Hay all,
new Manjaro user on a Thinkpad x201. I am running Manjaro stable Plasma. I did a fresh install of Manjaro a couple of months back on this laptop and then had it turned off for a couple of months. I started to use the laptop again within the last couple weeks. and the battery is showing that it is not charging, at 0% while charged in.
when I run acpi -V in terminal I get:
[scott@Manjarox201 ~]$ acpi -V
Battery 0: Charging, 0%, charging at zero rate - will never fully charge.
Battery 0: design capacity 4752 mAh, last full capacity 4061 mAh = 85%
Adapter 0: on-line
Thermal 0: ok, 50.0 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 100.0 degrees C
Thermal 0: trip point 1 switches to mode passive at temperature 91.5 degrees C
Cooling 0: Processor 0 of 10
Cooling 1: intel_powerclamp no state information available
Cooling 2: Processor 0 of 10
Cooling 3: Processor 0 of 10
Cooling 4: LCD 3 of 15
Cooling 5: Processor 0 of 10
I am currently updating the system via pacman -Syu
any thoughts or ideas? I can run some additional diagnostics if y’all can give me some to run.
Thanks,
Scott aka Hunn2020
