector initialized.
[    0.674956] microcode: sig=0x906e9, pf=0x8, revision=0x8e
[    0.675335] microcode: Microcode Update Driver: v2.2.
[    0.675339] sched_clock: Marking stable (675332780, 0)->(896218605, -220885825)
[    0.675685] registered taskstats version 1
[    0.675691] Loading compiled-in X.509 certificates
[    0.675700] zswap: loaded using pool lzo/zbud
[    0.678471] Key type big_key registered
[    0.679827]   Magic number: 7:810:601
[    0.680044] rtc_cmos 00:02: setting system clock to 2019-02-21 21:33:03 UTC (1550784783)
[    0.805646] Freeing unused kernel memory: 1384K
[    0.805647] Write protecting the kernel read-only data: 16384k
[    0.806546] Freeing unused kernel memory: 2016K
[    0.807849] Freeing unused kernel memory: 1216K
[    0.862501] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    0.862502] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    0.863002] i8042: Warning: Keylock active
[    0.863182] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.873398] rtsx_pci 0000:03:00.0: enabling device (0000 -> 0002)
[    0.875665] ACPI: bus type USB registered
[    0.875680] usbcore: registered new interface driver usbfs
[    0.875686] usbcore: registered new interface driver hub
[    0.875721] usbcore: registered new device driver usb
[    0.876286] nvme nvme0: pci function 0000:6f:00.0
[    0.878319] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.878322] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.879543] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[    0.879548] xhci_hcd 0000:00:14.0: cache line size of 128 is not supported
[    0.879716] hub 1-0:1.0: USB hub found
[    0.879783] hub 1-0:1.0: 16 ports detected
[    0.880284] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.880288] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.880290] xhci_hcd 0000:00:14.0: Host supports USB 3.0  SuperSpeed
[    0.880445] hub 2-0:1.0: USB hub found
[    0.880473] hub 2-0:1.0: 8 ports detected
[    0.881002] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[    0.881005] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 3
[    0.882459] xhci_hcd 0000:3a:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    0.882697] hub 3-0:1.0: USB hub found
[    0.882709] hub 3-0:1.0: 2 ports detected
[    0.882973] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[    0.882974] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 4
[    0.882976] xhci_hcd 0000:3a:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.883070] hub 4-0:1.0: USB hub found
[    0.883081] hub 4-0:1.0: 2 ports detected
[    0.897770] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.090910] nvme nvme0: missing or invalid SUBNQN field.
[    1.097622]  nvme0n1: p1 p2 p3
[    1.210354] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.220310] PM: Starting manual resume from disk
[    1.220739] PM: Image not found (code -22)
[    1.246581] random: fast init done
[    1.249900] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.325219] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.335256] systemd[1]: systemd 241.159-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.350486] systemd[1]: Detected architecture x86-64.
[    1.355916] systemd[1]: Set hostname to <xps-laptop>.
[    1.458284] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.458339] systemd[1]: Reached target Remote File Systems.
[    1.458429] systemd[1]: Listening on Journal Socket (/dev/log).
[    1.459693] systemd[1]: Created slice User and Session Slice.
[    1.459731] systemd[1]: Reached target Slices.
[    1.459810] systemd[1]: Listening on udev Control Socket.
[    1.460064] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    1.470807] random: lvm: uninitialized urandom read (4 bytes read)
[    1.475665] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[    1.480879] random: systemd-random-: uninitialized urandom read (512 bytes read)
[    1.523390] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[    1.568517] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[    1.569286] ACPI: Lid Switch [LID0]
[    1.569334] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    1.569366] ACPI: Power Button [PBTN]
[    1.571016] ACPI: AC Adapter [AC] (off-line)
[    1.571079] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[    1.571091] ACPI: Sleep Button [SBTN]
[    1.571133] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[    1.571156] ACPI: Power Button [PWRF]
[    1.575602] input: Intel HID events as /devices/platform/INT33D5:00/input/input5
[    1.575641] intel-hid INT33D5:00: platform supports 5 button array
[    1.575661] input: Intel HID 5 button array as /devices/platform/INT33D5:00/input/input6
[    1.577791] ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20170728/nsprepkg-130)
[    1.607604] tpm_tis MSFT0101:00: 2.0 TPM (device-id 0xFC, rev-id 1)
[    1.608774] input: Intel Virtual Button driver as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/INT33D6:00/input/input7
[    1.612508] int3403 thermal: probe of INT3403:02 failed with error -22
[    1.622030] hidraw: raw HID events driver (C) Jiri Kosina
[    1.626151] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    1.627474] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    1.632637] systemd-journald[214]: Received request to flush runtime journal from PID 1
[    1.638469] Linux agpgart interface v0.103
[    1.642465] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    1.646559] thermal LNXTHERM:00: registered as thermal_zone8
[    1.646560] ACPI: Thermal Zone [THM] (25 C)
[    1.649391] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.652301] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.653446] clocksource: Switched to clocksource tsc
[    1.657326] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.663619] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    1.663619] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    1.663620] RAPL PMU: hw unit of domain package 2^-14 Joules
[    1.663620] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    1.663621] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    1.663621] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    1.678509] ACPI: Battery Slot [BAT0] (battery present)
[    1.693301] AVX2 version of gcm_enc/dec engaged.
[    1.693302] AES CTR mode by8 optimization enabled
[    1.700221] Adding 17746368k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:17746368k SSFS
[    1.714405] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    1.738825] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.739042] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.767529] ath10k_core: unknown parameter 'nohwcrypt' ignored
[    1.772799] ath10k_pci: unknown parameter 'nohwcrypt' ignored
[    1.772800] ath10k_pci: unknown parameter 'skip_otp' ignored
[    1.780289] ath10k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[    1.783222] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    1.789947] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[    1.805988] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.806024] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.812214] random: crng init done
[    1.813765] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    1.826688] [drm] Memory usable by graphics device = 4096M
[    1.826691] checking generic (90000000 1fb0000) vs hw (90000000 10000000)
[    1.826692] fb: switching to inteldrmfb from EFI VGA
[    1.826708] Console: switching to colour dummy device 80x25
[    1.827426] [drm] Replacing VGA console driver
[    1.832058] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.832059] [drm] Driver supports precise vblank timestamp query.
[    1.835056] wmi_bus wmi_bus-PNP0C14:01: WQBC data block query control method not found
[    1.835157] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    1.836358] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    1.836885] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.837802] intel_rapl: Found RAPL domain package
[    1.837803] intel_rapl: Found RAPL domain core
[    1.837804] intel_rapl: Found RAPL domain uncore
[    1.837804] intel_rapl: Found RAPL domain dram
[    1.837862] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_01.bin (v1.1)
[    1.847711] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    1.857424] [drm] Initialized i915 1.6.0 20170818 for 0000:00:02.0 on minor 0
[    1.859487] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    1.860271] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[    1.860416] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    1.867027] iTCO_vendor_support: vendor-support=0
[    1.868113] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    1.868287] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    1.868404] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    1.871595] fbcon: inteldrmfb (fb0) is primary device
[    1.891795] usbcore: registered new interface driver usbhid
[    1.891796] usbhid: USB HID core driver
[    1.897293] dell-wmi 9DBB5994-A997-11DA-B012-B622A1EF5492: Dell descriptor buffer has invalid buffer length (32768)
[    1.897294] dell-wmi 9DBB5994-A997-11DA-B012-B622A1EF5492: Detected Dell WMI interface version 1
[    1.897355] input: Dell WMI hotkeys as /devices/platform/PNP0C14:01/wmi_bus/wmi_bus-PNP0C14:01/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input10
[    1.900275] input: Wacom HID 486B Pen as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-WCOM486B:00/0018:056A:486B.0001/input/input11
[    1.900339] input: Wacom HID 486B Finger as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-WCOM486B:00/0018:056A:486B.0001/input/input12
[    1.900401] wacom 0018:056A:486B.0001: hidraw0: I2C HID v1.00 Mouse [WCOM486B:00 056A:486B] on i2c-WCOM486B:00
[    1.904711] input: DELL080D:00 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL080D:00/0018:06CB:7A13.0002/input/input15
[    1.904753] hid-multitouch 0018:06CB:7A13.0002: input,hidraw1: I2C HID v1.00 Mouse [DELL080D:00 06CB:7A13] on i2c-DELL080D:00
[    1.905289] mousedev: PS/2 mouse device common for all mice
[    1.928549] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3271: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    1.928551] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    1.928552] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    1.928552] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    1.928553] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    1.928554] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[    1.928555] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1b
[    1.928555] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    1.984962] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    1.985029] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    1.985092] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    1.985158] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    1.985218] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    1.985278] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[    2.061854] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[    2.061881] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[    2.064287] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:143a
[    2.064293] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 0 testmode 0
[    2.065456] ath10k_pci 0000:02:00.0: firmware ver RM.4.4.1.c2-00057-QCARMSWP-1 api 6 features wowlan,ignore-otp,no-4addr-pad,raw-mode crc32 e061250a
[    2.131730] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 4ed3569e
[    2.350026] usb 1-3: new full-speed USB device number 4 using xhci_hcd
[    2.616700] usb 1-6: new full-speed USB device number 5 using xhci_hcd
[    2.702362] ath10k_pci 0000:02:00.0: Unknown eventid: 3
[    2.719135] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[    2.725839] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    2.804947] ath: EEPROM regdomain: 0x6c
[    2.804948] ath: EEPROM indicates we should expect a direct regpair map
[    2.804950] ath: Country alpha2 being used: 00
[    2.804951] ath: Regpair used: 0x6c
[    2.817098] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[    2.865380] Console: switching to colour frame buffer device 480x135
[    2.870040] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[    2.886688] usb 1-10: new full-speed USB device number 6 using xhci_hcd
[    2.928075] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    3.160017] usb 1-11: new high-speed USB device number 7 using xhci_hcd
[    3.357143] [drm] RC6 on
[    3.478569] input: Gaming KB  Gaming KB  as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:258A:1006.0003/input/input26
[    3.481177] media: Linux media interface: v0.10
[    3.490632] cdc_acm 1-10:1.0: ttyACM0: USB ACM device
[    3.490924] usbcore: registered new interface driver cdc_acm
[    3.490924] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.495508] Linux video capture interface: v2.00
[    3.512036] uvcvideo: Found UVC 1.50 device Integrated_Webcam_HD (0bda:58f4)
[    3.518177] Bluetooth: Core ver 2.22
[    3.518189] NET: Registered protocol family 31
[    3.518190] Bluetooth: HCI device and connection manager initialized
[    3.518191] Bluetooth: HCI socket layer initialized
[    3.518193] Bluetooth: L2CAP socket layer initialized
[    3.518196] Bluetooth: SCO socket layer initialized
[    3.536804] hid-generic 0003:258A:1006.0003: input,hidraw2: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:00:14.0-3/input0
[    3.536995] input: Gaming KB  Gaming KB  as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:258A:1006.0004/input/input27
[    3.577249] ath10k_pci 0000:02:00.0: Unknown eventid: 3
[    3.592078] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[    3.593615] hid-generic 0003:258A:1006.0004: input,hiddev0,hidraw3: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:00:14.0-3/input1
[    3.605326] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[    4.390938] ath10k_pci 0000:02:00.0: Unknown eventid: 3
[    4.405896] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[    4.435620] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[    4.468167] usbcore: registered new interface driver btusb
[    4.469621] uvcvideo 1-1:1.0: Entity type for entity Integrated_Webcam_HD was not initialized!
[    4.469624] uvcvideo 1-1:1.0: Entity type for entity Extension 4 was not initialized!
[    4.469625] uvcvideo 1-1:1.0: Entity type for entity Extension 7 was not initialized!
[    4.469626] uvcvideo 1-1:1.0: Entity type for entity Processing 2 was not initialized!
[    4.469628] uvcvideo 1-1:1.0: Entity type for entity Camera 1 was not initialized!
[    4.469694] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input28
[    4.470280] uvcvideo: Unknown video format 00000032-0002-0010-8000-00aa00389b71
[    4.470286] uvcvideo: Found UVC 1.50 device Integrated_Webcam_HD (0bda:58f4)
[    4.470307] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[    4.470309] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[    4.501777] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[    4.524699] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[    4.535436] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.535438] Bluetooth: BNEP filters: protocol multicast
[    4.535446] Bluetooth: BNEP socket layer initialized
[    5.138461] Bluetooth: RFCOMM TTY layer initialized
[    5.138468] Bluetooth: RFCOMM socket layer initialized
[    5.138475] Bluetooth: RFCOMM ver 1.11
[    5.428982] uvcvideo: Unable to create debugfs 1-2 directory.
[    5.429079] uvcvideo 1-1:1.2: Entity type for entity Extension 10 was not initialized!
[    5.429080] uvcvideo 1-1:1.2: Entity type for entity Extension 12 was not initialized!
[    5.429081] uvcvideo 1-1:1.2: Entity type for entity Processing 9 was not initialized!
[    5.429082] uvcvideo 1-1:1.2: Entity type for entity Camera 11 was not initialized!
[    5.429212] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/input/input29
[    9.374827] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   11.193638] usbcore: registered new interface driver snd-usb-audio
[   11.195000] uvcvideo: Found UVC 1.00 device FULL HD 1080P Webcam (0bda:58b0)
[   11.206971] uvcvideo 1-11:1.0: Entity type for entity Extension 4 was not initialized!
[   11.206972] uvcvideo 1-11:1.0: Entity type for entity Processing 2 was not initialized!
[   11.206973] uvcvideo 1-11:1.0: Entity type for entity Camera 1 was not initialized!
[   11.207036] input: FULL HD 1080P Webcam: FULL HD 1 as /devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input30
[   11.207108] usbcore: registered new interface driver uvcvideo
[   11.207108] USB Video Class driver (1.1.1)
[   14.266558] wlp2s0: authenticate with d4:6a:91:a6:5a:e5
[   14.318322] wlp2s0: send auth to d4:6a:91:a6:5a:e5 (try 1/3)
[   14.319548] wlp2s0: authenticated
[   14.323399] wlp2s0: associate with d4:6a:91:a6:5a:e5 (try 1/3)
[   14.326220] wlp2s0: RX AssocResp from d4:6a:91:a6:5a:e5 (capab=0x1511 status=0 aid=1)
[   14.329070] wlp2s0: associated
[   14.337896] ath: EEPROM regdomain: 0x8348
[   14.337899] ath: EEPROM indicates we should expect a country code
[   14.337901] ath: doing EEPROM country->regdmn map search
[   14.337903] ath: country maps to regdmn code: 0x3a
[   14.337905] ath: Country alpha2 being used: US
[   14.337906] ath: Regpair used: 0x3a
[   14.337908] ath: regdomain 0x8348 dynamically updated by country IE
[   14.425584] wlp2s0: Limiting TX power to 24 (24 - 0) dBm as advertised by d4:6a:91:a6:5a:e5
[   14.426389] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[   46.349476] NET: Registered protocol family 38
[   47.252580] fuse init (API version 7.26)
[   48.605259] input: Surface Mouse as /devices/virtual/misc/uhid/0005:045E:0919.0005/input/input31
[   48.605530] hid-generic 0005:045E:0919.0005: input,hidraw4: BLUETOOTH HID v1.10 Mouse [Surface Mouse] on 9C:B6:D0:91:CA:40
[   53.761606] rfkill: input handler disabled
[ 1713.676094] CPU4: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676095] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676096] CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676122] CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676127] CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676128] CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676128] CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676129] CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676130] CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.676131] CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1713.677064] CPU4: Core temperature/speed normal
[ 1713.677065] CPU0: Core temperature/speed normal
[ 1713.677066] CPU6: Package temperature/speed normal
[ 1713.677066] CPU2: Package temperature/speed normal
[ 1713.677067] CPU0: Package temperature/speed normal
[ 1713.677088] CPU4: Package temperature/speed normal
[ 1713.677092] CPU5: Package temperature/speed normal
[ 1713.677093] CPU1: Package temperature/speed normal
[ 1713.677093] CPU3: Package temperature/speed normal
[ 1713.677094] CPU7: Package temperature/speed normal
[ 3053.767697] PM: suspend entry (deep)
[ 3053.767700] PM: Syncing filesystems ... done.
[ 3053.800517] Freezing user space processes ... (elapsed 0.003 seconds) done.
[ 3053.803707] OOM killer disabled.
[ 3053.803708] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 3053.805210] Suspending console(s) (use no_console_suspend to debug)
[ 3053.805784] wlp2s0: deauthenticating from d4:6a:91:a6:5a:e5 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 3054.204113] ACPI: EC: interrupt blocked
[ 3054.246688] ACPI: Preparing to enter system sleep state S3
[ 3054.254313] ACPI: EC: event blocked
[ 3054.254314] ACPI: EC: EC stopped
[ 3054.254315] PM: Saving platform NVS memory
[ 3054.254422] Disabling non-boot CPUs ...
[ 3054.271203] smpboot: CPU 1 is now offline
[ 3054.301178] smpboot: CPU 2 is now offline
[ 3054.331156] smpboot: CPU 3 is now offline
[ 3054.372362] smpboot: CPU 4 is now offline
[ 3054.401021] smpboot: CPU 5 is now offline
[ 3054.431046] smpboot: CPU 6 is now offline
[ 3054.460972] smpboot: CPU 7 is now offline
[ 3054.465490] ACPI: Low-level resume complete
[ 3054.465614] ACPI: EC: EC started
[ 3054.465614] PM: Restoring platform NVS memory
[ 3054.466440] Enabling non-boot CPUs ...
[ 3054.466463] x86: Booting SMP configuration:
[ 3054.466464] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 3054.466859]  cache: parent cpu1 should not be sleeping
[ 3054.466884] intel_pstate: Disabling energy efficiency optimization
[ 3054.466964] CPU1 is up
[ 3054.466979] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 3054.467359]  cache: parent cpu2 should not be sleeping
[ 3054.467472] CPU2 is up
[ 3054.467485] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 3054.467866]  cache: parent cpu3 should not be sleeping
[ 3054.467984] CPU3 is up
[ 3054.467998] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 3054.468471]  cache: parent cpu4 should not be sleeping
[ 3054.468682] CPU4 is up
[ 3054.468698] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 3054.469087]  cache: parent cpu5 should not be sleeping
[ 3054.469214] CPU5 is up
[ 3054.469228] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 3054.469620]  cache: parent cpu6 should not be sleeping
[ 3054.469759] CPU6 is up
[ 3054.469772] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 3054.470170]  cache: parent cpu7 should not be sleeping
[ 3054.470319] CPU7 is up
[ 3054.476373] ACPI: Waking up from system sleep state S3
[ 3054.761431] ACPI: EC: interrupt unblocked
[ 3054.812603] ACPI: EC: event unblocked
[ 3054.813120] usb usb1: root hub lost power or was reset
[ 3054.813123] usb usb2: root hub lost power or was reset
[ 3054.813128] usb usb3: root hub lost power or was reset
[ 3054.813130] usb usb4: root hub lost power or was reset
[ 3054.821010] ACPI: button: The lid device is not compliant to SW_LID.
[ 3054.846284] acpi INT3400:00: Unsupported event [0x88]
[ 3054.847400] acpi INT3400:00: Unsupported event [0x88]
[ 3054.920392] nvme nvme0: missing or invalid SUBNQN field.
[ 3055.163317] usb 1-3: reset full-speed USB device number 4 using xhci_hcd
[ 3055.426632] usb 1-10: reset full-speed USB device number 6 using xhci_hcd
[ 3055.520024] ath10k_pci 0000:02:00.0: Unknown eventid: 3
[ 3055.535283] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[ 3055.690300] usb 1-6: reset full-speed USB device number 5 using xhci_hcd
[ 3055.953644] usb 1-1: reset high-speed USB device number 2 using xhci_hcd
[ 3056.216966] usb 1-11: reset high-speed USB device number 7 using xhci_hcd
[ 3056.434008] [drm] RC6 on
[ 3056.480051] usb 1-2: reset high-speed USB device number 3 using xhci_hcd
[ 3056.833088] usb 1-6:1.0: rebind failed: -517
[ 3056.833100] usb 1-6:1.1: rebind failed: -517
[ 3056.833713] OOM killer enabled.
[ 3056.833715] Restarting tasks ...
[ 3056.834384] pci_bus 0000:05: Allocating resources
[ 3056.834461] pcieport 0000:05:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3a] add_size 200000 add_align 100000
[ 3056.834504] pcieport 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 3056.834526] pcieport 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 3056.834535] pcieport 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 3056.834540] pcieport 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 3056.837833] done.
[ 3056.838748] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[ 3056.838750] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[ 3056.882618] PM: suspend exit
[ 3056.893518] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[ 3056.903942] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3056.908180] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3056.912702] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3057.713565] ath10k_pci 0000:02:00.0: Unknown eventid: 3
[ 3057.739305] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[ 3057.786187] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3057.879105] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3058.433926] pci_bus 0000:05: Allocating resources
[ 3058.434004] pcieport 0000:05:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3a] add_size 200000 add_align 100000
[ 3058.434045] pcieport 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 3058.434049] pcieport 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 3058.434055] pcieport 0000:05:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[ 3058.434059] pcieport 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 3062.777159] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3067.726346] wlp2s0: authenticate with d4:6a:91:a6:5a:e5
[ 3067.781016] wlp2s0: send auth to d4:6a:91:a6:5a:e5 (try 1/3)
[ 3067.782189] wlp2s0: authenticated
[ 3067.786650] wlp2s0: associate with d4:6a:91:a6:5a:e5 (try 1/3)
[ 3067.788989] wlp2s0: RX AssocResp from d4:6a:91:a6:5a:e5 (capab=0x1511 status=0 aid=6)
[ 3067.792104] wlp2s0: associated
[ 3067.804255] ath: EEPROM regdomain: 0x8348
[ 3067.804257] ath: EEPROM indicates we should expect a country code
[ 3067.804259] ath: doing EEPROM country->regdmn map search
[ 3067.804261] ath: country maps to regdmn code: 0x3a
[ 3067.804264] ath: Country alpha2 being used: US
[ 3067.804265] ath: Regpair used: 0x3a
[ 3067.804267] ath: regdomain 0x8348 dynamically updated by country IE
[ 3067.812995] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 3067.887208] wlp2s0: Limiting TX power to 24 (24 - 0) dBm as advertised by d4:6a:91:a6:5a:e5
[ 3082.919153] input: Surface Mouse as /devices/virtual/misc/uhid/0005:045E:0919.0006/input/input32
[ 3082.919461] hid-generic 0005:045E:0919.0006: input,hidraw4: BLUETOOTH HID v1.10 Mouse [Surface Mouse] on 9C:B6:D0:91:CA:40
I also noticed there are a couple of other people reporting similar thunderbolt related errors:
@Yochanan or @imsesaok would you guys mind weighing in here? Is your thunderbolt dead after the update?
#7
My laptop doesn’t have Thunderbolt. :man_shrugging:
#8
As Jonathon already mentioned, perhaps this is a kernel (or possibly a firmware regression). Have you tested other kernels yet.
#9
Damn… You’re right. It is a regression in 4.14. If I moved the kernel to 4.20, my thunderbolt returns. But kernel 4.20 has major bluetooth stability issues for me. I can use an external bluetooth dongle as a temporary work around, but it is super not ideal… I’ll open a bug on kernel.org.
#10
Kind of figured that might be what caused it. What exactly is the issue with your Bluetooth on 4.20. Did you test 4.19 perhaps you could get lucky and they are both working there.
Please post:
inxi -Fxxxz
#11
@tbg you were helping me on it in a separate thread here:
#12
Be aware that if you’re on stable there’s already a new 4.14.102 in unstable.
#13
No thunderbolt so no comment.
