I want to turn the screen off after 15 minutes, but not lock the screen after 15 minutes. However, the settings mirror each other. So if I turn the screens off after 15 minutes in Power, the Blank Screen delay in Screen Lock is set to 15 minutes to lock. If I turn the Screen lock setting to never, then it’s also never in blanking the screen in power. And when I come out of lock, it acts like a bootup by automatically starting all my windows all over again instead of bringing me back to where I had been prior to the lock.
inxi:
Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=1b24c3b1-e405-4586-a862-5a33ac595aac rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Apple product: MacBookPro10,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-C3EC7CD22292981F serial: <filter>
Mobo: Apple model: Mac-C3EC7CD22292981F v: MacBookPro10,1 serial: <filter>
UEFI: Apple v: 421.0.0.0.0 date: 12/17/2020
ID-1: BAT0 charge: 93.7 Wh (100.0%) condition: 93.7/91.6 Wh (102.3%)
volts: 12.7 min: 10.9 model: Newer Tech A1417 type: Li-ion serial: N/A
status: Full cycles: 70
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.54 GiB used: 3.12 GiB (20.1%)
Info: Quad Core model: Intel Core i7-3740QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB bogomips: 43112
Speed: 3492 MHz min/max: 1200/3700 MHz Core speeds (MHz): 1: 3492 2: 3492
3: 3492 4: 3508 5: 3555 6: 3492 7: 3515 8: 3558
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8510 class-ID: 0e02 serial: <filter>
Device-4: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
bus-ID: 3-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
Device-5: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
bus-ID: 4-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: NVE7 v: 4.3 Mesa 21.0.3 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Logitech H600 [Wireless Headset] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.3:6 chip-ID: 046d:0a29
class-ID: 0300 serial: <filter>
Device-4: Apple Thunderbolt Display Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:3 chip-ID: 05ac:1107
Device-5: Apple Thunderbolt Display Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 4-1.4:3 chip-ID: 05ac:1107
Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Broadcom NetXtreme BCM57786 Gigabit Ethernet PCIe driver: N/A
port: 2000 bus-ID: 03:00.0 chip-ID: 14e4:16a3 class-ID: 0200
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma port: 2000 bus-ID: 04:00.0
chip-ID: 14e4:4331 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-3: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
driver: tg3 v: kernel port: 2000 bus-ID: 0d:00.0 chip-ID: 14e4:16b0
class-ID: 0200
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-4: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
driver: tg3 v: kernel port: 2000 bus-ID: 3e:00.0 chip-ID: 14e4:16b0
class-ID: 0200
IF: enp62s0 state: down mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:8 chip-ID: 05ac:8286 class-ID: fe01
Local Storage: total: 931.51 GiB used: 97.06 GiB (10.4%)
ID-1: /dev/sda maj-min: 8:0 model: Aura Pro S MB258 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 6ANR scheme: GPT
ID-1: / raw-size: 186.06 GiB size: 182.08 GiB (97.86%)
used: 32.7 GiB (18.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 1b24c3b1-e405-4586-a862-5a33ac595aac
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
used: 8.4 MiB (4.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 67E3-17ED
ID-3: /run/media/bryankarlan/Data raw-size: 202.81 GiB
size: 198.57 GiB (97.91%) used: 64.35 GiB (32.4%) fs: ext4 dev: /dev/sda3
maj-min: 8:3 label: Data uuid: 118bfd46-6603-48f5-b56c-2fd577082f14
ID-1: swap-1 type: partition size: 16.77 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 2feb6cc8-3860-4730-8947-66bdfab3c1f6
ID-1: /dev/sda2 maj-min: 8:2 size: 525.56 GiB fs: ext4 label: N/A
uuid: 2888ee6c-3156-40cc-ab58-b2efb0745350
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2512 class-ID: 0900
Hub-6: 2-1.8.1:4
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.8.1.3:8 info: Apple Bluetooth Host Controller type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8286
class-ID: fe01
Device-2: 2-1.8.2:5 info: Apple Apple Internal Keyboard / Trackpad
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0262 class-ID: 0301
Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 3-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 05ac:9127 class-ID: 0900
Device-1: 3-1.3:6 info: Logitech H600 [Wireless Headset] type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 144mA chip-ID: 046d:0a29 class-ID: 0300
serial: <filter>
Device-2: 3-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
speed: 12 Mb/s power: 2mA chip-ID: 05ac:1107 class-ID: 0300 serial: <filter>
Device-3: 3-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
Device-4: 3-1.7:5 info: Apple Thunderbolt Display type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
chip-ID: 05ac:9227 class-ID: 0300 serial: <filter>
Hub-9: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-10: 4-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
Device-1: 4-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
Device-2: 4-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
Device-3: 4-1.7:5 info: Apple Thunderbolt Display type: HID
Hub-11: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-12: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-13: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-14: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-15: 9-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 9-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-16: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 97.0 C mobo: 55.0 C gpu: nouveau temp: 67.0 C
Processes: 331 Uptime: N/A wakeups: 7 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1307 pacman: 1284 lib: 308
flatpak: 15 snap: 8 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.04
