i get this
cat /etc/environment.d/qt5.conf
export QT_QPA_PLATFORMTHEME="qt5ct"
what i am doing wrong?
i get this
can’t copy/paste from screenshot
(required values: qt6ct or qt5ct)
Hasn’t there been a change from QT5 to QT6 recently?
so: try the other one …?
When/where do you get this?
The syntax is wrong.
/etc/environment
accepts KEY=VALUE
entries.
(delete the export
opening qt5ct
nothing changes
Did you reboot?
yes i did reboot
Having looked at it in two different VM’s (Plasma and Xfce4)
I don’t even have anything there in /etc/environment in either one
opening qt5ct
works in Xfce4 (and is not needed in Plasma, I guess - the command isn’t even present)
Here on xfce in /etc/environment, mine looks as follows and all is fine. I no longer get the message that the OP has:
QT_QPA_PLATFORMTHEME="qt6ct"
Apparently doing the environment.d does not work it needs to be done directly on environment
indeed
# This file is parsed by pam_env module
# Syntax: simple "KEY=VAL" pairs on separate lines
This, in turn, can be configured here:
/etc/security/pam_env.conf
A better place for this is .profile, or .bash_profile.
