Thunar GTK3 problem
the same for exo-gtk3
for removing xfce4 it says thunar-shares-plugin-manjaro. removing thunar breaks dependencies.
Force it - we are going to reinstall anyway.
sudo pacman -Rdd libxfce4ui-gtk3 exo-gtk3 thunar-shares-plugin-manjaro
Will do it.
Just keep removing till it stops complaining - then reinstall:
sudo pacman -S xfce4 xfce4-goodies
You have lxde to fall back on.
Thank you Xircon,
It worked. As you said, I had to remove another file (xfconf, or so). But finally i was able to install XFCE again. Best regards
