manjaro-arm-installer throws some errors while creating a sdcard for rpi 3b.
==> Proceeding....
-> Getting package lists ready for rpi4 xfce edition...
grep: /var/tmp/manjaro-arm-installer/arm-profiles/devices/rpi4: No existe el fichero o el directorio
grep: /var/tmp/manjaro-arm-installer/arm-profiles/editions/xfce: No existe el fichero o el directorio
grep: /var/tmp/manjaro-arm-installer/arm-profiles/services/xfce: No existe el fichero o el directorio
==> Getting /dev/sdb ready for rpi4...
==> Creating install for rpi4...
-> Used device is /dev/sdb
-> Downloading latest aarch64 rootfs...
Manjaro-ARM-aarch64-latest.ta 100%[================================================>] 167,69M 601KB/s en 4m 50s
-> Extracting aarch64 rootfs...
-> Setting up keyrings...
-> Generating mirrorlist...
-> Installing packages for xfce on rpi4...
core 225.3 KiB 463 KiB/s 00:00 [########################################] 100%
extra 2.4 MiB 720 KiB/s 00:03 [########################################] 100%
community 5.5 MiB 676 KiB/s 00:08 [########################################] 100%
warning: systemd-libs-246.6-1.1 is up to date -- reinstalling
resolving dependencies...
Packages (44) argon2-20190702-3 cryptsetup-2.3.4-1 dbus-1.12.20-1 device-mapper-2.02.187-3 file-5.39-1
gettext-0.21-1 grep-3.6-1 gzip-1.10-3 hwids-20200813.1-1 icu-67.1-1 iproute2-5.9.0-1
iptables-1:1.8.6-1 iputils-20200821-1 json-c-0.15-1 kbd-2.3.0-2 kmod-27-2 less-563-1
libcroco-0.6.13-2 libelf-0.181-1 libmnl-1.0.4-3 libnetfilter_conntrack-1.0.8-1 libnfnetlink-1.0.1-4
libnftnl-1.1.8-1 libnl-3.5.0-2 libpcap-1.9.1-4 libseccomp-2.4.2-1.1 libxml2-2.9.10-6
licenses-20200427-1 lsb-release-1.4-13 pciutils-3.7.0-1 pcre2-10.35-1 popt-1.18-1
procps-ng-3.3.16-2 psmisc-23.3-2 sed-4.8-1 shadow-4.8.1-4 systemd-sysvcompat-246.6-1.1 tar-1.32-3
util-linux-2.36.1-3 base-2-2 manjaro-release-20.10-1 manjaro-system-20200428-1 systemd-246.6-1.1
Total Download Size: 20.63 MiB
Total Installed Size: 138.80 MiB
Net Upgrade Size: 136.45 MiB
:: Retrieving packages...
file-5.39-1-aarch64 311.7 KiB 561 KiB/s 00:01 [########################################] 100%
grep-3.6-1-aarch64 193.5 KiB 165 KiB/s 00:01 [########################################] 100%
procps-ng-3.3.16-2-aarch64 342.4 KiB 650 KiB/s 00:01 [########################################] 100%
sed-4.8-1-aarch64 216.6 KiB 739 KiB/s 00:00 [########################################] 100%
tar-1.32-3-aarch64 738.3 KiB 734 KiB/s 00:01 [########################################] 100%
icu-67.1-1-aarch64 8.9 MiB 657 KiB/s 00:14 [########################################] 100%
gettext-0.21-1-aarch64 1942.0 KiB 481 KiB/s 00:04 [########################################] 100%
hwids-20200813.1-1-any 422.3 KiB 575 KiB/s 00:01 [########################################] 100%
pciutils-3.7.0-1-aarch64 89.4 KiB 1225 KiB/s 00:00 [########################################] 100%
psmisc-23.3-2-aarch64 111.0 KiB 974 KiB/s 00:00 [########################################] 100%
util-linux-2.36.1-3-aarch64 2.2 MiB 717 KiB/s 00:03 [########################################] 100%
less-563-1-aarch64 103.6 KiB 779 KiB/s 00:00 [########################################] 100%
gzip-1.10-3-aarch64 77.1 KiB 741 KiB/s 00:00 [########################################] 100%
licenses-20200427-1-any 66.8 KiB 1422 KiB/s 00:00 [########################################] 100%
device-mapper-2.02.187-3-aarch64 259.3 KiB 735 KiB/s 00:00 [########################################] 100%
popt-1.18-1-aarch64 64.0 KiB 1778 KiB/s 00:00 [########################################] 100%
json-c-0.15-1-aarch64 50.6 KiB 684 KiB/s 00:00 [########################################] 100%
argon2-20190702-3-aarch64 30.3 KiB 1319 KiB/s 00:00 [########################################] 100%
cryptsetup-2.3.4-1-aarch64 505.9 KiB 462 KiB/s 00:01 [########################################] 100%
dbus-1.12.20-1-aarch64 284.9 KiB 334 KiB/s 00:01 [########################################] 100%
libmnl-1.0.4-3-aarch64 10.6 KiB 2.58 MiB/s 00:00 [########################################] 100%
libnftnl-1.1.8-1-aarch64 59.7 KiB 891 KiB/s 00:00 [########################################] 100%
libnl-3.5.0-2-aarch64 355.8 KiB 643 KiB/s 00:01 [########################################] 100%
libnfnetlink-1.0.1-4-aarch64 16.1 KiB 2.25 MiB/s 00:00 [########################################] 100%
libnetfilter_conntrack-1.0.8-1-aarch64 41.8 KiB 1130 KiB/s 00:00 [########################################] 100%
kbd-2.3.0-2-aarch64 1138.9 KiB 699 KiB/s 00:02 [########################################] 100%
pcre2-10.35-1-aarch64 981.5 KiB 715 KiB/s 00:01 [########################################] 100%
libxml2-2.9.10-6-aarch64 1220.7 KiB 732 KiB/s 00:02 [########################################] 100%
libcroco-0.6.13-2-aarch64 144.9 KiB 775 KiB/s 00:00 [########################################] 100%
(44/44) checking keys in keyring [########################################] 100%
(44/44) checking package integrity [########################################] 100%
(44/44) loading package files [########################################] 100%
(44/44) checking for file conflicts [########################################] 100%
(44/44) checking available disk space [########################################] 100%
( 1/44) installing file [########################################] 100%
( 2/44) installing grep [########################################] 100%
( 3/44) reinstalling systemd-libs [########################################] 100%
( 4/44) installing procps-ng [########################################] 100%
( 5/44) installing sed [########################################] 100%
( 6/44) installing tar [########################################] 100%
( 7/44) installing icu [########################################] 100%
( 8/44) installing libxml2 [########################################] 100%
( 9/44) installing libcroco [########################################] 100%
(10/44) installing gettext [########################################] 100%
Optional dependencies for gettext
git: for autopoint infrastructure updates
(11/44) installing hwids [########################################] 100%
(12/44) installing kmod [########################################] 100%
(13/44) installing pciutils [########################################] 100%
(14/44) installing psmisc [########################################] 100%
(15/44) installing shadow [########################################] 100%
(16/44) installing util-linux [########################################] 100%
Optional dependencies for util-linux
python: python bindings to libmount [installed]
words: default dictionary for look
(17/44) installing less [########################################] 100%
(18/44) installing gzip [########################################] 100%
(19/44) installing licenses [########################################] 100%
(20/44) installing device-mapper [########################################] 100%
(21/44) installing popt [########################################] 100%
(22/44) installing json-c [########################################] 100%
(23/44) installing argon2 [########################################] 100%
(24/44) installing cryptsetup [########################################] 100%
(25/44) installing dbus [########################################] 100%
(26/44) installing libmnl [########################################] 100%
(27/44) installing libnftnl [########################################] 100%
(28/44) installing libnl [########################################] 100%
(29/44) installing libpcap [########################################] 100%
(30/44) installing libnfnetlink [########################################] 100%
(31/44) installing libnetfilter_conntrack [########################################] 100%
(32/44) installing iptables [########################################] 100%
(33/44) installing kbd [########################################] 100%
(34/44) installing libelf [########################################] 100%
(35/44) installing libseccomp [########################################] 100%
(36/44) installing pcre2 [########################################] 100%
(37/44) installing systemd [########################################] 100%
warning: directory permissions differ on /var/log/journal/
filesystem: 755 package: 2755
Initializing machine ID from container UUID.
Creating group sys with gid 3.
Creating group mem with gid 8.
Creating group ftp with gid 11.
Creating group mail with gid 12.
Creating group log with gid 19.
Creating group smmsp with gid 25.
Creating group proc with gid 26.
Creating group games with gid 50.
Creating group lock with gid 54.
Creating group network with gid 90.
Creating group floppy with gid 94.
Creating group scanner with gid 96.
Creating group power with gid 98.
Creating group adm with gid 999.
Creating group wheel with gid 998.
Creating group kmem with gid 997.
Creating group tty with gid 5.
Creating group utmp with gid 996.
Creating group audio with gid 995.
Creating group disk with gid 994.
Creating group input with gid 993.
Creating group kvm with gid 992.
Creating group lp with gid 991.
Creating group optical with gid 990.
Creating group render with gid 989.
Creating group storage with gid 988.
Creating group uucp with gid 987.
Creating group video with gid 986.
Creating group users with gid 985.
Creating group systemd-journal with gid 984.
Creating group rfkill with gid 983.
Creating group bin with gid 1.
Creating user bin (n/a) with uid 1 and gid 1.
Creating group daemon with gid 2.
Creating user daemon (n/a) with uid 2 and gid 2.
Creating user mail (n/a) with uid 8 and gid 12.
Creating user ftp (n/a) with uid 14 and gid 11.
Creating group http with gid 33.
Creating user http (n/a) with uid 33 and gid 33.
Creating group nobody with gid 65534.
Creating user nobody (Nobody) with uid 65534 and gid 65534.
Creating group dbus with gid 81.
Creating user dbus (System Message Bus) with uid 81 and gid 81.
Creating group systemd-journal-remote with gid 982.
Creating user systemd-journal-remote (systemd Journal Remote) with uid 982 and gid 982.
Creating group systemd-network with gid 981.
Creating user systemd-network (systemd Network Management) with uid 981 and gid 981.
Creating group systemd-resolve with gid 980.
Creating user systemd-resolve (systemd Resolver) with uid 980 and gid 980.
Creating group systemd-timesync with gid 979.
Creating user systemd-timesync (systemd Time Synchronization) with uid 979 and gid 979.
Creating group systemd-coredump with gid 978.
Creating user systemd-coredump (systemd Core Dumper) with uid 978 and gid 978.
Creating group uuidd with gid 68.
Creating user uuidd (n/a) with uid 68 and gid 68.
Created symlink /etc/systemd/system/getty.target.wants/getty@tty1.service → /usr/lib/systemd/system/getty@.service.
Created symlink /etc/systemd/system/multi-user.target.wants/remote-fs.target → /usr/lib/systemd/system/remote-fs.target.
:: Append 'init=/usr/lib/systemd/systemd' to your kernel command line in your
bootloader to replace sysvinit with systemd, or install systemd-sysvcompat
Optional dependencies for systemd
libmicrohttpd: remote journald capabilities
quota-tools: kernel-level quota management
systemd-sysvcompat: symlink package to provide sysvinit binaries [pending]
polkit: allow administration as unprivileged user
curl: machinectl pull-tar and pull-raw [installed]
(38/44) installing systemd-sysvcompat [########################################] 100%
(39/44) installing iputils [########################################] 100%
(40/44) installing iproute2 [########################################] 100%
Optional dependencies for iproute2
linux-atm: ATM support
(41/44) installing base [########################################] 100%
Optional dependencies for base
linux: bare metal support
(42/44) installing manjaro-system [########################################] 100%
(43/44) installing lsb-release [########################################] 100%
(44/44) installing manjaro-release [########################################] 100%
(1/9) Creating system user accounts...
(2/9) Updating journal message catalog...
(3/9) Reloading system manager configuration...
Skipped: Current root is not booted.
(4/9) Updating udev hardware database...
(5/9) Applying kernel sysctl settings...
(6/9) Creating temporary files...
(7/9) Reloading device manager configuration...
Skipped: Device manager is not running.
(8/9) Arming ConditionNeedsUpdate...
(9/9) Reloading system bus configuration...
-> Enabling services...
-> Applying overlay for xfce...
cp: no se puede efectuar `stat' sobre '/var/tmp/manjaro-arm-installer/arm-profiles/overlays/xfce/*': No existe el fichero o el directorio
-> Setting up users...
-> Setting password for root ...
-> Adding user...
-> Enabling user services...
-> Setting up system settings...
Generating locales...
es_ES.UTF-8... done
Generation complete.
/usr/bin/manjaro-arm-installer: línea 191: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No existe el fichero o el directorio
/usr/bin/manjaro-arm-installer: línea 192: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No existe el fichero o el directorio
/usr/bin/manjaro-arm-installer: línea 193: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No existe el fichero o el directorio
/usr/bin/manjaro-arm-installer: línea 194: /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No existe el fichero o el directorio
sed: no se puede leer /var/tmp/manjaro-arm-installer/root/etc/X11/xorg.conf.d/00-keyboard.conf: No existe el fichero o el directorio
Correcting permissions from overlay...
chown: no se puede acceder a '/var/tmp/manjaro-arm-installer/root/etc/polkit-1/rules.d': No existe el fichero o el directorio
-> Cleaning install for unwanted files...
==> rpi4 xfce install complete
==> Writing bootloader and cleaning up after install...
mv: no se puede efectuar `stat' sobre '/var/tmp/manjaro-arm-installer/root/boot/*': No existe el fichero o el directorio
==> Time : 18.80 minutes...
Edit:
System doesn’t start, so I think something might be broken.
Boot partition was empty when finished the filesystem creation process, I’m not sure if that is correct.
It was an xfce system.
