I’ve been playing The Ur-Quan Masters Megamod and now after the last update the game will not load. Here is what I get when I use the Terminal:
uqm-megamod
he Ur-Quan Masters v0.8.1 MegaMod (compiled May 3 2022 16:42:54)
This software comes with ABSOLUTELY NO WARRANTY;
for details see the included 'COPYING' file.
Netplay protocol version 0.4. Netplay opponent must have UQM 0.8.1 or later.
GCC_VERSION: 11.2.0
GCC_VERSION: 11.2.0
Buid Time: May 3 2022 16:42:54
Initializing base SDL functionality.
Using SDL version 2.0.22 (compiled with 2.0.20)
Compiled with 2.0.20
Using config dir '/home/william/.local/share/uqm-megamod/'
uio_getFileSystemHandler 0x5557557735e0
Using '/usr/share/uqm-megamod/content' as base content dir.
uio_open mm-0.8.1-content.uqm
uio_getFileSystemHandler 0x555755773780
uio_open mm-0.8.1-3dovoice.uqm
uio_open mm-0.8.1-hd.uqm
uio_open mm-0.8.1-sol-textures.uqm
uio_open mm-0.8.1-vols-remix.uqm
uio_open uqm-0.7.0-3DOMusicRemastered.uqm
uio_open uqm-0.7.0-3dovideo.uqm
7 available addon packs.
1. 3domusic
2. 3dovideo
3. 3dovoice
4. mm-hd
5. sol-textures-hd
6. sol-textures-sd
7. volasaurus-remix-pack
Saved games are kept in /home/william/.local/share/uqm-megamod/save/.
Initializing SDL.
SDL initialized.
Initializing Screen.
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 159
Current serial number in output stream: 160
Do not know how to display an error box
I get the same when I try the play the regular game. Should I wait until the Maintainer fixes this?
