Kreon
14 November 2021 23:09
22
On these two points, I did not quite understand:
sudo mount /dev/sdXY /mnt
sudo mount /dev/sdXY /mnt/boot/efi
In both sdXY commands, this is the boot partition. Or the first disk Manjaro and the second boot partition.
Disk Manjaro /dev/sdd and boot partition /dev/sdd1
I have one manjaro system, this must be done?
Aren’t using this to chroot into your system?
grub-mkconfig must be run in order to detect ALL operating systems, Linux, Windows or whatever you may have installed. Anytime any changes are made to GRUB, you have to run grub-mkconfig.
Kreon
18 November 2021 21:31
25
Oddly enough, I was able to boot the Manjaro to an SSD from Live-USB through the item to find UEFI bootloaders.
How to properly reanimate the UEFI bootloader now?
apply this
boot on USB live EFI ( choose with < USB vendor name > < partition 1 > ) ,
do not select your disk , only live manjaro
open a terminal
inxi -Mxa
sudo efibootmgr -v
sudo efivars -l
sudo lsblk -fs ( check UUID )
sudo manjaro-chroot -a
cat /etc/fstab ( UUID should be the same Here for /boot/efi)
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --recheck
update-grub
sync
exit ( end chroot )
then you can reboot
Kreon
20 November 2021 01:05
27
Thank you very much. Fixed, SSD is loading.
system
Closed
22 November 2021 15:05
28
