I’m afraid you will need to start a new topic for this.
General rule: One issue per topic/thread.
Please provide your system information as described (below) along with any other detail that might help others help you.
Your post has been moved to a dedicated topic. Please change the title so that it better reflects your actual issue.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a
at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
| inxi man pages |
(manual) |
If running `inxi` within a `chroot` environment
- Add
--color=0 to the long-form command, or…
- Change the short-form command to
inxi -zv8c0
Your privacy is respected
Update Announcements
Technical Resources
