The PS1 in gnome-terminal with zsh is asymmetric
As shown below, it’s not symmetric up and down. Which font should i use ? I have tried DejaVu, Hack Nerd. In Droid Sans Mono Font, it display in a rectange not triangle.
looks like line height - I don’t know what causes it - although I am fairly certain it is something local to your system.
It could be related to the GPU in use.
Did a quick check - under normal circumstances it appears as expected - tested in VirtualBox VM
Summary
Thanks.
Below is inxi -S results of mine.
  Host: xxxx Kernel: 6.5.9-1-MANJARO arch: x86_64 bits: 64
    Desktop: GNOME v: 45.0 Distro: Manjaro Linux
Still the same after update to 45.1 - still virtualbox vm
Summary
