Hello there
I uploaded manjaro. I want to change the theme color.
How can I do?
I did not do it with kvantum.
thank
You need to edit the gtk file of the theme and change the color code.
You find the file to change at /usr/share/themes/[choose theme]/gtk3.0/gtk.css
Thanks for the answer.
I looked for gtk.css and couldn’t find it.
I’m using a gnome desktop
Which theme are you ttrying to alter?
GNOME 3 desktop.
You’re using Gnome 3 as DE, but the theme you want to alter have a name. If it’s the default you can check “Tweaks” app to see its name.
I changed the Theme in the Tweaks, Appearance, Themes, apps tab and got it done.
Storm,
I say thank you very much.
