I downloaded some themes including Manjaro-cyan-plasma one from the kde web page Plasma Themes - KDE Store t
I installed OCS, and the themes installed from the web with that went to ~/.local/share/aurorae/themes and did not appear
I searched and it seems themes are stored at /usr/share/sddm/themes
And I searched if there were any way of adding folders to the themes interface in configuration to be able to use both or any other way of being able to use both directories to keep OCS installs but working, or to change the OCS install directory by default, and I cannot find it.
I suppose copying the themes as root would work, but wouldn’t be better being able to have your root default themes in /usr and some other ones in ~/.local ?
