Thinkpad Camera has Artifacts
My thinkpad T14 camera is having artifacts. See the below video for an example of the camera taking a video of a blank wall. As you can see, it’s flickering and flashing
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=578c1959-57e6-4426-a816-e9a40ab3bf12 rw quiet
    cryptdevice=UUID=57f8f67f-44f9-4952-b211-28928da37af7:luks-57f8f67f-44f9-4952-b211-28928da37af7
    root=/dev/mapper/luks-57f8f67f-44f9-4952-b211-28928da37af7 splash
    resume=/dev/mapper/luks-b862e74a-e367-4b78-bab3-730dd27d7c2e
    udev.log_priority=3 intel_iommu=on kvm.ignore_msrs=1
    vfio-pci.ids=8086:4626
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Laptop System: LENOVO product: 21AH001DUS v: ThinkPad T14 Gen 3
  Mobo: LENOVO model: 21AH001DUS v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21AH_BU_Think_FM_ThinkPad
    T14 Gen 3 uuid: <superuser required> UEFI: LENOVO v: N3MET18W (1.17 )
    date: 10/24/2023
  ID-1: BAT0 charge: 19.7 Wh (43.3%) condition: 45.5/52.5 Wh (86.7%)
    power: 9.1 W volts: 15.1 min: 15.5 model: SMP 5B10W51864 type: Li-poly
    serial: <filter> status: discharging cycles: 106
  System RAM: total: 16 GiB available: 15.33 GiB used: 5.76 GiB (37.6%)
  Array-1: capacity: 256 GiB slots: 8 modules: 1 EC: None
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A2G44BM0-CWE serial: N/A
  Device-2: Controller0-ChannelB-DIMM0 type: no module installed
  Device-3: Controller0-ChannelC-DIMM0 type: no module installed
  Device-4: Controller0-ChannelD-DIMM0 type: no module installed
  Device-5: Controller1-ChannelA-DIMM0 type: no module installed
  Device-6: Controller1-ChannelB-DIMM0 type: no module installed
  Device-7: Controller1-ChannelC-DIMM0 type: no module installed
  Device-8: Controller1-ChannelD-DIMM0 type: no module installed
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x434
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 966 min/max: 400/4700:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 966 2: 966 3: 966 4: 966 5: 966 6: 966 7: 966
    8: 966 9: 966 10: 966 11: 966 12: 966 13: 966 14: 966 15: 966 16: 966
    bogomips: 79888
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:4626 class-ID: 0300
  Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:004f
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:4626 memory: 7.49 GiB unified: yes display-ID: :1.0
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: br-d80680a085fb state: down mac: <filter>
  IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: veth944f454 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: luks-57f8f67f-44f9-4952-b211-28928da37af7 maj-min: 254:0
    type: LUKS dm: dm-0 size: 936.7 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 936.7 GiB
  Device-2: luks-b862e74a-e367-4b78-bab3-730dd27d7c2e maj-min: 254:1
    type: LUKS dm: dm-1 size: 16.86 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 16.86 GiB
  Local Storage: total: 953.87 GiB used: 98.87 GiB (10.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ9X102N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51730A10 temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 936.7 GiB size: 920.93 GiB (98.32%) used: 98.87 GiB (10.7%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-57f8f67f-44f9-4952-b211-28928da37af7 label: N/A
    uuid: 578c1959-57e6-4426-a816-e9a40ab3bf12
    used: 924 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 6E49-A7B6
  ID-1: swap-1 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-b862e74a-e367-4b78-bab3-730dd27d7c2e label: swap
    uuid: a61dcebd-47dd-4ae4-86a2-03bafe50c823
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:5 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  Device-2: 3-4:3 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 30c9:004f class-ID: fe01 serial: <filter>
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1963 libs: 501 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirrors2.manjaro.org/stable/$repo/$arch
    4: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    6: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 387
  1: cpu: 17.6% command: zoom pid: 48571 mem: 766.5 MiB (4.8%)
  2: cpu: 16.6% command: brave pid: 49031 mem: 331.8 MiB (2.1%)
  3: cpu: 10.1% command: aomhost pid: 48987 mem: 50.8 MiB (0.3%)
  4: cpu: 9.4% command: brave pid: 39522 mem: 415.7 MiB (2.6%)
  5: cpu: 5.7% command: brave pid: 48241 mem: 292.2 MiB (1.8%)
  Memory top: 5 of 387
  1: mem: 766.5 MiB (4.8%) command: zoom pid: 48571 cpu: 17.6%
  2: mem: 579.9 MiB (3.6%) command: brave pid: 38493 cpu: 2.9%
  3: mem: 571.1 MiB (3.6%) command: Discord pid: 28907 cpu: 0.8%
  4: mem: 443.4 MiB (2.8%) command: plasmashell pid: 1613 cpu: 0.0%
  5: mem: 415.7 MiB (2.6%) command: brave pid: 39522 cpu: 9.4%
  Processes: 387 Power: uptime: 1d 13h 35m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Hi there. It might not work but have you tried more established LTS kernels, like 5.15 & 6.1? If you haven’t tried these, it’s worth a shot. All the best! Ruziel :wink:
PS, check out the following link & also look into fwupd under section 1.1…
https://wiki.archlinux.org/title/Lenovo_ThinkPad_T14_(AMD)_Gen_3
Hi there! Thanks so much for the reply. I have tried that to no avail. I really hope this isn’t a hardware issue but I’ll have to check if there aren’t any more ideas
OK, yeah hopefully it’s not a hardware issue. I guess you could try running a live ISO of a different distro on a stick & seeing how it looks. All the best with it!
