Hello,
using ctrl+h is crashing thunar. This happens on both of my two xfce systems. This is not related to todays testing update, because on my second machine I tried out before updating.
SIGSEGV
Thread 1 "thunar" received signal SIGSEGV, Segmentation fault.
0x00007ffff718e932 in g_node_traverse_pre_order (node=<optimized out>, flags=flags@entry=G_TRAVERSE_ALL,
func=func@entry=0x5555555e1040 <thunar_tree_model_node_traverse_visible>, data=data@entry=0x555555a16220)
at ../glib/glib/gnode.c:506
…will revert to stable, see how that goes…
Edit: Thunar also crashes on stable, reverting to stock configuration by deleting uca.xml file doesn’t help. Back to testing.
inxi
$ inxi -zv8
Kernel: 6.18.22-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d1c1f021-26a1-4666-bc9e-b859a2f2d269 ro nowatchdog quiet
loglevel=3 rd.udev.log_level=3 zswap.enabled=0
Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 21CKCTO1WW v: ThinkPad P16s Gen 1
Mobo: LENOVO model: 21CKCTO1WW v: ThinkPad serial: <superuser required>
part-nu: LENOVO_MT_21CK_BU_Think_FM_ThinkPad P16s Gen 1
uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: R23ET86W (1.62 ) date: 12/10/2025
ID-1: BAT0 charge: 75.2 Wh (84.1%) condition: 89.4/86 Wh (104%) volts: 15.3
min: 15.44 model: SMP LNV-5B10W51871�� type: Li-poly serial: <filter>
charging: status: not charging control: start: 70% end: 85% cycles: 2
System RAM: total: 32 GiB available: 27.17 GiB used: 2.34 GiB (8.6%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
part-no: H9JCNNNFA5MLYR-N6E serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA40410A
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2670 min/max: 402/2701 boost: disabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2670 2: 2670 3: 2670
4: 2670 5: 2670 6: 2670 7: 2670 8: 2670 9: 2670 10: 2670 11: 2670 12: 2670
13: 2670 14: 2670 15: 2670 16: 2670 bogomips: 86234
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 31.0 C
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 30c9:0050 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.22 with: Xwayland v: 24.1.10
compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: Samsung
serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 40 gamma: 1.2 chroma: red: x: 0.643 y: 0.329 green: x: 0.302 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.278 y: 0.290
size: 1210x680mm (47.64x26.77") diag: 801mm (31.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1366x768,
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model: Lenovo 0x41b7
built: 2021 res: 1920x1080 dpi: 141 gamma: 1.2 chroma: red: x: 0.651
y: 0.333 green: x: 0.302 y: 0.612 blue: x: 0.145 y: 0.059 white: x: 0.318
y: 0.337 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.4-arch1.1
rembrandt ACO DRM 3.64 6.18.22-1-MANJARO) device-ID: 1002:1681
memory: 3.91 GiB unified: no
API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 26.0.4-arch1.1
device-ID: 1002:1681 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.18.22-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.3 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
Local Storage: total: 953.87 GiB used: 131.16 GiB (13.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA1T0TFK
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 7003V5LN temp: 24.9 C
scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 20.03 GiB (20.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: d1c1f021-26a1-4666-bc9e-b859a2f2d269
used: 404 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5759-84E8
ID-3: /home raw-size: 853.37 GiB size: 838.9 GiB (98.30%)
used: 111.12 GiB (13.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: f986f6b3-74b9-4497-bf9f-5797e5bd003f
ID-1: swap-1 type: zram size: 13.58 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 3 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-1:2 info: Microsoft Wireless keyboard (All-in-One-Media)
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 045e:0800 class-ID: 0300
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Luxvisions Innotech Integrated RGB Camera
type: video driver: uvcvideo interfaces: 5 rev: 2.0
Hub-7: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 30.0 C
Fan Speeds (rpm): fan-1: 3100
Packages: pm: pacman pkgs: 1435 libs: 406 tools: pamac,yay pm: rpm pkgs: 0
1: https://mirrors.manjaro.org/repo/testing/$repo/$arch
2: https://mirrors2.manjaro.org/testing/$repo/$arch
Processes:
CPU top: 5 of 478
1: cpu: 6.8% command: chromium pid: 183984 mem: 253.1 MiB (0.9%)
2: cpu: 4.7% command: xfce4-terminal pid: 184601 mem: 52.8 MiB (0.1%)
3: cpu: 2.9% command: chromium pid: 178512 mem: 353.6 MiB (1.2%)
4: cpu: 2.5% command: chromium pid: 178820 mem: 315.3 MiB (1.1%)
5: cpu: 2.0% command: chromium pid: 178794 mem: 242.7 MiB (0.8%)
Memory top: 5 of 478
1: mem: 353.6 MiB (1.2%) command: chromium pid: 178512 cpu: 2.9%
2: mem: 315.3 MiB (1.1%) command: chromium pid: 178820 cpu: 2.5%
3: mem: 256.7 MiB (0.9%) command: chromium pid: 178558 cpu: 1.5%
4: mem: 253.1 MiB (0.9%) command: chromium pid: 183984 cpu: 6.8%
5: mem: 242.7 MiB (0.8%) command: chromium pid: 178794 cpu: 2.0%
Processes: 478 Power: uptime: 5h 47m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 10.82 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Bash v: 5.3.9
running-in: xfce4-terminal inxi: 3.3.40
