Every time when I poweroff/reboot my computer it gives an irritating sound and on my screen I see this text:
Broadcast message from “my computer name” (“current date” ):
The system is going down for reboot/poweroff NOW!
Is here any way to disable this? (At least remove the sound)
There were no such things before.
Tomek
3
Go to System Settings → Notifications → Applications: Configure → Local System Message Service → Configure Events and uncheck Play a sound
There are no such options in Applications: Configure
The sound is initiated by systemd - for a desktop system you can use the blacklist pcspeaker option.
For KDE the place is
Bell notification settings can be modified in “System Settings” → “Accessibility Options” → “Bell”.
Tomek
6
My mistake, I forgot about Notifications. Fixed
system
Closed
7
