As stated.
Installed on a usb stick.
Installation went perfect, but initial update, both with pacman and pamac fails with dependency conflicts.
Pacman:
(1/1) upgrading archlinux-keyring [#######################] 100%
==> Appending keys from archlinux.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 1 keys.
==> Importing owner trust values...
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
-> Disabled 5 keys.
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 22 signed: 95 trust: 0-, 0q, 0n, 22m, 0f, 0u
gpg: depth: 2 valid: 73 signed: 27 trust: 73-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-12-31
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
:: Replace appstream-qt with extra/appstream-qt5? [Y/n]
:: Replace attica with extra/attica5? [Y/n]
:: Replace baloo with extra/baloo5? [Y/n]
:: Replace bluez-qt with extra/bluez-qt5? [Y/n]
:: Replace frameworkintegration with extra/frameworkintegration5? [Y/n]
:: Replace kactivities with extra/kactivities5? [Y/n]
:: Replace kactivities-stats with extra/kactivities-stats5? [Y/n]
:: Replace karchive with extra/karchive5? [Y/n]
:: Replace kauth with extra/kauth5? [Y/n]
:: Replace kbookmarks with extra/kbookmarks5? [Y/n]
:: Replace kcmutils with extra/kcmutils5? [Y/n]
:: Replace kcodecs with extra/kcodecs5? [Y/n]
:: Replace kcompletion with extra/kcompletion5? [Y/n]
:: Replace kconfig with extra/kconfig5? [Y/n]
:: Replace kconfigwidgets with extra/kconfigwidgets5? [Y/n]
:: Replace kcontacts with extra/kcontacts5? [Y/n]
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n]
:: Replace kcrash with extra/kcrash5? [Y/n]
:: Replace kdbusaddons with extra/kdbusaddons5? [Y/n]
:: Replace kdeclarative with extra/kdeclarative5? [Y/n]
:: Replace kded with extra/kded5? [Y/n]
:: Replace kdesu with extra/kdesu5? [Y/n]
:: Replace kdnssd with extra/kdnssd5? [Y/n]
:: Replace kdoctools with extra/kdoctools5? [Y/n]
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n]
:: Replace kfilemetadata with extra/kfilemetadata5? [Y/n]
:: Replace kglobalaccel with extra/kglobalaccel5? [Y/n]
:: Replace kguiaddons with extra/kguiaddons5? [Y/n]
:: Replace kholidays with extra/kholidays5? [Y/n]
:: Replace ki18n with extra/ki18n5? [Y/n]
:: Replace kiconthemes with extra/kiconthemes5? [Y/n]
:: Replace kidletime with extra/kidletime5? [Y/n]
:: Replace kimageformats with extra/kimageformats5? [Y/n]
:: Replace kio with extra/kio5? [Y/n]
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n]
:: Replace kitemmodels with extra/kitemmodels5? [Y/n]
:: Replace kitemviews with extra/kitemviews5? [Y/n]
:: Replace kjobwidgets with extra/kjobwidgets5? [Y/n]
:: Replace knewstuff with extra/knewstuff5? [Y/n]
:: Replace knotifications with extra/knotifications5? [Y/n]
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n]
:: Replace kpackage with extra/kpackage5? [Y/n]
:: Replace kparts with extra/kparts5? [Y/n]
:: Replace kpeople with extra/kpeople5? [Y/n]
warning: kpeoplevcard: local (0.1+r38.32d50a9-1) is newer than extra (0.1-2)
:: Replace kpty with extra/kpty5? [Y/n]
:: Replace kquickcharts with extra/kquickcharts5? [Y/n]
:: Replace krunner with extra/krunner5? [Y/n]
:: Replace kservice with extra/kservice5? [Y/n]
:: Replace ktexteditor with extra/ktexteditor5? [Y/n]
:: Replace ktextwidgets with extra/ktextwidgets5? [Y/n]
:: Replace kunitconversion with extra/kunitconversion5? [Y/n]
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n]
:: Replace kwallet with extra/kwallet5? [Y/n]
:: Replace kwayland with extra/kwayland5? [Y/n]
:: Replace kwidgetsaddons with extra/kwidgetsaddons5? [Y/n]
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n]
:: Replace kxmlgui with extra/kxmlgui5? [Y/n]
:: Replace libkcddb with extra/libkcddb5? [Y/n]
:: Replace libkdcraw with extra/libkdcraw5? [Y/n]
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n]
:: Replace modemmanager-qt with extra/modemmanager-qt5? [Y/n]
:: Replace networkmanager-qt with extra/networkmanager-qt5? [Y/n]
:: Replace plasma-framework with extra/plasma-framework5? [Y/n]
:: Replace prison with extra/prison5? [Y/n]
:: Replace purpose with extra/purpose5? [Y/n]
:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n]
:: Replace solid with extra/solid5? [Y/n]
:: Replace sonnet with extra/sonnet5? [Y/n]
:: Replace syndication with extra/syndication5? [Y/n]
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n]
:: Replace threadweaver with extra/threadweaver5? [Y/n]
resolving dependencies...
:: removing kpeople breaks dependency 'kpeople' required by kpeoplevcard
:: removing kcontacts breaks dependency 'kcontacts' required by kpeoplevcard
or pamac upgrade:
Preparing...
Authenticating as: Marcus Johansson (bedna)
Password:
Warning: kpeoplevcard: local (0.1+r38.32d50a9-1) is newer than extra (0.1-2)
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing kpeople breaks dependency 'kpeople' required by kpeoplevcard
- removing kcontacts breaks dependency 'kcontacts' required by kpeoplevcard
I realize now that I checked that there is a tiny bit newer iso available, but the kernel is the same.
I used manjaro-kde-23.0.1-230911-linux65.iso
inxi -Fazy
Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=7da08de4-f75c-43a3-9046-819509d41d1e rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP EliteBook 840 G2
v: A3008D410B03 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2216 v: KBC Version 96.5B
serial: <superuser required> UEFI: Hewlett-Packard v: M71 Ver. 01.18
date: 09/26/2016
ID-1: BAT0 charge: 37.1 Wh (94.4%) condition: 39.3/39.3 Wh (100.0%)
volts: 12.7 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 604 high: 918 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 500 2: 918 3: 500 4: 500
bogomips: 18366
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard ZBook 15u G2 Mobile
Workstation driver: i915 v: kernel arch: Gen-8 process: Intel 14nm
built: 2014-15 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP EliteBook integrated
HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 2-7:5 chip-ID: 05c8:0374 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1495 built: 2013 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.6-3 renderer: Mesa Intel HD Graphics 5500
(BDW GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.5.1-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.79 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:4 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 178.87 GiB used: 13.94 GiB (7.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7SB6S-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1006 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: UFD 64GB UFD 64GB size: 59.63 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: U032 scheme: MBR
ID-1: / raw-size: 47.7 GiB size: 47.7 GiB (100.00%) used: 8.36 GiB (17.5%)
fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-2: /boot/efi raw-size: 300.7 MiB size: 300 MiB (99.79%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb3 maj-min: 8:19
ID-3: /home raw-size: 47.7 GiB size: 47.7 GiB (100.00%)
used: 8.36 GiB (17.5%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-4: /var/log raw-size: 47.7 GiB size: 47.7 GiB (100.00%)
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 199 Uptime: 55m wakeups: 1 Memory: total: 4 GiB
available: 3.71 GiB used: 2.2 GiB (59.3%) Init: systemd v: 253
Packages: pm: pacman pkgs: 1138 libs: 334 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
