Hello, I am currently having an issue with my dell laptop where anytime I run a load with prime-run
my system doesn’t seem to thermal throttle properly. The nvidia xserver settings reports slowdown temp (which I am assuming is thermal throttle?) of 96 degrees however my system shuts down at 93-94. I also had this problem on the unstable debian branch (debian 11 IIRC) but have been using manjaro for a while and figured I’d actually ask for help this time.
It’s not an issue with cooling in general as in windows it can throttle and manage it’s self just fine, Running sensors in linux I can see and feel the fans doing work. I’m also assuming it’s not driver related as I’m gone through several driver updates/reinstalls and no one else is having this issue (as far as I can find).
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=21ab1e97-d077-44df-938b-cb68958bfea2 rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd-intel-dspcfg.dsp_driver=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Convertible System: Dell product: Inspiron 5491 2n1 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: Dell model: 0T4D59 v: A00 serial: <filter> UEFI: Dell v: 1.5.0
date: 02/04/2020
ID-1: BAT0 charge: 36.4 Wh condition: 37.8/42.0 Wh (90%) volts: 12.5/11.4
model: Samsung SDI DELL 0FJMK99 type: Li-ion serial: <filter>
status: Discharging
Device-1: hid-0018:04F3:273D.0002-battery model: CUST0000:00 04F3:273D
serial: N/A charge: N/A status: N/A
Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 8 MiB
bogomips: 36812
Speed: 1462 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 1462 2: 1731
3: 1516 4: 1383 5: 2013 6: 2243 7: 1228 8: 1027
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41 class ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Dell driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1d11
class ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 0bda:5678 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: fbdev alternate: intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:02c8 class ID: 0401
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:02f0 class ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus ID: 1-10:4 chip ID: 8087:0aaa class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 253.63 GiB (53.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 11001101 temp: 27.9 C
scheme: GPT
ID-1: / raw size: 342.77 GiB size: 336.39 GiB (98.14%)
used: 253.55 GiB (75.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw size: 150 MiB size: 146 MiB (97.33%)
used: 85.2 MiB (58.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 255 Uptime: 5h 58m wakeups: 999 Memory: 7.44 GiB
used: 3.64 GiB (48.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1511 lib: 449 flatpak: 0 Shell: Bash v: 5.1.0 running in: yakuake
inxi: 3.3.01
