There’s been a lot of updates recently and over the past 24 hours I have notice a lot of screen bleeding. Was wondering if anyone else having same issue? The Nvidia drivers have been updated a couple of times this week. Do you think a change of kernel will resolve the issue?
Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=946d67f7-e2d1-44f8-96b2-4bf678b3bde9 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F22 date: 06/12/2017
Info: model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3255 high: 3600 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3600
4: 3600 5: 844 6: 3600 7: 3600 8: 3600 bogomips: 57616
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1b81
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-4 res: 2560x1440 dpi: 109 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 831.27 GiB (89.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX002-2DV162
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 831.27 GiB
(90.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 300 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 259 Uptime: 11h 1m wakeups: 0 Memory: 15.58 GiB used: 4.68 GiB
(30.0%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 2008 pm: pacman pkgs: 1995 libs: 480
tools: pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 13 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.22
